Question about APC Back-UPS Office 500VA (BF500) UPS System
Bf500-fr not work
LED-s not shining
Vizio e65x-c2 led tv has no backlight but has sound and display works when shining a flashlight on it. What board should I replace?
Chances are its not a board issue but bad LED lamps in the panel, you can measure the voltage at the LED output from the power supply and see what you have there to get a better idea whats going on
Dec 14, 2017 | Vizio Televison & Video
Samsung LED no picture but have sound. Is this the T-con board?
first shine a light on the screen and see if you can see the picture if you can its the led board failed. this can be a bad led in the back of the screen or the power board for the leds. it can take a few angels to see the screen but if you can shine light in the back or at and angle on the screen you will find out the problem.
Jun 22, 2017 | Samsung Televison & Video
How do I get the picture back on my LG LED 50 flat screen? Sound works, no picture.
-You have a bad panel. Led arrays internal to the panel are defective. Replacement cost exceeds economical repair.
Apr 27, 2015 | LG Televison & Video
Power led light
You need not worry, it appears the LED light is a little faulty and your switch mode power supply is OK.
If you are worried then replace this LED.
Mar 04, 2012 | HP Compaq dc7600 Small Form Factor PC...
Three out of the five plugs do not work have stopped working.
The APC UPS will power the non-battery (label something like surge only) with the power button turned off. If the outlets that are not powering up are labeled Battery/Surge, you need to turn on the UPS. There should be a button you depress to turn the system on.
Also if this is a new UPS, you will need to hook up the battery for this to work. Open the bottom of the unit and you will find the battery and plugs.
Jul 20, 2011 | APC Back-UPS Office 500VA (BF500) UPS...
APC will not stop making noise even after I
Disconnect the battery(s) from inside. The backup batteries are still working...
Mar 12, 2010 | APC Back-UPS Office 500VA (BF500) UPS...
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
IWILL DH800 power problem ??
try removing, cleaning the contacts and reseating the memory, see if that works
regards
Nov 24, 2008 | Iwill DH800 Motherboard
Surge protectors
No no need to charge there may loose contact between power cord and surge protecter or internal loose contact between sockets that can be removed
Nov 12, 2008 | APC Back-UPS Office 500VA (BF500) UPS...
APC Back-UPS Office 500VA (BF500) UPS System Logo
29 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
