Question about Sunheat Electric Heaters: 25 in. 1500 Watt Infrared Electric Portable
Thermal wave infrared fireplace
The rod that turns in the back to make the fireplace look like it is flickering has stopped turning.
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I get a replacement flame effect?
I have a vermont castings radiance 2600 fireplace, the pilot light is lit but the on switch isn't turning the fireplace on
desa is out gone but maybe pro com have a controller with the same controls as the desa check #on the control and see cross ref in Google search they can be 80.00 and up but can b found
Dec 10, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
Flame has stopped flickering on our Century Heating electric fireplace, model HEF26. Fuses or motor?
Probably, neither. If there's no brightness at all, the bulbs are burned out and need to be replaced. If the brightness is there, but no flickering, then it's probably the motor or the shaft that the bulbs are on is stuck and can't rotate. Really not an uncommon problem with electric fireplaces, no matter who the manufacturer is. If you don't hear a humming noise when the flame function is turned ON. the motor may have overheated and shut down.
To test this, turn the Master ON/OFF Switch to OFF and unplug the fireplace from the wall outlet. Wait 12 - 15 minutes. Plug the unit back in and Turn the Master ON/OFF Switch to ON. Turn just the flame function ON. If it starts right up, the motor has cooled and the unit reset itself. If this continues to occur on a regular basis, contact the manufacturer's Technical Service Dept. If nothing happened after it was turned back ON, contact the manufacturer for replacement parts.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
I have a Delonghi type Venice fireplace serial no 52013. Normally it has a nice flicker which goes up the back of the fire place and looks like a normal fire. Today the gentle flicker has turned to a very...
Did you fix it as I have a Delonghi Venice electric fire which has just stopped working for no reason? There is electricity going to the circuit board but nothibg is working. Could this be a faulty remote control?
Aug 28, 2010 | Heating & Cooling
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Where can I get parts and/or service for my electric fireplace. The ''flame'' does not work. The lights work and the heat works but the ''flame'' does not flicker I live in central Missouri
I think you'll have to replace the entire insert.
I found some at the url below
http://www.electricfireplaces.com/inserts.htm
I have not purchased from them before, but it seems like they have a very good selection.
Nov 27, 2009 | Heating & Cooling
Light comes on but dont flicker
Most likely this is becasee motor driving the "tinsel in a stick" is not working. Take the glass off, remove the fake logs and look underneath to see if the the rod wih the tinsel is turning. If not the problem could be the motor or the speed control. If you have a voltmeter you can test the speed control output - it's 12VDC - of course it will vary depending on the speed sselection. The mot probably cause is the motor has died. You can buy a new one at www.ibuyfireplaceparts.com. Cost is $77.01> it's a bit tricky to replace - just a tight spot is all - 2 small screws and out it comes.
Oct 03, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Flickering lights have stopped working
basically, on the bottom of the fireplace, there are 2 screws on the sides, 3 on the back, take them off, lift bottom (it wont come off, so be careful not to bend it) there are 3 christmas light type bulbs, you can find them at any hardware store. Just replace them. Problem solved.
Jun 18, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Sunheat Electric Heaters: 25 in. 1500 Watt Infrared Electric Portable Logo
87 people viewed this question
Top Sunheat Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Sunheat Fish Expert? Answer questions, earn points and help others
