Question about Onkyo Remote Control RC-745M p/n:24140745
Volume control every button on my ONKYO RC-745M Remote Control work fine except the volume control to lower the volume...i can raise the volume with no problem
petraman7
  • 1175 Answers
SOURCE: How to set factory codes for remote
Have you tried the Onkyo website yet?
Posted on Mar 18, 2008
SOURCE: onkyo Remote Controle Codes for XBoX 360
Try 32083 or 30522.
Posted on Jan 26, 2009
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 06, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
SOURCE: Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Posted on Sep 13, 2009
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
Manual owners www
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Jul 26, 2014 | Onkyo Remote Control RC-745M p/n:24140745
Remote will not turn up volume
If you are using your Onkyo remote to adjust volume of your TV, it may not be able to because the TV volume adjustment is in "steps" rather than continuous.
Apr 18, 2014 | Onkyo Remote Control RC-773M p/n:24140773
Why does My RC745m remote control does not function?
Most likely, the remote is not properly paired with the device. The manual for either the AV receiver or for the remote itself should have instructions for how to program the remote codes. If you do that and still have issues, the remote itself could be faulty.
Dec 18, 2013 | Onkyo Remote Control RC-745M p/n:24140745
Remote codes for Samsung DVD-Blu-Ray players needed
These are the codes to check. 2066 2052 2097 2180 2027 21302056 2102. If you wish to get more details and codes, check this lin. Pull up older posts there, either by its left side bar, or, see it in 'Timeslide' option. http://electrohelponline.blogspot.com/ Check this link too. http://electronicshelponline.blogspot.com/
Jun 20, 2013 | Onkyo RC-745M Remote Control 24140745
Volume control not working properly on my remote control, all other buttons are fine, do I need a new remote or canI get it repaired if so where? Onkyo HT550 unit
Did u tried disassemble remote control and clean PCB with clean cloth? Also u can take rubber part of remote and wash it carefully in soaped water . While u have it disassembled check for bad solder connections at IR LED on remote controller . Regards .
Oct 01, 2012 | Onkyo SKS-HT500 System
Sep 12, 2009 | Onkyo TX-SR606 Receiver
All remotes controlling my Onkyo TX-SR304 stopped working
try putting the remote an inch away from the IR receiver on the unit and see if it works then, if so then you definitely know its broken. This can and does happen. From what you have posted it sounds like no remote is working on the receiver, the ir receiver can break. If you need further assistance let me know.
Thank you,
Lee
May 28, 2009 | Onkyo TX-SR875 Receiver
Onkyo Remote Control RC-745M p/n:24140745 Logo
180 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
