LG top loader fuzzy Logic 6.5kg wf t655th
My washing machine is not spinning or draining unless drained manually.Does not seem to be any blockages. Also where is lid switch located ? LG top loader fuzzy logic 6.5kg WF-T655TH
Yazz226
  • 497 Answers
SOURCE: my washing machine is not
  • That the outlet hose is not kinked or raised more than 40° from the floor.
  • If you wish to remove articles when the water will not pump out, place the end of the drain hose into a bucket on the floor and allow water to drain out by gravity, noting that more than one bucketful may be present. Hook the hose into the sink again and try the spinner before removing the articles - if this fails most of the water can be baled out with a cup.
  • If the above method fails to remove the water then the pump is probably blocked - do not open the door, but contact your nearest Service Engineer.
  • Thanks for using Fixya!
    Posted on Aug 26, 2008
    • 6 Answers
    SOURCE: I have a Brand LG
    You probably have the drain hose too far down the standpipe and it is siphoning out. Check that first. If that doesn't work, look up Catriver, sounds like that cat knows his stuff. Tenbears.
    Posted on Dec 20, 2008
    SOURCE: LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine not spinning
    hi...I have an LG Fuzzy Logic 6.5 Kg WF-F733PC washing machine & it's stop when 3-4 second start washing, wash and spin led appear also the buzzer bip contibuosly...any ideas?it's software problem....need advice
    Posted on May 22, 2011
    SOURCE: HI, my Fuzzy logic WF
    Hi, my LG Fuzzy Logic WF-T502A washing machine, washes and drains but will not spin dry. Please advise on what I should do. Thanks.
    Posted on Jul 03, 2011
    • 6277 Answers
    SOURCE: my washing machine fuzzy logic wf-t1391tp does not
    I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
    Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
    If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
    REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
    It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
    Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
    At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
    (If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Posted on Jul 13, 2011
    HOW DO I FIX ?
    sounds like the timer has decided not to work . repairman might be a best choice .
    Dec 13, 2015 | LG Washing Machines
    Lg fuzzy logic 4.0kg wf-402a wont drain
    First things first, check the pump / hoses for blockage, check if the pump is operational, check outlet hose for kinks.
    Apr 11, 2015 | LG Washing Machines
    Hi there ! I have a LG Top loader WF-T7030TP that wash the clothes but do not want to rinse,spin and drain the water.
    you have blockage in your drain in the machine-possibly something stuck in the drain pump like a sock or a paper clip-tear it down-have a couple of old towels handy for the mess-cheers Denny
    Oct 21, 2013 | LG WM Washing Machines
    I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
    I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
    Jan 16, 2012 | LG Washing Machines
    My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
    The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
    Jun 23, 2011 | LG Washing Machines
    LG Top Loader Fuzzy Logic 5.5. The water
    No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
    Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
    heatman101
    Apr 27, 2010 | LG WFT1071TP Top Load Washer
    I have an LG Fuzzy Logic top loader. it keeps draining water out
    If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
    Aug 07, 2009 | Washing Machines
    I have a Brand LG Top loader washing machine (Fuzzy Logic WF-T9235TP), it continue draining the water even if I am starting to wash
    Dec 20, 2008 | LG WFT1071TP Top Load Washer
    My washing machine is not draining the water properly,so when i do a wash, the clothes inside after its finished are still soaking wet and then i have to manually drain the water from the clothes. I have...
    Aug 26, 2008 | LG Washing Machines
    Washing Machines Logo
    35 people viewed this question
    Top Washing Machines Experts
