Question about Irulu 7" Google Android 4.0 Capacitive Touchscreen Cortex A10 Tablet Pc Bundle Case
It doesn't turn on!
I've bought an irulu tablet and, when I tried to put it to charge, the charger didn't work! Than I tried with the USB cable and seemed to work, but now, it doesn't turn on, just a light appaers when I press the button. What should I do?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
You should take it back to the shop if there is some troubles with any kind it could be broke or some problem with it
Posted on Mar 31, 2014
2 Suggested Answers
zcomputerwiz
  • 92 Answers
SOURCE: iRulu 10.1" tablet running under Android 4
Some printers (such as newer HP models) have a feature like HP ePrint that allow you to print from any device via email.
If your 3TB device supports FTP or SMB, there are apps available for Android (like AndFTP or AndSMB) to allow you to copy files to and from the device or your Windows computers.
Posted on Oct 30, 2013
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Charger malfunctioned. Blew tablet inside
As long as it is not an Irulu, take it back for repair. It is Irulu just buy a new one, they are cheap Chinese junk.
Oct 03, 2015 | Tablets & eReaders
My irulu X7 will not charge unless I hold charger n place. Otherwise it won't maintain the connection. What can I do?
If it's tha chargering socket, nothing. Ig it's the charger's plu, try to replace it.. I don't know wht kind of a charger is used by Irulu, hope it's a standard cable.
Aug 09, 2015 | Tablets & eReaders
My IRULU tablet will not charge.How can I fix it? Is there an internal battery,where is it?
Either the charger or connector has a problem. There is a battery, but it is not a normal replacement item. You will find the battery behind the back cover.
Jun 16, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
I bought two irulu tablets but the both broke in the same exact spot, in the charging port. the pin broke out and i cant charge them now. Is this a flaw with all irulu tablets or just the two I bought
I would definitely follow your friends advice. If they are under warranty, you should be able to get them fixed. If the battery can come out of the tablet, you can use a universal charger to charge the batter, but I am assuming it doesn't.
If you know how to solder, then you could replace the port yourself, but this is risky, so getting pro help is the best bet.
Feb 14, 2015 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Why won't my table charge?
Will the charger fit any other device that you have? If so try to charge some other device. It appears that there are only two possible problems. 1 The charger is bad.- 2 The tablet is bad.
Read your manual regarding charging and how long the first charge should take.
Aug 15, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
We got a RULU in 12/2013. It worked for 3 months and now can not charge i
Some tablet brands will not recognize certain charger brands or connections.
First, try all available connections-USB-wall inverter, and direct computer connection (making sure the computer is awake and logged in). Second, try restarting your tablet. Third, try gently wiggling the connections on both ends, to see if it recognizes a charge. Finally, leave it plugged in for a few hours, even if it says it isn't charging. You may have a trickle charge-to put it simply, the cord is not giving the device enough power to qualify as a charge, but there is power traveling through the cord. If the charge level goes up a little over that time span, you have a trickle.
If these don't work, just purchase a new charger. They're sold everywhere-Wal-Mart, Target, Best Buy, 7-Eleven, name a store and they probably sell USB charger cords.
I hope I helped.
Jul 08, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
I turn it off and went to it back on and now it want power back on
It is a bit hard to understand your problem.
I assume that you switched it off and is not working.
From experience with other tablets, I would first charge it. (Verify by substitution that the charger is working). Ideally use an external charger and not a computer USB.
Then, if satisfied that the tablet has fully charged, I will press and hold the power on button for up to 30 seconds until the screen stirs.
A better descrition of your problem in clear sentences would help.
Nov 04, 2013 | Irulu 7" 4gb Mid Google Android 2.3...
How do u charge an irulu tablet, didnt get a charger with it
I got my tablet with a charger but after some time it got damaged.. NOW I USE THE MINI-USB cable to charge it.. you can use an adaptor like the one that comes with the Samsung galaxy cellphone and use the mini usb cable with it.. Hope you understand my mess.. good look..
Dec 13, 2012 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Irulu 7" Google Android 4.0 Capacitive Touchscreen Cortex A10 Tablet Pc Bundle Case Logo
111 people viewed this question
Top Irulu Tablets & eReaders Experts
john smith
gbob59
David Harrelson
David Harrelson
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
