Samsung WF316LAS/XAA FL Error code
Already replaced locking mechanism. With power off: 56 to 62 Ohms between CN10 Pin 7 (Sky Blue) and CN5 Pin 3 (Blue) 56 to 62 Ohms between CN10 Pin 8 (White) and CN5 Pin 3 (Blue) With power on: 120 VAC at CN10 Pin 8 (White) and CN5 Pin 1 (White) 120 VAC at CN10 Pin 7 (Sky Blue) and CN5 Pin 1 (White) 100 VAC at CN7 Pin 2 (Black) and CN5 Pin 1 (White) Given that the last test should be 120 VAC, does the PCB need to be replaced or I have made a mistake someplace?
3 Suggested Answers
  • 380 Answers
SOURCE: HAVE LE CODE ON SAMSUNG WF316LAS/XAA WASHER LE CODE AND BEEPS
LE is a water level issue.
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
Posted on Dec 23, 2009
richroth
  • 9472 Answers
SOURCE: I'm getting error code tE on samsung silvercare WF316LAS/XAA
tE is mostly related to
temperature sensor wire and connection problem. Look for a broken or loose wire.
Posted on Dec 07, 2012
I have a Samsung front load washing machine wf328aaw/xaa. the drain pump motor is not getting the 120 to run the motor. I tested the resistance on the motor and it tested ok as 13.8. when I put the w
Have you resistance tested the cable from the pub to the pump connections ? The sensor problem I had which was linked to failure to drain was connected to a piece of tube some sort of pressure sensor .. The tube had a split so it was not detecting the pressure (of I assume height of water left in the machine) split was at the top .. Bit of trimming of the pipe fixed the problem
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
My samsung washer WF316LAS/XAA has a e3 error code I took the stator off and you can see a smoke or burn spot on it do you think that's the problem?
almost definately. check the resistance across the windings of the stator. they should all be the same. (which they almost definately won't be if theres a burn on there)
Nov 07, 2013 | LG WM2016C
Maytag washer nd code
The control board is faulty and will need to be replaced. Here is the part to order and it comes with a 365 day, any part, any reason return policy.
Jun 23, 2013 | Maytag MAH8700A Front Load Washer
Dec 07, 2012 | Washing Machines
Samsung WF350ANR/XAA has an error code FL and door will not lock to start cycle
The FL Code means that the door failed to lock. Turn the machine off and restart the cycle. If this does not clear the error message and the machine does not return to normal, you will need to contact a Samsung repair service.
Jul 25, 2012 | Samsung WF337AA Front Load Washer
Where is the debris filter on a Samsung WF316las/xaa?
There is no more filters to be cleaned on front load machines. It's a self cleaning filter and everything goes through the drain.
Mar 14, 2011 | Samsung WF337AA Front Load Washer
I have a Samsung WF316LAS/XAA Washing Machine, has worked great for 4 years. Just started pouring water out of the soap dispenser drawer when in a washing cycle. Any advise
take off the top and check the hose that leads to the tub may be plugged . May have to take the boot(door)seal off front under door to access lower end.
Nov 20, 2010 | Samsung WF306BHW High Efficiency Front...
- Main PBA fault.
Dec 19, 2009 | Samsung WF316BAC 3.79 cu.ft High...
I have a samsung front load washing machine wf316las with an error code PF. please help
WF316LAS
In the washer owners manual it shows "PF" code with the following explanation.
Meaning
Electric service was lost when the washer was running.
Solution
Restart the cycle by pressing the cycle selector dial.
I hope this helps a little bit.
Apr 04, 2008 | Samsung Washing Machines
Washing Machines Logo
Top Washing Machines Experts
