Question about Sewing Machines
Shuttle race of my sewing machine refuses to move
  • Sewing Machines Master
  • 626 Answers
Either you have the wrong bobbin carrier or you haven't put it in properly. If it is inserted wrong it will not move.
Posted on Apr 09, 2014
SOURCE: Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Posted on Feb 05, 2009
kent581
  • 87 Answers
SOURCE: Can't reassemble shuttle hook and shuttle race
the hook driver (still in machine) is 1/2 moon shape. The hook is also 1/2 moon shape. If you set the machine on its back, it's easier. Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed out. Needle gaurd to the top of the machine. Snap the twist locks in place and viola!
Kent
Posted on Mar 18, 2009
  • 1788 Answers
SOURCE: I need a diagram to re-assemble the shuttle race
Hi, if you go to sears parts direct and put your model #in you will get a diagram of the parts and how they go together. Looks like you have a real classic there. If, you cannot figure it out from the diagrams, try and find a reliable repairman, someone who has been in business for a few years. Good luck, Happy New Year
Posted on Jan 02, 2011
SOURCE: Singer Sewing Machine 6105 - shuttle does not always move although everything else does.
you might think of having the machine serviced
Posted on Mar 07, 2012
SOURCE: sewing machine not working
have you cleaned under the needle plate for lint
also in the bobbin area for lint or loose threads
make sure the bobbin is inserted correctly into the bobbin case
make sure the bobbin is not warped
try changing the needle
try rethreading the machine top & bobbin
if none of these suggestions work,, then it will be a good idea to
have the machine checked at a repair shop
Posted on Aug 24, 2012
How do I put the shuttle race and the shuttle hook back into my front loading sewing machine?
You didn't provide the make & model of your machine, but one of these may be helpful:
install bobbin shuttle Google Search
Dec 21, 2016 | Sewing Machines
Help hand wheel of zigzag sewingmachine refuses to move
The make/model of your machine would be very helpful in assisting us to provide advice.
Just offhand, if it is a mechanical machine, it most likely needs a good cleaning and oiling. When mechanicals are not regularly oiled, the old oil solidifies and causes the moving parts to seize. It is important to use a good quality sewing machine oil--NO 3-in-1, WD-40, cooking oil, or old stinky brown stuff from grandma's sewing box.
May 24, 2016 | Sewing Machines
MY BOBBIN CASE HAS FALLEN APART AND I'M NOT SURE HOW TO PUT THE PIECES BACK TOGETHER.
Sounds like you are describing the hook. Perhaps the owner's manual would be assistance. We don't know the make/model of your machine so are really unable to help. There are some videos on YouTube that show how to install a shuttle and bobbin case, but machines differ.
Set up the shuttle race for RS2000 Series
Brother LS30 Inserting Bobbin Vertical Shuttle Hook
How to Clean and Maintain your Sewing Machine at Home Front Loading Bobbin
Mar 14, 2016 | Sewing Machines
The upper thread becomes jammed inside the lower track of the shuttle. What can I do?
Try a brand new needle. Change thread. Make sure the needle is installed facing the correct direction and is pushed all the way up. The upper tension may be too loose.
Short of that, could be the machine's timing is off.
Dec 16, 2015 | Euro-Pro Shark by Euro Pro Sewing Machine
The brother XL3500i is only sewing backward how can I fix the problem?
I suggest taking the machine to a sewing machine shop & letting them check to see if the reverse button is damaged in some way
Mar 13, 2012 | Brother XL-3500
Brother XL-2022 Bobbin Problem
Removable parts are the race and bobbin case.
Raise the needle to it's at the highest position and set the race hook into the shuttle so the hook is at the lower left.
Re-place the hook race cover and move the levers or pegs to hold the cover in place.
Apr 18, 2010 | Sewing Machines
I need to know how to clean and oil the machine
From the Sears Kenmore manual:
Using a small brush, remove the lint that accumulates in the shuttle area and around the feed dogs.
To Clean the Shuttle Area:
  1. This area must be kept free of dust, lint and occasional tangled thread. Raise the needle bar to its highest point and remove the bobbin case.
  2. Push levers of shuttle race aside and lift shuttle race cover and shuttle out.
  3. Clean the shuttle race with a small brush.
  4. Put a drop of oil on the center pin of the shuttle and shuttle race.
Jan 25, 2010 | Sewing Machines
Bobbin and shuttle case pop out of machine .
You might need to clean the shuttle assembly.
1. Raise the needle bar to its highest position and remove the bobbin case.
2. Push levers sideways of the shuttle assembly and liftshuttle and shuttle race cove out by the center pin.
3. Clean the shuttle race of any lint or small particles of thread with a small brush.
4. Put a drop of oil on the center pin of the shuttle and on the shuttle race.
to reassemble, hold sjuttle by center pin and it carefull into assembly opposit the shuttle driver. Slip shuttle race cover into place. Snap the levers into position.
Occasionally remove the needle plate and clean feed dog with soft brush.
I hope that helps!
Apr 23, 2009 | Brother LS-2125 Mechanical Sewing Machine
Material won't feed just stays in one place, the drop feed control doesn't move the teeth.
hi! there,
feed dogs are mechanically connected to shuttle race link.everytime shuttle race rotatate and needle goes up and down the move relative to its timing order.there is control knob on feed dogs to release or goes down permanently not to move,on the right side of machine.if you push down feed dogs go down.try to find this one,if you can't try to see uder the machine if there a loosen parts behind shuttle race holding feed dogs.tighen this up.hopefully this could help you,have a nice day,just rate me thank's
Apr 19, 2009 | Singer Sewing Machines
Kent
Mar 16, 2009 | Baby Lock BL1556
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
