Question about UPG 12V 8Ah Zap Zappy 3 EZ Scooter Battery - UB1280EBALT156
Wiring diagram for 3 wheel 12 volt electric zappy 3 scooter
Wiring diagram
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
I need a wiring diagram for my Pride victory 3 wheel scooter. Where can I get one mine is all messed up?
Try spinlife.com or call them at 1-800-850-0335. Maybe Customer support or manuals, technical assistance.
Jul 09, 2014 | Pride Victory 4 Wheel Mid-Size Electric...
Scooter wiring diagram
Bad connections on the battery posts is most likely. If the circuit breaker was bad you'd get nothing at the battery . The charger voltage is 29 volts when not connected to the batteries. 26 or more when connected and on.
Jun 30, 2013 | Pride Mobility Revo 3 Wheel Electric...
Need a wiring diagram for a Scoot-N-Go Elecric scooter?
After getting a new set of batteries, now when I turn on the key the scooter's motor engages and takes off. I have the wiring diagram and everything looks right, what could be the problem?
Feb 04, 2012 | Health & Beauty
I need to replace the battery case for my Golden tech liteway scooter. Or i need to see a wiring diagram. Can you help?
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
Apr 24, 2011 | Golden Technologies Golden Liteway...
WIRING DIAGRAM FOR A PEP-PAL FROM MEGA MOTION CONTROL ON THE POT.
New batteries, scooter will go in reverse, but doesn't want to go forward,what should i do?
Sep 07, 2010 | Golden Technologies Avenger 3 Wheel...
UPG 12V 8Ah Zap Zappy 3 EZ Scooter Battery - UB1280EBALT156 Logo
233 people viewed this question
Top UPG Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an UPG Health and Beauty Expert? Answer questions, earn points and help others
