Question about Samsung DV410AER Electric Dryer
Samsung dv410aer/xaa motor hums but drum will not spin
I can start the spin by hand, and then it runs fine. Belt and tension springs are great, could this be a capacitor? If so, I cannot seem to find one to replace it, could they be referred to as something else?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 50 Answers
Could be the start windings in the motor, most dryers dont have a external capacitor
Posted on Mar 24, 2014
4 Suggested Answers
  • 3074 Answers
SOURCE: I have a samsung dryer mod DV218AGB/XAA. The dyer
maybe the belt:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Nov 29, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
  • 3 Answers
SOURCE: Samsung dryer hums but the drum does not turn
It sounds to me like the drive belt that goes around your dryer tub has broken.
images?q=tbn:and9gcqu5itfzbd0xyagva6nfwjbc486ekglruzljwmfemwgndlj-mg5tw
The back of the dryer will need to be removed to gain access to the problem.
Posted on Oct 27, 2012
I have a Samsung electric dryer dv400 that the drum doesn't turn when you press start. It just hums but doesn't turn.
Check the blower housing to be sure there are no foreign objects blocking the blower wheel from spinning, also see if you can turn the drum by hand, but don't spin it more than a foot or two as the belt may come off.
Jul 24, 2016 | Samsung Dryers
Samsung elec dryer, Model dv5451aew xaa 01. Drum not spinning. Belt ok. Dr Sw ok. Changed both fuses on heating element. Nothing.
Samsung dryer won't spin, belt is fine - Fixya
www.fixya.com/support/t8946132-samsung_dryer_won_39_t_spin_belt
Apr 14, 2011 - Question about Samsung DV218AEW Electric Dryer. 2 Answers ....Samsung dv410aer/xaa motor hums but drum will not spin. Mar 21, 2014 ...
How to Fix a Samsung Dryer: the Drum Won't Spin
www.ehow.com > Home
From time to time a dryer's drum can fail either by jamming up, a technical error ...Support US Samsung: The Dryer Drum Does Not Spin · Repair2000: How to .
Oct 16, 2015 | Samsung Dryers
Samsung Dryer Model DV419AEW /XAA Dryer will not
I doubt its the main board. Try seeing if the drum is tight and seeing if the belt broke by spinning it by hand. If the drum is real sloppy and you can't feel motor tension, you need a belt. I would rule out the mainboard until last because the belt is like 89 cents.
http://www.amazon.com/341241-Whirlpool-Kenmore-Dryer-Belt/dp/B00064NH6E
http://www.youtube.com/watch?v=zNATJ8qyqP4
Sep 27, 2013 | Samsung Clothes Dryer Control Panel Main...
We have a MMDE9206AYM model dryer that makes a low humming sound but will not start. Last night it also produced a burning smell. I assume either the belt is gone or the motor is overheating although it...
Sounds like drum is locked and motor is running and burned the belt. Try to spin drum by hand, Might check drum ends felt seals, Teflon bearing strips located on the bottom lip of front drum end for wear causing drag. Also check 2 drum support wheels to see if they spin freely, take the belt off motor pulley and spin drum by hand, if easier & motor runs drum is dragging. How is the spring on tensioner, does tensioner pulley spin free? Hope this helps locate the problem.
Feb 13, 2011 | Maytag Dryers
We just purchased a new Samsung Dryer model #DV218AEB/XAA the lights will come on but when you attempt to start the dryer there is a hum, the dryer does not spin, then the hum goes away after a few...
Could be a couple things causing this problem. If you can turn the durm by hand without much resistance then the belt may be too loose. This could be because the spring on the tension pully came off or the belt streached. The humming you hear is the motor spinning. If you cannot turn the drum by hand then something could be stuck between the drum and the frame of the dryer.
I would also check that the dryer is wired correctly, because low voltage could be causing the motor to hum but not turn.
Dec 23, 2009 | Samsung DV218AEW Electric Dryer
When pressing the start botton it hums but will not spin. This is on a Kenmore dryer
Remove the rear panel and check to see if the belt is broken. If it looks ok, try to turn the motor by hand. If ok, watch while the machine is tried--if the motor turns, but the belt doesn't move, then check the belt tensioning idler for a broken spring. If the tension device is pulled to it's stops and the belt is still loose, replace the belt. The front panel must be removed to access the belt which passes over the top of the drum. Hope this helps.
Oct 28, 2009 | Dryers
Dryer will not move but power good
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Oct 05, 2008 | Samsung 7.3 Cu. Ft. Super Capacity...
BELT WON'T TURN THE DRUM
there is a tensioner pulley as well as the drum and motor
It hooks into a slot, usually on the floor of the case, and has a spring that pulls it against the belt to tension the belt.
Broken belts have been known to knock the tensioner out of place, it should be sitting on the floor of the case as should its spring.
There is usually ony one slot for it to sit in, self evident if you know to look for it
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
fd5c779.jpg tensioner may be on the bottom run pushing up, or on the top run pulling down
Jul 07, 2008 | Zanussi TC7114W Electric Dryer
Samsung DV410AER Electric Dryer Logo
319 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
