Question about Frigidaire FGUB2642L
Cannot reset the filter light
I have replaced the water filter and have tried to reset the filter light but cannot
  • Official Brand Answer
  • 2,267 Answers
Hi David, this is AP.
I understand you are having trouble resetting the water filter light on your Frigidaire refrigerator. On this model, FGUB2642L, I would start by pressing and holding the water filter button located at the top of the display panel for 3 seconds if you have not already. If that option does not work I would recommend using the default settings button. Hold down on the button to reset all refrigerator settings. If that still does not rest the light I would suggest cutting power to the refrigerator for a few minutes to reset the display. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect if you have additional information regarding your question.
Thanks,
Posted on Mar 21, 2014
Filter light on
Water Filter Status Light and Filter Reset
The filter reset control allows you to restart the water filter status
tracking feature each time you replace the water filter. See "Water
Filtration System."
After changing the water filter, reset the status light. Press the
OPTIONS button to enter Options mode, then press LOCK to
initiate the reset, then press MEASURED FILL to confirm that
you want to reset the status light. When the system is reset,
the "Order" and "Replace" icons will disappear from the
display screen.
These instructions can be found in the=> GZ25FSRXYY2 User Manual . As for the dispenser and ice dispenser problem this could be related to a loose connection in the door where wiring attaches to control panel and/or where door wires go from door to cabinet also a defective pressure switch where glass is pressed to get water or ice. Can you tell me when this additional problem began?
I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | Whirlpool Refrigerators
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I've got a side by side Whirlpool refridgerator. The Water Filter status light is not indicating. What could be the problem and solution?
There are several pages that explain dispenser programming. This is on page 10 of the owners manual.
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> sea_breeze_132.jpg Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
Apr 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I am replacing the water filter how do I reset on the outside door
The Water Filter Status Indicator Light serves as a
reminder to replace the water filter. A green light
indicates that the filter is in good condition. A red light
indicates the filter should be changed. Once light turns
red, it will remain red until function is reset.
To Reset Indicator:
• Press and hold both the Lock and Water
buttons simultaneously for four seconds. The
green filter status indicator light will flash
three times when the function has
successfully reset.
Thanks, Sea Breeze
May 17, 2010 | Jenn-Air JCD2295HES Side by Side...
Change filter light
Light (select models)
To Reset Indicator:
successfully reset.
Sea Breeze
Nov 25, 2009 | Maytag MSD2650H Side by Side Refrigerator
Changing light after installing new water filter
(select models)
To Reset Indicator:
• Press and hold both the LOCK and WATER
successfully reset.
Aug 12, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Reset after water filter replacement
Generally all you need to do is push and hold the filter reset button in for 3 to 5 seconds to reset it. However, even with the filter light on, it shouldn't stop the water flow as most of the time on most brands it is just an "idiot light" that is on either a timer based on number of days or on number of minutes the water has flowed through the water valve
Dec 16, 2008 | Refrigerators
Reset the water filter indicater light
hold light and lock buttons until lamp blinking release and lamp turns off no it is reset.
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire FGUB2642L Logo
241 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
