Question about Bosch Dryers
Bosch wtmc632 motor hums when start button pushed but won't turn. Spinning drum by hand starts it spinning
  • 50 Answers
Bad start winding or lint in start switch in motor not letting it go to start position.
Posted on May 04, 2014
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
larryyb
  • 291 Answers
SOURCE: dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Posted on Dec 05, 2008
appldoctom
  • 311 Answers
SOURCE: Dryer drum wont start spinning after pushing the start button
the problem is with the start winding on your dryer motor.it is centrifical switch,so if a lint build up gets in that motor switch area it stays on the run winding.pop the top .remove the frount.pull drum.vacume motor out if then starts on own great.other wise you need new motor.parts about 100$God bless,tom
Posted on Jan 02, 2009
  • 574 Answers
SOURCE: dryer drum will not spin when you push start button.
can you hear the motor running? if so its probably a broke belt
Posted on Sep 03, 2009
Testimonial: "Thanks so much roberta3fan. "
dmftrucker
  • 1922 Answers
SOURCE: dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Posted on Nov 01, 2009
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
When you push the button to start the dryer, all it does is buzz and nothing happens
next time send the model number and brand name,all dryers are not the same!it sounds like a bad motor.open the door,push the door switch in with one hand and with the other spin the drum,while you're spinning the drum have someone push the start button,if the motor starts you'll know the motor is bad but it might run for a while before it does this again or it will do it every time but either way the motor should be changed,also on some dryers if the belt broke it will buzz like when the dryer is down but if yours is more like a humming sound like power is going to the motor but it won't run then it's the motor.
Apr 24, 2011 | Dryers
Is making humming noise and drum does not turn.
the noise is coming from the motor,you either have something jammed in the motor or blower wheel stopping the motor from spinning or the motor is bad,try this,open the door,hold the door switch in with one hand and spin the drum with your other hand and have someone else hit the start button at the same time,this sometimes starts the motor but the motor still has to be changed out.let me know what you find and send the model number
Oct 22, 2010 | GE Dryers
I get no response when i push the start button of my dryer. Only a humming noise.
unfortunately the noise is your motor,try spinning the drum by hand,if it spins it's the motor,if it's hard to turn you could have something stuck in the blower wheel or the belt could be hung up on something that's not letting the motor turn,also try spinning the drum and hold the door switch in and have someone else hold the start button in to see if it starts,sometime there's a flat spot on the motor and you can get it to start this way but if it happens again you have to change out the motor or get a new dryer,good luck let me know what you find and if you need more help let me know
Aug 05, 2010 | Kenmore 62802 Electric Dryer
Dryer turns on but does not start when i push the start button. The timer comes on all the buttons light up, light is on inside dryer, but does not start just makes a sound when i hit the start button
if it's a humming sound the motor is bad or something is jammed keeping the motor from spinning.open the dryer door and move the drum by hand if the drum can't be moved the belt could be jammed on something or there's something stuck in the blower wheel.the blower wheel is behind the duct that the lint filter slides into.if you can move the drum then you most likely have a bad motor,try spinning the drum and push the door switch in and have someone else push the push to start button and see if the dryer will start,if the motor has a flat spot it could start like this.let me know what you find
Jul 14, 2010 | Kenmore 62602 Electric Dryer
I have to manually get drum turning...
Yes, there is a "startup" switch. It's the button you push on the panel (but I'm sure you know about that).
This switch energizes the start winding in the motor -- when the motor gets up to speed, a centrifugal switch in the motor disconnects the power from the start winding and switches to the run winding.
Either the start winding is not getting power or the winding is bad. If "no power" is the problem, it could be the button on the panel or a loose/dirty connection between there and the start winding. Lot of possibilities which need to be explored.
But if you know about pushing the safety switch on the door and spinning the drum by hand to get the motor started, you can probably fix this.
May 04, 2009 | Amana NDE2330AY Electric Dryer
Dryer wont run/push power-sounds like it wants to start/nothing
i get this all the time,yes it is the motor,what happens is the motor gets so weak that it will no longer turn the drum it just hums,a motor on ebay runs about $65,your model number if you want to tackle it is inside the dryer door-mike
Apr 24, 2009 | Dryers
When you press the start button the dryer hums and doesnt turn
first thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
Apr 18, 2009 | Dryers
Dryers Logo
24 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
