Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
My 7, 8, 9 keys down work
My Log, 7,8,9 and X keys are not working
How do you retrieve the last number called to this phone?
If you have a CiX system with Caller-ID, a Caller-ID "review" or "log" key must be assigned on the set. Also, a CID buffer of (x) calls must be assigned in system programming. Once done, to review calls, press the CID Log key, scroll up and down using the NEXT/PREV soft key. This does not work on the older DK systems.
Dec 16, 2015 | Toshiba DKT2020SD Phone
My kobo reader is asking for a password to log into the Wi Fi network re actiontec965. Where do i find this password
many times the default security key will be on a sticker on the router, it might say "wep key" or "wpa2 key" and it will be 10 or 16 characters long. if you don't find it or it doesn't work then you can do a factory reset on the router (hold reset button down for 12 seconds on the back of the router) and then log into the router settings by typing 192.168.1.1 into your web browser to get to the router log in page and you can find the wireless security key in there.
Apr 28, 2014 | Actiontec (GT704WG) Router
System control buttons not working on Toshiba Satellite a660
You can adjust these settings on the Make the keyboard easier to use page in the Ease of Access Center. 1. Open the Make the keyboard easier to use page by clicking the Start button , clicking Control Panel, clicking Ease of Access, clicking Ease of Access Center, and then clicking Make the keyboard easier to use. 2. Select the options that you want to use: • Turn on Mouse Keys. This option sets Mouse Keys to run when you log on to Windows. Instead of using the mouse, you can use the arrow keys on your keyboard or the numeric keypad to move the pointer. • Turn on Sticky Keys. This option sets Sticky Keys to run when you log on to Windows. Instead of having to press three keys at once (such as when you must press the CTRL, ALT, and DELETE keys together to log on to Windows), you can use one key by turning on Sticky Keys and adjusting the settings. This way, you can press a modifier key and have it remain active until another key is pressed. • Turn on Toggle Keys. This option sets Toggle Keys to run when you log on to Windows. Toggle Keys can play an alert each time you press the CAPS LOCK, NUM LOCK, or SCROLL LOCK keys. These alerts can help prevent the frustration of inadvertently pressing a key and not realizing it. • Turn on Filter Keys. This option sets Filter Keys to run when you log on to Windows. You can set Windows to ignore keystrokes that occur in rapid succession, or keystrokes that are held down for several seconds unintentionally. • Underline keyboard shortcuts and access keys. This option makes keyboard access in dialog boxes easier by highlighting access keys for the controls in them. If that does not work you may need to visit the web site of your computer manufacturer to see if they have some specific software installed on your computer that controls key functions.
Aug 31, 2011 | Computers & Internet
I cant delete my call log history on my nokia x3
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory
card. Key Code *#7370# (click this combination of keys on the keyboard
in the mobile)
You can also achieve Total Reset by pressing and holding down following keys:
* + 3 + Green Button (call) immediately after turning the mobile on.
Important: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset,
the mobile stop receiving electricity it can ruin the internal flash
memory of the mobile device and stop function.
If this does not work then contact your carrier.
Mar 05, 2011 | Nokia X3 Cell Phone
I foegot my pasworf, then reqested help and received a temporary Key but was still not able to log on. Help! I have closed Skype then reopeded it and reentered the temp Key and was still unable to log in.
Skype down all over the world keep up with skype @ http://twitter.com/#!/Skype Skype will be down for a Few days or weeks. So anything will not work at the moment just be patient
Dec 16, 2010 | Skype IM
How to find log on a calculator
Since I do not know what Kenko calculator you have I will remain general.
Locate a key marked log (for common decimal logarithm)
Try the two options. One of them is bound to work
  1. Enter a positive number and press the key marked LOG.
  2. If that does not work, press the LOG key and then enter a positive number. If the calculator displayed log( , with a left parenthesis, insert a right parenthesis before pressing the = key.
To calculate the natural logarithms (LN), look for a key marked with LN and proceed as for the common logarithm. I am sure that the syntax (key sequence) that works for the common log will work for th natural log.
If no key is marked on top of it with LOG or LN, it may be because those markings are ON the body of calculator. In that case the functions are accessed by pressing a key marked SHIFT or 2ND, or 2ndF before the function LOG or LN.
Jun 25, 2010 | Casio FX-260 Calculator
Errors
Press the following keys:
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
Wait for the fax machine to reboot.
Oct 21, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
SOMETIMES MY PASSWORD WORKS AND S
Thank you.
It is now 2014.
I have a different computer now
Oct 13, 2008 | AOL Entertainment CD-ROM (P50128U)
Hi my problem is. I hve two computers and I am trying to connect at least one of them wireless. The HP people said I needed to call linksys for the WEP for the router? I have several encrypted keys but...
You need to log into the router. You set the WEP key in the router; Linksys does NOT have access to your WEP key.
If you can log into the router, set the key and copy it down. If you can, use WPA2 encryption (more secure than WEP).
Mar 29, 2008 | Computers & Internet
Can't log in - TouchPad does not work
You you cannot navigate using Touchpad you can use "tab" key. if doesnt work also shut the computer by holding the power button about 5 seconds and restart the computer. If issue persist please post your question with model information of the computer, Operating system etc.
Good Luck
Dec 30, 2007 | Computers & Internet
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
