Question about Radio Communications
I have a discontinued LT2 echo board some called it connex board but connex never made This is a echo board for cb radio I need to install such in a Cobra 29 Ltd classic I need to know exactly where wires on echo board go in radio
    New Friend:
  • 24 Answers
Look on youtube and type in echo board wiring and the video will show you how !!!
Posted on Apr 27, 2014
5 Suggested Answers
Benimur
  • 6966 Answers
SOURCE: Cobra 29 Ltd
Appreciate the direct "Ask Me" again.
The initial posting would still hold true, best would be:
  • remove TR18;
  • replace 2SC2069 with 2SC1969; and
  • adjust L12, 13 & 14.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 08, 2008
Benimur
  • 6966 Answers
SOURCE: scematic
Hi and welcome to FixYa,
Pls click on the schematic diagram for a Cobra 29LTD.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
  • 6 Answers
SOURCE: where to get a free wiring schematics for a cobra 29 ltd classic
www.cbtricks.com
Posted on Apr 07, 2009
  • 773 Answers
SOURCE: cobra 29 ltd classic antenna calibration ??
Wow. That's not at all a solution to what this guy is asking. And why all the caps??
The one point jm77437 has that is correct is that you do not set the radio, you set the antenna. The rest is blah blah.
Here is how you tune your antenna for you radio. First off it depends on what kind of antenna you have. most fiberglass antennas have a tunable tip to adjust the height of the antenna. Metal whips either have a collar at the base that the whip will either slide up or down in to adjust the height. The other type of metal whip's you have to physically clip to shorten the antenna, you must be careful with this type because once its clipped, that's it. You cannot add what you cut off.
I am going to give this example using a metal whip with an adjustable collar.
First after your radio is hooked up in the vehicle, drive to an open lot. Buildings and other structures can cause extra reflection. turn to channel 1. Flip the meter to CAL. Key the mic without talking. Now turn the CAL knob up until the needle reaches the little upside down triangle all the way to the right marked CAL. Now you have just celebrated your radio for your setup to measure you SWR. Now while still holding the key, flip the meter switch to SWR. The needle will move, and where it stops is your SWR reading. The lower the better. Anything under 1.5 is considered really good. But still, the lower the better.
Make note of what your SWR was on ch 1.
Now flip to channel 40. Repeat the SWR process. You must recalabrate each time you take a reading.
Now like jm77437 said. If your SWR reading is higher on 40 then 1, then your antenna is too long, and you must make it shorter. Loosen the collar and lower the antenna in the collar 1/4 inch at a time. check the swr each time you adjust the antenna.
If your SWR reading is higher on channel 1, then your antenna is too short. You must make your antenna longer. Do this by loossening the collar and pulling the antenna upward in the collar 1/4 inch at a time, again checking the swr each time you adjust the antenna.
What you want to achieve is having the same SWR reading on channel 1 and 40. then you have the best match you are going to get with that antenna.
If your swr is under 1.5 on all channels, you don't need to fuss unless you are a perfectionist. then by all means go ahead.
If your reading is higher then 3, or your ant light comes on, something is really wrong. Make sure your antenna is connected all the way, and the coax is not damaged.
Its important to have an appropriate SWR because if you do not, you are reflecting too much signal back into the radio, and eventually you will burn out your final transistor, and your radio will be toast.
Some tips: make sure you check the swr with the doors and windows shut. Make sure you are in an open lot. Remember to calabrate ecah time you take a reading. If you have had your radio peaked by a radio shop, and they have lowered your dead key, or have done a swing modification, then the meter in your radio will not work when taking an SWR reading and you will have to use an external meter.
Posted on Apr 24, 2009
Have connex board in my 29 sound tracker how should I set the board to the radio?
If you must use echo.. please use a dummy load. while adjusting the amount of echo.. you want it to be intelligible to the other listeners.. just barley add the echo effect and it should sound great and not like your in a can or all running together were no one can understand you...
Jan 01, 2016 | Connex Radio Communications
I need a schematic for a LT2 echo board to install in my president grant PC-409AB
break audio line. J2 input goes to mic pin J1output to radio.
(leave the shielded ground wires disconnected. on audio)
Power use a 1k ohm resistor from 12v dc on pwr switch.
Ground run the ground wire to board ground
test and set echo level.
this will work for any radio. if the echo needs 12v instead of 8v remove the 1k resistor and just use a 1n4001 diode on the power wires . some models require 12v some are 5-8volts.
Jan 18, 2015 | Radio Communications
Echo not working all the time
dry joint .... usually its the actual echo level pot control has a bad or dirty wiper they are low quality
Mar 07, 2014 | Connex 3300 240-Channels Base CB Radio
How do we hook up our connex fc390 to our home base cb radio ?our cb is a Galaxy SSB ECHO
The Fc 390 should have come with directions to install it . I'm sure the installation is the same as the Fc347 which CB tricks has the directions for .
Nov 28, 2011 | Connex FC 390 Freq counter for all Cb Ham...
Connex 3300 HP won't change channels when you turn ch. selector stays on same channel ch. 32.
There is a board in the CB called a PCB board. If you open your radio it is a little circuit board. Held onto the side of the radio by a screw and has two or three connectors leading to the board. Replace that little board and your radio will be good as new. I have seen radios come in my shop many times and this is the fix. What that board does is send a signal to the crystals to start mixing a frequency. When it goes out it just sticks where it is at. Here is a link to a place that can take care of you. http://www.hyelectronics.com/default.asp You tell them you need the little PCB board for a Connex 3300 inside the radio. Might be $35 or so.
Mar 14, 2011 | Connex 3300 240-Channels Base CB Radio
I have a galaxy dx 959 I had a connex board put in it sometimes it sounds great then the next time it sounds destoreded or a loud sweel
did they put both the power ground and the audio ground together when they installed it? some echo's can only have the one ground , not both.. either the power wires ground or the coax ground on the audio wires.
also check the swr's..
Feb 19, 2011 | Galaxy Radios DX-959 40-Channels Base CB...
Just bought the connex 3300hp and I need to know how to adjust it
squelch counter clock wise.
volume to comfortable level
rf gain fully clockwise
mic gain fully clockwise.
band should be band d??
adjust echo to decent setting.
RK56 $38.99 NEW
Connex300HP blue led's $198.99 NEW
Astatic 636L $17.99
if you need more help -- call text email us..
Jan 25, 2011 | Connex 3300 240-Channels Base CB Radio
Feed back thru external speaker, very bad
Have your antenna checked at a place that knows what they're doing. If your antenna system is bad, ground problem,coax bad mount or maybe just a wrong or bad antenna. Then the sounds not getting out the antenna and its feeding back thur the radio.If your echo board was bad then your radio wouldn't transmitt at all.
If you unplug your external speaker will it squeal? If not do the antenna and if that reads fine just try a better speaker like a uniden 20watt speaker.I own a CB shop and this is easy to fix.
Jul 10, 2010 | Connex 3300 240-Channels Base CB Radio
Disable talkback
one turn off echo and talkback will turn off. or disconnect the wire goin to the transistor off the echo board that turns on the talkback.
May 31, 2009 | Connex 3300 240-Channels Base CB Radio
Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Feb 10, 2009 | Connex 4600 Base CB Radio
Radio Communications Logo
260 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
