Question about Jandy Ae2500t 115,000 Btu Heat Pump
I want to move the control pad on my jandy ae 2500 about 160 ft., what kind of wire should i use?
  • 78 Answers
You can effectively use wiring designed for alarm systems or telephones.
Posted on Apr 22, 2010
I have a Jandy AE 2000T, serial L07AA0105. When I turn on the power with pool pump running,all I get is "Universal Controller UI FW Rev: 1.7" on the controller screen. No response from cont. button "
The "Rev:1.7" is the software on the board indicating the board has power however you may need to replace the board if you can not boot beyond the firm ware screen.
Oct 28, 2016 | Jandy Pool & Spa
Jandy 8227
make sure 4 pin connector is plugged in and wires arent cut or shorted
May 12, 2013 | Jandy Aqualink Rs4 One Touch Control...
Jandy ae heat pump
make sure wiring is correct for 220 volt or 115 volt and check fuses
Mar 20, 2013 | Jandy AE3000T AE-Ti Heat Pump 137K BTU
Where is the pressure switch on jandy pool water heater AE-TI
open front panel look for a white and copper triangular object with 2 wires connected and a copper tube
Dec 28, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
How do i fix H20 sensor on a jandy pool water heater AE-TI
remove the two black wires from the PCB board and remove the other part from the copper line going to the header where the pipes connect
How do I connect my Jandy AE-TI heat pump to my intermatic T104P3
1) Copy following link for wiring illustration ... assuming timer is supposed to control pool pump:
http://waterheatertimer.org/images/T104-to-contactor.jpg
2) T104P is 240Volt (208-277V) SPDT timer in P plastic outdoor enclosure.
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Jandy AE-TI is 208/230V pool heater.
http://www.bestbuypoolsupply.com/media/aemanual.pdf
4) Page 13 of Jandy manual shows single-phase residential wiring diagram.
5) First of all, power to main contactor is not interruped by timer, since this powers 24Volt transformer that controls the chip board and general operation.
6) The timer is connected to 'Auto-heat contactor.'
The confusion is what Load connects to this contactor? The water pump? Load is shown on diagram as 'pump time clock.'
I assume the load is the PUMP??
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 04, 2012 | Hardware & Accessories
Jandy rs4 indoor control panel lights up but nothing displays
trade controllers if when switched problem moves bad controller if problem stays inside bad wires or plug
Aug 18, 2012 | Jandy Aqualink Rs4 One Touch Control...
Auto shut down function not working (Jandy Aqualink RS6)
Jandy relays are known to stick. You can diagnose this yourself with a screwdriver. Remove the four screws on the outside panel. You will see a series of black rectangular relays and a lot of wires. Typically the pump relay is the one in the upper right. It will certainly be the one plugged into the left hand socket at the bottom of the circuit board.
Be sure to do all of this simply be looking. You can move the twisted red/black wires a bit to determine which relay is plugged into the first socket. Try to notice on the bottom of the relay a small black tab that is sticking out. When out, the relay is on. If the pump is running, this tab is out. If you then put the controller into service mode and the lights go out without the tab popping back in, you have a bad relay. If turning the pump off does not put the pump light out, you have a bad board.
In most cases, the relay is bad and it is a simple fix.
Nov 24, 2008 | Jandy AQUALINK RS TELELINK KIT
Jandy Ae2500t 115,000 Btu Heat Pump Logo
85 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
