Question about Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch
I need to remove the crown from the movement
Ineed to remove the crown from the movement in a sabaqua noma 5040 d to repair the dial?
Braun bn0095 watch battery replace
"For servicing and repairs, the removal of the access screw on the back of the watch gives access to the stem release catch; after removal of the crown and stem, pressurised air is inserted to blow-out the crystal. Thereafter, the entire movement, together with the dial and hands are easily removed from the top. Experienced watchmakers with the necessary equipment should only perform this operation and the removal of the access-screw by any other persons without the required expertise is highly discouraged."
Mar 26, 2013 | Braun Watches
Watch ******** my invicta 5511 has snapped how do i get a new one
you can find what you need at Invicta Web-site http://invictawatch.com I had order straps from them for my Sabaqua NOMA III and russan diver here is also the link for the service http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Nov 16, 2012 | Invicta Subaqua Noma Iii S
I pulled the entire crown and stem out of my Rolex President. What is involved in fixing it?
The repair for this problem may be quick and inexpensive--or somewhat more expensive. Either way, it's considered a minor repair.
The crown and stem assembly in held in a Rolex movement by a small pressure screw. When this screw is loosened, the stem can be cleanly pulled out of the movement without damaging any parts. The movement can then be removed from its case. If the screw is too loose, it is sometimes possible to pull the crown and stem out with ordinary effort. The simple fix for this would be to have a watchmaker take the back off your Rolex (requires a special wrench) and slide the stem back into the watch while loosening and re-tightening the screw. If that's it, the repair takes about 5 minutes, most of which is spent removing and replacing the watch back.
Things can get more complicated. The set stem interacts with a thin sheet metal spring / detent that helps the stem "snap" to its various set and wind positions. Sometimes, when a stem gets pulled out, the force of that can snap the delicate little finger in this watch part. Replacing this watch part will require that the movement be removed from the case and the hands and dial be removed for access to the part. Once you get to it, the part itself can easily be replaced--it's designed to be replaced without disassembling the whole watch movement--but there's considerably more effort involved than just sliding the stem back in and tightening down the screw.
May 08, 2011 | Watches
Hi i just got an invicta subaqua noma 3 and noticed that the lever that goes over the crown is loose. How do i tighten this or should i just return it?
I have had the same problem with one of my SANIIIs, As you have probably figured out, there are two small screws that are part of this assembly, lower one is the pivot point, upper is the latch. There are also very small rubber bushings (upper & lower) in the pivot of the crown protector, if they are worn it will present side to side movement or "slop" they need to be replaced in this case (I Just went through this on an older Valjoux 7750 SANIII - same problem, latch would not stay closed), you can order the part from Invicta or take from a donor watch in the mean time (Invicta will take several weeks to months to fulfill a part order) The upper screw goes through a small cylinder or cam, there is a little (very little - but it is there) to move that cylinder outward towards the upper pusher or top of the watch. After you loosen the top screw (loose not remove) you can adjust this play w/two precision screwdrivers, one to tighten the upper screw one to lever the cylinder toward the top of the case by leaning one screwdriver w/ just a slight pressure against the crown and the cylinder to widen the area between the pivot screw and the latch cylinder. Don't overtighten the screws to try to add friction to the assy - the threads & heads are fragile, you can damage the case or strip them - or worse snap the head off. Hope that helps.
Dec 18, 2010 | Invicta Subaqua Noma Iii S
Zero in second hand
Easier than you think.Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Aug 29, 2010 | Invicta Subaqua Noma Iii S
I have a diesel watch model dz-2136 I need to know how to remove stem
Thank you for contacting FixYa.
I dont know why you want to remove the stem but here you go.
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder. Now you can remove the stem as described above
Aug 26, 2010 | Diesel Audio Diesel Watch
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
Apr 04, 2010 | Watches
The second hand on my invicta chronograph watch doesn't reset to zero
Dec 26, 2009 | Invicta Subaqua Noma Iii S
How to replace crown to Raymond weil 9124-2
If i were you , i'd contact directly the brand on their Official Website. This is best done by watchmaking specialists :
RAYMOND WEIL Swiss Watches
Mar 12, 2009 | Raymond Weil Automatic Watch
Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch Logo
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
