Question about Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch
Ineed to remove the crown from the movement in a sabaqua noma 5040 d
Watch ******** my invicta 5511 has snapped how do i get a new one
you can find what you need at Invicta Web-site http://invictawatch.com I had order straps from them for my Sabaqua NOMA III and russan diver here is also the link for the service http://www.invictawatch.com/support_files/service_center/ServiceCenter.htm
Nov 16, 2012 | Invicta Subaqua Noma Iii S
Hi i just got an invicta subaqua noma 3 and noticed that the lever that goes over the crown is loose. How do i tighten this or should i just return it?
I have had the same problem with one of my SANIIIs, As you have probably figured out, there are two small screws that are part of this assembly, lower one is the pivot point, upper is the latch. There are also very small rubber bushings (upper & lower) in the pivot of the crown protector, if they are worn it will present side to side movement or "slop" they need to be replaced in this case (I Just went through this on an older Valjoux 7750 SANIII - same problem, latch would not stay closed), you can order the part from Invicta or take from a donor watch in the mean time (Invicta will take several weeks to months to fulfill a part order) The upper screw goes through a small cylinder or cam, there is a little (very little - but it is there) to move that cylinder outward towards the upper pusher or top of the watch. After you loosen the top screw (loose not remove) you can adjust this play w/two precision screwdrivers, one to tighten the upper screw one to lever the cylinder toward the top of the case by leaning one screwdriver w/ just a slight pressure against the crown and the cylinder to widen the area between the pivot screw and the latch cylinder. Don't overtighten the screws to try to add friction to the assy - the threads & heads are fragile, you can damage the case or strip them - or worse snap the head off. Hope that helps.
Dec 18, 2010 | Invicta Subaqua Noma Iii S
What powers my subaqua noma iii gmt limited edition model # foo27
It has an automatic movement powered by the movement of your arm.
Nov 07, 2010 | Invicta Subaqua Noma Iii S
Just bough a Subaqua Noma III Chronograph Watch and the Day of the week...where it says mon tues etc...changes at 3 am instead of at midnight. how can i fix this
you cannot fix this. Unfortunately for movements to be that exact they cost a lot of money and the movement inside your subaqua is not that high tech and accurate. This is what makes watch really expensive the little things like this. Unless you are buying a 10k watch , they usually are not going to have the top of the line movement . The movement you have in your watch is an ISA 8173 and that is as accurate as the watch will get.
Oct 19, 2010 | Invicta Subaqua Noma Iii S
How do you pull the crown out on and invicta watch
mcdevito75 here, Your invicta may have a screw down crown that adds water proof protection to your watch, try to un-=screw the crown when un- screwed then pull up to set time.
Jun 26, 2010 | Invicta Subaqua Noma Iii S
How do i set the day of the week on my Invicta subaqua noma 6125?
For Invicta chronographs to set the day you need to pull the crown out to position 3 (2nd click after releasing the crown/ furthest crown position/ same position to adjust time). You can only set the day by rotating the crown clockwise. Every 24 hours of clockwise rotation will move the day indicator forward 1 position (Mon>Tue, Tue>Wed, etc). If your watch is set one day ahead of the correct day (Its Tuesday but the watch displays Wednesday for example) you will need to rotate the crown clockwise through the entire remainder of the week in order to get to the correct day, you CANNOT rotate the crown counter-clockwise in order to move the indicator back a day.
May 21, 2010 | Invicta Subaqua Noma Iii Chronograph men...
How do I remove the crown/stem to take the watch movement out of the case? thanks Marc
To remove the stem you must first loosen the set lever screw, then you can pull the stem out.
You only need to turn the set lever screw a couple turns to release the stem. Some movements use a button instead and in that case you would simply push the button down lightly with a pointed tool and while holding the button down pull the stem out.
For watches with one-piece cases where the movement comes out the dial side and the case has no removable back, you will not be able to get at the set lever screw. For this type of watch you must grasp the crown firmly and pull it out, or use plastic or soft brass tweezers to get behind the crown and pop it off. These watches have two-piece stems that have male and female ends that snap together. Then remove the bezel and let the movement come out into your hands. Then remove the hands and the dial and put the movement face down into a movement holder.
Apr 04, 2010 | Watches
The second hand on my invicta chronograph watch doesn't reset to zero
Easier than you think.
Pull your Crown out to the FIRST stop (were you would normally set your date). Push the "A" button (top chrono button) for your dial at the "3 oclock" area, Push the "B" button(bottom chron button) for the second hand.
Dec 26, 2009 | Invicta Subaqua Noma Iii S
Find watch numbers, seamaster automatic
I hope you have Omega Dynamic?!
If yes, then the crown can be removed by appling slight pressure against the watch. The stem inside the watch is made of 2 pieces and the crown can be pulled out. But be careful, there are chances that the stem may break :-)
Sep 07, 2009 | Omega Constallation 1272.70 Wrist Watch
Removing the crown/stem of CASIO EF-321
Other case for a simple Casio quartz watch :
Jan 15, 2009 | Casio Edifice EF106D2AV Wrist Watch
Tag Heuer 2000 Classic WK1113.BA0311 Wrist Watch Logo
16 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
