Question about Adobe Photoshop Elements 6: Windows
I have a dell with Vista. Photo Shop 6.0 Editor will not open, get a message that Photo Shop Editor is not responding.
  • 256 Answers
Find the Photo shop 6 program on your computer and RIGHT click on it. Choose properties. In the next window, click the "Compatability" tab. In theis window, CHECK "Run this program in compatability mode for:" and choose one of the operating systems from the drop down choices below. If this does not work, you may have to upgrade Photo Shop.
Posted on Jun 14, 2009
How do i enlarge photos/images?
In a photo editor like photo shop. Be aware even after enlarging a photo, it will not have more info. Small pictures have little info, and will be blurred when enlarged.
Mar 08, 2015 | Huawei Cell Phones
Hi I am unable to use itunes on my computer. I installed and its asking to turn off the compatibity mode. And also I cannot view summary, photo etc tab on my iphone device.
Hi
First of all
1. Exit out of iTunes.
2. On the Windows Start Menu select Computer or My Computer Depending on the OS
3. Browse to the following location: C:\Program Files\iTunes.
Note: Windows 7 (64 bit)browse to C:\Program Files (x86)\iTunes.
4.Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
5. Next select the Compatibility tab.
6.
Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
This should fix your problem.Still if your facing the same problem after performing the following steps:-
7. Open the Registry Editor by selecting the Windows Start button, typing regedit into the search box or the run box depending which OS your using eg- xp,vista,7 and then pressing Enter.
8.
Browse to the following location in the registry editor, HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers, and highlight the Layers folder.
9. Delete the entry for the iTunes application (iTunes or iTunes.exe).
10. Close registry editor and restart the computer
You should now be able to open iTunes without receiving the error message about iTunes running in compatibility mode.If not please reply
Thanks & Regards
LOnG LIvE tHe GeeKs!!!!!
Dec 09, 2010 | Computers & Internet
I have a Dell VOSTRO 1700 running VISTA, purchased March 2008 (out of warranty). I used the Toshiba DVD Drive only a few times. Since Oct 2009, the laptop unit (softwarewise) does not ''see'' the Drive....
This is becoming a common problem. Let's see if we can save you $150!!
If your CD-ROM or DVD-ROM Drive Appears To Be Missing then you will need to manually edit your registry.
Follow the instruction below.
Click Start Menu. In the Search box, type regedit, and then click OK. A Registry Editor window will open up.
1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step.
Step 3: Delete the LowerFilters registry entry
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak.
7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
8. Exit Registry Editor.
Step 4: Restart the computer.
This should resolve the problem and there is no easy fix unless you factory restore or reinstall the operating system.
Good luck and please let me know if there is anymore advice that you need.
Jul 20, 2010 | Dell Vostro 1700 Notebook
I'm running Corel Photo-Paint 12 on my Toshiba laptop, AMD Turion-X2, 64-bit machine running Vista Home Premium. I didn't have this problem until recently, and it's only with Photo-Paint, not CorelDraw:...
I had some troubles with some software on Vista Ultimate  one of the problems was Corel Photo Paint   i went back to Adobe Photo Shop  it installed well and works well
Nov 05, 2009 | Computers & Internet
Trying to use PrimeFilm 1800U scanner on my Dell PC (with Vista), but when running supplied Presto ImageFolio (Mr. Photo) CD, the following message appears: 'String MSG_OS was not found in string table'....
Uninstall Presto Mr Photo, image folio & Cyberview, all of which are not Vista compatible. Obtain new scanner drivers from http://www.scanace.com/en/download.php. Also, can use any image editor once scanning complete. Google provide free application called Picasa at www.picasa.google.com.
Sep 09, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
Dell photo Editor
I updated my Driver. Thank You
Jan 29, 2009 | Dell Office Equipment & Supplies
Downloading photos from Canon 400D direct to Canons photo editing programmes on new windows Vista computer.
There are two ways to solve this problem. I am assuming you are simply clicking on the pictures and choosing "edit" or double clicking on the pictures and they are opening in "Vista picture editing"
The first way to overcome this is by opening the desired program first (in this case canon's photo editor) and then choose open and find the desired photos.
The other way is to set the file type association in vista so that RAW programs open with the canon program see below for step by step:
1. Click Start
2. Click default programs on the black bar
3. Click Associate a file type or protocol with a program
4. Find the file types you want to open automatically in your canon editing program (RAW .jpg etc)
5. Click once at the top of the page click change program
6. A new window will open, if it does not list the correct program click browse at the bottom of the window and find your editor in it's folder.
7. Select the desired program by double clicking
8. Click OK
9. Click close
10. Test the new file association by double clicking a RAW file or one of the other file types and see if it loads into the correct program.
The final (and this is simply my plug for open source programs) solution would be to try something like GIMP (it is a photo editing suite developed under linux but adapted for windows) you can search for it on google.
If you are having trouble with any of these steps please post a comment and I will try and add some clarification.
Hope this helps
May 01, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Winmail to Outlook express 6
Outlook Express does not display any message attachments if TNEF-encoded file (winmail.dat) was received. If you are expecting some attachment, but do not see any, it still can be there.
To decode such a message perform the following steps:
  1. Save the whole e-mail message to an *.EML file via File, Save As, or Drag-and-drop.
  2. Open the *.EML file in a text editor such as Wordpad or Notepad.
  3. Locate the line Content-Type: application/ms-tnef;, and change the Content subtype to something else, such as Content-Type: application/zzz;
  4. Locate the line name="winmail.dat" and change to name="winmail.tnf". You may change the winmail part as well, if desired.
  5. Save the *.EML file from the text editor.
  6. Double click the *.EML file from the Windows File Explorer. This will open the message in a mail window and the TNEF attachment should now be available for saving.
  7. Drag the saved attachment into the Winmail Opener program. Decoded attachments will then be there and can be dragged or opened.
Dec 07, 2007 | Microsoft Office Outlook 2003 for PC
Adobe Photoshop Elements 6: Windows Logo
177 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
