Question about GE Advantium 120 Convection/Microwave Oven
Advantium 120 won't heat food with microwave
I've checked the 3 door switches and they checkout good with door open and closed. I've checked 3 cut off switches (not sure if there are more) and they all pass current. I've checked the one by the Magnatron, one on the left side, and one on top. 120v at the transformer is also good. Not really sure where to go from this point. Are all three TCOs suppose to read close ( no resistance)?
  • 1 more comment
  • Matt W
    Matt W Mar 21, 2014
    Model SCB1001MSS
  • Matt W
    Matt W Mar 21, 2014
    Unit works normally including the convection side heating.
  • Matt W
    Matt W Mar 21, 2014
    I'm leaning more towards HVC, transformer, or magnatron.
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 blew breaker when door was closed. I reset breaker and it worked for three weeks. Breaker is blown again...when i open the door and reset breaker it works, but as soon as you close the door...
I'd suspect the interlock monitor switch is stuck, or its mounting bracket is out of adjustment. This is designed to blow the fuse if you try to run the oven while the door is open. The switch is supposed to open when you close the door. This switch is replaceable, but you should have this oven repaired by a professional. There are lethal voltages present with the cover off, and the possibility of microwave leakage is the repairs aren't done correctly.
Mar 20, 2010 | GE Advantium SCA1001SS Convection /...
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
Microwave not heating every time...
You seem to be having a problem with the interlock device. when you close the microwave door it is supposed to hit a series of 3 switches to tell the microwave every thing is safe and able to run. you may want to take the control panel off and make sure those switches are ok. usually out of the 3 switches top and bottom should be open middle should be closed. you could check with the continuity side of your electric meter.
Let me know if you have any questions before rating me.
Nov 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium 120 problem
dis connect from power alow to reset for about a minute . if not there are switches behind the door probably not making good contact make sure door is closed tightly
Jul 30, 2007 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
