Question about HP LaserJet Office Equipment & Supplies
HP LaserJet Pro CM1415fnw stuck in calibration mode, won't print
Printer calibrating over and over, won't print, even though documents are in print queue. very odd
    Novelist:
  • HP Expert
  • 175 Answers
There's a few reasons why your printer is doing this - I would recommend the following action:
1 disconnect the printer from your PC ( USB/Net)
2 power off the printer
3 open the top/ front and pull out the process section( where you put your toners)
4 individually remove and then reseat these toner cartridges
close the covers back up and power on ( still disconnected from the PC)
5 allow the printer to come to ready ( if it wont come to ready there may be a problem with one or more of the toner cartridges)
6 print an internal testpage ( press menu , select information, select configuration, select print)
7 whent his prints you know your printer is going to be ok, On your PC-clear ALL the print queue- reconnect to printer and test!
Posted on Mar 21, 2014
HP LaserJetM551
Turn printer off and unplug any network or usb cables. Restart printer, if it comes to ready then you may only need to update the firmware on the printer to solve your problem. Go to HP.com and download the current firmware for the 551 and copy it to a USB stick. In the menus on the printer go to Printer maintenance>upgrade firmware and then insert the usb key into the usb slot on top of printer. Screen will show the file that is on the usb key, press ok and wait for process to finish.
Aug 11, 2014 | HP LaserJet M551 M551N Laser Printer - C
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Colours not calibrating
Hi Selorm,
i suggest you Go Visit Colours not calibrating Solution Video
OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : HP Printer Support
Feb 11, 2014 | HP Laserjet Pro Cp1525n Color Printer...
Hp laserjet 3600 printer Won't stop calibrating, i try to change toner,reset dafault settings,still calibrating,i canot stop calibration,can u pl sent gud solution. Thanking U shiju
Its a particular problem with this printer, it needs a firmware update.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=501044&swItem=lj-44336-1&prodNameId=501046&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=1
May 29, 2011 | HP LaserJet 3600n Printer
HP colour laserjet 1600: I turn on printer and it switches from initialising to calibrating withour printing documents
Does the printer ever come to ready? If not, have you recently changed any of the toner cartridges? We have had cases with generic or refilled toners that will cause the printer to not be able to calibrate.
Apr 11, 2011 | HP LaserJet 1600 Printer
Alignment of HP L 7780 failed. What are the steps to correct?
hello, you will need to run a cleaning cycle, you are looking for black printing, if not printing well, it might fail, if it does you will need #88 printhead. the black/yellow one. most times you will not need calibration to print, unless machine is stuck in that mode and won't pass. and won;t allow for print.
Oct 25, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Can't stop the printer calibrating
No guarantee this will fix your problem, but the last time I experienced this problem it ended up being one of the toner cartridges. I replace her refurb. toners to OEM brand.
Jun 02, 2009 | HP LaserJet 4600dn Color Printer
Very Light Printer on HP Color LaserJet 3500
Table 7-33. Causes for distortion or blurring
Cause Solution
Transfer unit is defective. Replace the transfer unit. Calibrate the printer
after replacing the transfer unit. See Calibrate
Now, later in this chapter.
Defective secondary transfer roller If it does not rotate smoothly or it is deformed,
replace the secondary transfer roller.
DC controller PCB is defective. Replace the DC controller PCB. Calibrate the
printer after replacing the DC controller. See
Calibrate Now, later in this chapter.
Calibrate Now
Use the following procedure to calibrate the printer whenever you replace the DC controller,
the formatter, the color misregistration sensor (PS12), the transfer unit, or the laser/scanner.
1. Press to enter the MENUS.
2. Press to highlight configure device.
3. Press to select configure device.
4. Press to highlight PRINT quality.
5. Press to select PRINT quality.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
hope this helps
pdouglasss
Dec 17, 2008 | HP Color LaserJet 3500 Printer
I changed the trasfer kit on my HP Color LaserJet 3500 and now the print is very light. I used and OEM transfer kit and followed the instructions provided by HP. Help
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer.
1. Press MENU to enter the MENUS.
2. Press to highlight CONFIGURE DEVICE.
3. Press to select CONFIGURE DEVICE.
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
Hope this works for you
pdouglasss
My HP laser jet 3500 color printer documents look horrible
Hi marsha_smith:
Run this program and let me know if this work for you ok.
pdouglasss
Calibrate Now
Dec 03, 2008 | HP Color LaserJet 3500 Printer
282 people viewed this question
Seeker5211
Seeker5211
