Question about Onkyo TXSR508 Receiver
Remote can't shut off receiver once the game button is selected.
When the receiver is switched from cab/sat to game and then want to shut off the receiver you are not able to shut off from the remote. Only from the on/off on the receiver.
Dish remote stays in vcr mode
Hi, Cheri Torres with DISH Network Customer Service here. I would be happy to help with any remote issues you're experiencing. Normally if the remote is stuck on VCR mode you would need to try replacing the batteries first. Once you have replaced the batteries you are going to want to press and hold down the SAT button until it lights up red and flashes after you release. This should put your remote back in SAT mode. If this does not resolve your issue you may need to readdressing the remote to the receiver. I will list the instruction here for you to do so. I hope you find this information useful and if you have any further questions please let me know!
Instructions for addressing the remote to the receiver
  1. Go to System Info screen.You can do this by either pressing the system info button on the front of the receiver or by pressing the power button once and the channel up button once on the front of the receiver.
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Sep 28, 2011 | DISH Network 721 DVR Remote Control
DIDN'T TAKE THE SELECT BOTTON TO WATCH TV AN MY 2ND TV.
Hi, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. The first troubleshooting step you are going to want to try is making sure the remote is in SAT mode you can insure this by pressing the SAT button once the remote. If the remote is in SAT mode and still not functioning properly you may want to try replacing the batteries if you already have not. If both options do not work for you then you are going to need to try readdressing the remote to your DISH receiver box. I will list here for you the instructions on readdressing your TV2 remote. I hope you find this information useful and if you have any further questions or concerns feel free to email me at Cheri.Torres@Dishnetwork.com.
Instructions for addressing remote to DISH receiver
  1. First you will want to take your TV2 remote to your TV1 location where the DISH receiver box is.
  2. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver or pressing the menu button twice on the TV1 remote.
  3. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  4. Hold down the SAT button until all mode lights light up.
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number in the little white square to something different than what is already listed for secondary remote address.
  6. Press the pound (#) button.
  7. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 5 will appear in the System Info screen under Remote Address.
Mar 09, 2011 | DISH Network IR Remote Control
I just had my cable hooked up after i moved and my remote will not let me press select to watch cable even though everything else works on the remote.
Hey there, Cheri Torres with DISH Network Customer Service. I came across your post and wanted to see if I could help. It sounds like you may need to readdress remote to your DISH receiver box. Make sure that your remote is in SAT mode by pressing the SAT button once so that it lights up red. Once you have done this you will need to take your remote to the TV1 location in order to readdress it to the receiver if you are not already there. I will list here for you the instructions on readdressing the remote after this post. I hope you find this information useful and if it does not fix the issue please email me at Cheri.Torres@Dishnetwork.com and I will be happy to see what else we will need to do in order to fix this issue.
Instructions for addressing your remote to your DISH Receiver box
  1. Go to System Info screen. You can do this by pressing the system info button on the front of the receiver box or by pressing the power button once and the channel up button once on the front of the receiver box.
  2. Once you are in the system info screen you will see remote address or primary remote address(TV1) and secondary remote address(TV2).
  3. Hold down the SAT button until all mode lights light up.
  4. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number to something different then what is already listed in the little white square.
  5. Press the pound (#) button
  6. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 4 will appear in the System Info screen under Remote Address.
Feb 21, 2011 | DISH Network 721 DVR Remote Control
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
I lost the manual I need instructions to program it
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thank You
Sep 12, 2010 | Hitachi VT-RM294A Remote Control
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
Hi.
Manual Programming:
Thanx
Jul 29, 2010 | Hitachi CLU-5713TSI Remote Control
My tv remote will not allow me to access the satellite
walk_alan,
Are you still having problems with your DISH Network remote? Which light on the remote lights up when you press the select button? If any button besides the SAT button, the remote is not in SAT MODE. Pressing and releasing the SAT button will put the remote in SAT MODE.
If the remote is in SAT MODE and doesn't operate the receive, then the remote may need to be readdressed to the receiver or the remote may need to be replaced. Do you have fresh batteries in the remote? If so, I have provided steps on readdressing the remote to the receiver.
Remote: All Other Remotes
  1. Go to System Info screen(depending on the receiver, you can press the "System Info" button, or pull the smart card out from the receiver till the "System Info" screen appears on the TV)
  5. Once the SAT button blinks three times, press record. Note: If successful the number selected in step 3 will appear in the System Info screen under Remote Address.
I hope this helps.
Ray Calo
DISH Network - Executive Offices
Jun 20, 2010 | DISH Network 135899 Remote Control
My dish network remote stop working
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux mode. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with! -Kirstie DISH Network
Mar 11, 2010 | DISH Network IR Remote Control
On our Dish 500 we get strong signals on both 110 and 119 but cannot lock on 119.
Hi jmhunsinger! I will be glad to assist you in your concern. 1st let press the reset button on the front panel of the receiver for 10secs, then once its reset, you will see attention 015 this will go on a progress, then press the menu button on the remote, that is on the upper left, then you will see the main menu. once you see the main menu, press 6,1,1 on the remote and it will go to pointdish, once you see point dish, select check switch on the upper right, then it will go to install summary, on the install summary, you will see installed device, input1-110-all, input2-110-all, on the butom you will see test, select test to perform switch test, let the test finish once its done it will be back to install summary, you should see input 1-119, input2-110 and both should be all or odd-even, select cancel, then it will go to pointdish, you will see on the sat field it could be 119 or 110 and under the signal meter you will see there lock echostar, it could be 119 or 110 west, no problem if one of them will show.119 west or 110 west, then selct cancel, then press 0, 3 times on the remote then it will go to attention 015, let the progress finish until it download the programming guide, if you got the tv show, and can change the channels of the program, lets check your sat if both of them is green, press on the remote the menu button and once the mainmenu is up, press on the remote 6, 1, 3 then it will go th the sysinfo, on the field g, you should see there 119-green, 110-green, if there are two green your good to go, but if there is only 1 sat, press cancel then select on the option updates, once your on the updates screen, you should select on with out my permission, then select save, and cancel all the way out, then it will show a tv pic..turn off the receiver by pressing the power button on the remote, then once the power is off, green light on the receiver if off and the tv will show a snowy or black screen, but in a few seconds it should show attention 061, downloading vital program information, this process will update the software of your receiver, let the process finish, dont do anything just sit and relax and wait until it finish, once its done the wtv will be on a black or snowy screen and the message will disappear. press and hold the power button on the receiver for 10secs then it will pop attention 015 let the progress finish until it download the programming guide, once you got a tv show, press again the menu button on the remote and press 6,1,3 on the remote to check sysinfo and check field g if sat 119-green, 110-green. granting still 1 sat and its green, select cancel, select point dish, check switch and test, let it finish once its finish, it should show 2 sat, 119, 110. then cancel all the way out and it go on the process again and wait untill all the process finish. granting you did check on the sysinfo again and still show only 1 sat. if you have other solo receiver, try to hook up the other receiver to the room were your having a problem, run the check and test the switch on the pointdish. lets say that the other receiver got two sat-119 and 110, mean that the 1st receiver that you working at have a problem and it needs to be replace but if the 2nd receiver that you hook up and it shows the same problem, call on 1-800-333-3474 and ask for service tech, there is a problem with your dish 500.
note: replacing the receiver and asking for a tech- you need to call the same number-1-800-333-3474
if you have any query,pls feel free to get in touch
Sep 19, 2009 | DISH Network 301 DTV Receiver
TV or control doesn't work need help know
ok my tv is doing the same thing and i need help if you found a solution please email me at pieces41096@aol.com
Jul 06, 2009 | DISH Network 322 DTV Receiver
Open Questions:
See all Onkyo TXSR508 Receiver Questions
Onkyo TXSR508 Receiver Logo
14 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
