Question about Maytag MSD2434GE Side by Side Refrigerator
Broken freezer drawer
The front clear plastic part of the freezer basket broke and will not stay on so now items fall out
    Champion:
  • 203 Answers
You can get a new one from a company called e spares on the internet
Posted on Mar 21, 2014
3 Suggested Answers
  • 1073 Answers
SOURCE: broken rear stationmary support on mat/cheese drawer
yep, order part number 61005337 and part 67764-1 about 2 bucks each and it will fix ya
Posted on Apr 23, 2008
richroth
  • 9472 Answers
SOURCE: my maytag mff2558vem4 is leaking water below the freezer drawer?
You need to check the drain line for blockage.
Posted on Nov 27, 2012
How do you remove the clear plastic cover on the crisper drawer of a Samsung Refrigerator Model RF4287HARS
Yes, the clear plastic front of the crisper drawer can be removed for cleaning. Using a thin-bladed, flat-head screwdriver, pry out at the clear plastic slot at the top outside of the drawer, where the clear front piece meets the tab of the white handle piece. Pry out just enough to get the blade under the slot, and then pry inward at the white tab to release the clear front piece at the top of the drawer. Repeat this procedure on the opposite side, so that the plastic front piece is free at the top of the drawer. Next, turn the drawer over on a counter and work the blade of th screwdriver under the tabs at the bottom of the front plastic piece. These should release easily. Notice the bottom edge has three slots and two sections that are interleaved with the bottom of the drawer. Once you have all three pieces separated, the while u-shaped handle piece, the plastic front panel, and the drawer itself, you can clean and dry them easily. To reassemble, first snap the while handle into place on the drawer, by lining up the top of the drawer to the while handle part first. The top of the handle fits over two plastic extensions on th top of the drawer, then swings down to cover the front sides of the drawer. Then reattach the bottom of the front plastic panel to the bottom of the drawer, interleaving the overlapping parts and snapping the tabs in place. Then snap the top of the front panel over the white handle at the top of the drawer, and you are done!
Dec 04, 2014 | Samsung Refrigerators
How do i fix a lower freezer door
Further inspect the drawer components for broken plastic pieces
Jul 23, 2014 | LG LFD25860
How do i remove the plastic basket from the freezer?
Hi Nick,
if you slide the drawer all the way out, you can lift the front of the basket first and slide it out, sometimes they have a screw on the sides.
hope this helps.
May 22, 2014 | Whirlpool GZ25FSRXYY
Our two lower slide-in baskets will not stay on track. Even when the load has been reduced, the baskets fall off the track. I have tried to bend the sides to better reach the track, but it doesn't work. ...
No, very rarely internal shelves can be moved between generations. Unfortunately all you can do is an improvisation to keep them in place: you need to make the channel walls higher by gluing some small pieces of thick plastic on them using a powerful adhesive - not superglue, something like Loctite Sumo Glue.
Sep 10, 2010 | Kenmore Freezers
Frezzer basket handle broke
I boughta new handles
Dec 30, 2009 | Fisher Freezers
Freezer drawer closes on right but gaps on left side for Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator, frosting contents. No contents blocking. Can manually hold left side closed, but wont...
I had this problem with my Kenmore bottom freezer drawer also. I found that the problem was I had too much weight at the very front of the drawer. Try reorganizing and moving items, especially heavier items away from the very front. Worked for me.
Jul 10, 2009 | Kenmore 73503 Stainless Steel Bottom...
Freezer Baskets fall off Guides
I have the same freezer and have the same problem with the baskets. I hope they come up with a solution because my baskets are inoperable right now...
Apr 27, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire front loader washer
one of the welds on your inner stainless steal tub may have broke causing the drop of your tub.  The tub has a warranty on it but the labor to put it in is around 3hrs give or take any hour.
Oct 23, 2007 | Frigidaire GLTR1670A Front Load Washer
Maytag MSD2434GE Side by Side Refrigerator Logo
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
