Question about ZTE Warp
Unlock My phone got locked out (my son) and nothing is working i even changed password and used the code for emer and nothing help please
My son locked everything on my motorola razrv3c and doesn't know the code. I need to get it unlocked
If you or your son did not establish a password/lockcode, then try using 0000. This is often the default code set up in phones.
Oct 11, 2009 | Motorola Mobility RAZR V3c Cellular Phone
How do i set password to access my phone (V9)?? I want to set a password on my phone so that no one else could just open it and start fiddling with my personal stuff. I can easilydo that on a nokia but i...
usually your able to go into the menu and the either options or settings and click on security! but some phones are so dang complicated. lol here is what ive found its a razr 2 v9 right?its from the motorola website
codes & passwords
Your phone’s four-digit unlock code is originally set to
1234. The six-digit security code is originally set to
000000. If your service provider didn’t change these
codes, you should change them:
Find it: s >wSettings > Security > New Passwords
You can also change your SIM PIN or call barring
passwords.
If you forget your unlock code: At the Enter Unlock Code
prompt, try entering 1234 or the last four digits of your
phone number. If that doesn’t work, press s and
enter your six-digit security code instead.
If you forget other codes: If you forget your security
code, SIM PIN code, PIN2 code, or call barring
password, contact your service provider.
lock & unlock phone
You can lock your phone to keep others from using it.
To lock or unlock your phone, you need the four-digit
unlock code.
To manually lock your phone: Presss>
wSettings > Security > Phone Lock > Lock Now, then enter
your four-digit unlock code.
To automatically lock your phone whenever you
turn it off: Presss>wSettings > Security > Phone Lock >
Automatic Lock > On, then enter your four-digit unlock
code.
Oct 02, 2009 | Cell Phones
ASUS P527 will not open when password is entered
Sir, every phone has 2 codes. Lock and Security. Your son must have given onr of then. Then enter the other one to unlock. Both's default is in the manual. Please check it.
Sep 07, 2009 | ASUS P527 Smartphone
FORMAT CODE FOR MOTOROLA L6
my motorola l6 is keep on restarting when ever i press a key so i thought it might get better to reformat my phone so i need the format code for it.
Mar 23, 2009 | Motorola Mobility L6 Cellular Phone
How to unlock moblie phone?
remove your battory insert it in a glass of water for few minutes and then hear comes magic .i also used this trick its working
Dec 31, 2008 | Cell Phones
Phone and sim locked
you can unlock your phone (ie allow it to accept SIM cards from any network) using the ''full reset'' code - *2767*3855#.
Hope this helps
Mar 03, 2008 | Samsung SGH-D900 Cellular Phone
Subsidy password
A subsidy password is an unlock code. Phones are usually locked to the original carrier and a subsidy password must be entered to use a different carriers SIM card. Its safest to obtain this from the original carrier. There are a lot of websites out there that can help you inlock the phone as well. Just be careful. If the wrong unlock code or subsidy password is entered too many times the phone will be locked to the original carrier permanently.
Jan 12, 2008 | Motorola Mobility W375 Cellular Phone
ZTE Warp Logo
29 people viewed this question
Top ZTE Cell Phones Experts
Audrey Messer
Audrey Messer
john smith
Nyte_Ryder
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
