Question about Panasonic VIERA TX-37LZD800 37 in. HD-Ready LCD TV
TV won't stay on. I changed the lamp and now it is acting up
I changed the lamp and reset the timer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 28 Answers
If it is a LCD what lamp did you change.How old is the TV, probably the Ballast, but this is a panel TV
Posted on May 25, 2014
2 Suggested Answers
SOURCE: projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Posted on Oct 02, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
How to reset the hour meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset
Your lamp will probably last a lot longer than the TV thinks it should. This procedure will reset the lamp timer so you don't have to look at that annoying message every time you turn your tv on. Remember that the "lamp" indicator light on the lower left of the set will stay on until the lamp is actually replaced. I had to buy a replacement lamp to get this information, could not find it anywhere for these model numbers.
Press the volume down button on the projection display and hold down the zero button on the remote control at the same time for more than 5 seconds. When the reset procedure is complete, a message will display that the lamp timer was reset to zero.
This procedure will work for Panasonic models: PT-52LCX66 , PT-56LCX66 , PT-61LCX66 , PT-52LCX16 , PT-56LCX16 , PT-61LCX16
Jul 20, 2014 | Panasonic PT-52LCX16
How to reset the lamp meter on a panasonic pt-52lcx16
Jul 20, 2014 | Panasonic Pt-52lcx16-b Replacement Rear...
How to reset the meter on a panasonic pt-52lcx16
Panasonic Projection TV Lamp Timer Reset r
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Every 15 min or so my tv shuts off and a over temp light starts falshing on the front of my tv and the bulb has just been changed in january.
    Hello!
    Looks, like one of your temperature sensors has been damaged. May be due to severe overheating by old lamp. Or: the lamp could be improperly installed. Heats up, then connections to ballast fail, lamp quit working. Next possible cause: did you clean air filter? Vacuumed or blow fans with compressed air? Another possibility: If there was not a significant dust accumulation inside of lamp compartment, the ballast board itself can be at fault. In any case, unit might behave the way it does now. Also: have you reset the lamp timer? In projectors, they won't just give you annoying message via "on screen display". It might think, that you never replaced the lamp, just took it out and put back in. You must reset the lamp timer first. The procedure could be in owner's manual or come with OEM replacement lamp. Generics or "bare" lamps might lack that note. Panasonic wants to stay in a business!
    Good luck with your project,
    thanks,
    Alex.
    Jun 13, 2010 | Panasonic PT-D5600U DLP Projector
    I turn the tv on it stay on for one second then it goes off thats when the lamp button comes on its red. then the red light comes on and it stays on although the tv is off the red lamp light is still on
    Your lamp timer may be maxed out which means you should change the lamp and reset the lamp timer. When the timer max's out it won't turn on till it is reset.
    Feb 09, 2010 | Mitsubishi WD62327 TV
    T V won,t come on and timer lamp on front panel stays lit.
    Your lamp hours have expired. Try taking the lamp out then putting it back in. The TV will go to a reset menu for the "new" lamp it thinks that you have put in. From there you can reset the lamp hours from the menu. It it doesn't work, the lamp may be burnt, and you have to replace it.
    Aug 13, 2009 | Samsung PCL542R 54" Rear Projection...
    HOW do you reset the timer>? the lights on front of the tv flash 3 gree then 2 orange. Says to replace lamp,which I did then reset timer...HOW?
    press "menu" button, scroll down to "special features" and press "ok" button, scroll down to "reset lamp timer" and press "ok" button, you will notice the "no" change to "yes" and press "ok" button, you will notice "yes" change to "no", this will reset the lamp timer
    Mar 20, 2009 | Vivitek V37655 56" DLP TV
    Best but repleace bulb but red light still on
    So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
    Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
    Panasonic VIERA TX-37LZD800 37 in. HD-Ready LCD TV Logo
    44 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
