Question about Kenmore Refrigerators
Kenmore 78309 suddenly no power wall outlet is fine.
4 Suggested Answers
RJTech
  • 32 Answers
SOURCE: kenmore model 11049182992 serial # ull4509224
make sure you have a new fuse in your panel and you have the lid down on the washer also check the lid switch it may be broken
Posted on Dec 18, 2007
Macmarkus
  • 2605 Answers
SOURCE: Asko W/D. Power to 220 wall outlet and washer
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Posted on May 16, 2010
  • 1033 Answers
SOURCE: My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
Posted on May 23, 2012
My Kenmore refrigerator 795.7830 stopped working, I have checked the plug and it is fine. No lights or compressor or error code
Hello
Check your home circuit breaker and the wall outlet.. try plugging in another appliance into the outlet to see if it works.
Listen carefully to the fridge for a two or three minutes. If you hear a buzzing and click sound.Then power is getting to the compressor but it isn't running the refrigerator. You may have to replace the compressor
Jun 04, 2015 | Kenmore Refrigerators
May 23, 2012 | Kenmore Heating & Cooling
No power up in washer
I have the same problem with my GW52F, i have checked the power supply and it works fine with other appliances, any ideas?
May 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Dryer interior light and motor will not turn on
plug something else into the wall outlet to make sure you're getting power there and try changing the bulb.if there is power check the door switch,move the paddle in and out and you should hear a clicking sound,if you don't change out the door switch,also check the back of the dryer at the block where the power cord connects to the dryer and make sure you have power there.also is there a gfi plug anywhere near the dryer that might have to be reset,i've seen this,also i've come across whoever wired the outlet switched the hot wire and the neutral around so when the machine is plugged in the wiring isn't correct
Feb 04, 2010 | Kenmore 63942 Dryer
Power is coming and suddenly going
I assume it's a pc.
1. Make sure the computer is plugged directly into a wall outlet not to a power strip.
2. Check that the wall outlet is working and not overloaded
3. Have you had any power spikes lately? Your power supply could have been affected.
4. Get a giood surge protector--it's worth the price.
Dec 15, 2009 | HP Compaq Business Desktop dx7400 - Core 2...
I have a trutech undercounter mount DVD/TV combo. It was working fine, and all of a sudden it turned off and will not come back on. We checked the outlet and it is fine.
Unplug the power cord from wall outlet and take the unit apart follow the power cord inside the unit it goes to the fuse. Check the fuse most of the time the fuse is bad.
Jul 22, 2009 | TruTech LMD-5702RT Portable DVD Player
My Toshiba Satellite battery is not getting charged. It worked previously, all of a sudden it stopped charging.
* check the wall power outlet is proper wheather power is coming or not if not change the outlet with good one if fine then
* check the power adapter is working fine (red light is coming when attached to power outlet or not,connected properly to the usb of laptop or not)
* if adapter is overheating or heating quickly change the adapter
*call for toshiba 1-800-457-7777
Jun 19, 2008 | Toshiba Computers & Internet
Power problem
The Printer unable to turn on could be of two reasons.
(1) Connect the Printer directly to the wall outlet instead of connecting through the power surge protector (If connected through surge protector).
(2) Check whether the Power adapter is getting warmed up after connecting to a particular wall outlet.
(3) Try connecting the printer to any other wall outlet and check for the results.
Hope this information would help you in this regard.
With regards,
Ashesburn.
Feb 14, 2008 | HP DeskJet F380 All-In-One Printer
Kenmore model 11049182992 serial # ull4509224
Dec 02, 2007 | Kenmore 22422 Top Load Washer
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
