Question about Microsoft Windows 7 Ultimate, Full Version (PC DVD)
SEARCH OF WINDOWS EXPLORER NOT WORKING CORRECTLY
When I perform a SEARCH in my computer using WINDOWS EXPLORER, if I search for: DWG2001145RevE will find 10 documents , which is fine, but... when I search only for the number part of this text, this is, I type only 2001145, then it will NOT find anything!!!. Why is this happening? As you can see it is not an indexing problem, meaning... the file DWG2001145RevE.pdf is in my computer and Windows Explorer can find it, but when I type only the number portion of the file name, it can not find it.... the same happen with many other files.... Does anyone has same problem?
  • 23 Answers
When you are using partial search terms you are best to use the wildcards. ie '*'
You would probably get the same issue searching using 'wg' or 'rev', but you would probably find the file if you searched with 'dw' for instance.
Windows search looks for a filename matching your term. SO without wildcards it is looking for a filename that begins with '2001145'.
So if you want to search for a file name containing 2001145 somewhere in the name, then put the wildcard before and after and it will return all files with that number(or whatever other term you use) in it.
Posted on May 06, 2014
Philster
  • 113 Answers
SOURCE: Windows Explorer Details View problems.
Usually, the view is determined by the type of files within the folder. For example, when you are in the My Music folder, the Details view gives you columns like "Artist" and "Album", etc, whereas the My Documents folder has the more generic "Name", "Size", etc.
However, if you right click upon any column header (that's where it says "Name" or whatever), a menu comes up that allows you to choose which columns are displayed. And once you change a particular folder to display, THAT folder will then display those columns until you remove them. But any other folder will default to back to the standard settings unless you manually change it yourself.
Posted on Feb 01, 2008
Kidyubyub
  • 143 Answers
SOURCE: text to pdf converter using C++
Try this page:
http://www.codeproject.com/KB/graphics/convertexttopdf.aspx
Hope it helps!
Posted on May 14, 2008
  • 23 Answers
SOURCE: Windows Startup Error csrss.exe
Okay, we are going to try two things. If the first don't work go to the second.
1) First perform a search on your computer for the 'csrss.exe' file. If found, copy it and then paste it into your C:\windows\system32 folder.
That should do it.
2) If that don't do it or your search can't find it, then perform the following;
To scan and verify the versions of all the system files that Windows File Protection protects, use the System File Checker (Sfc.exe) tool together with the /scannow parameter. If the SFC.exe tool detects that such a file was overwritten, the SFC.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows installation source files, and then replaces the incorrect file.
To run SFC, please follow these steps:
1. Click on Start > Run command prompt
2. Type SFC /scannow, and then press ENTER
Note: You may be asked for inset OS CD.
3. After finishing SFC, you may run CHKDSK C: /R in the Run command prompt as well.
Posted on Feb 14, 2009
SOURCE: cannot find regsvr.exe
it showing the same problem as i installed the Regsvr.exe file in System32. it showing file missing on or corrected...... can u get from this .
Posted on Mar 15, 2009
SOURCE: ahsan manan khan bhutta virus has taken over my
hahaha.. ur system is been infected...
re-format your computer is only resolution...than recovering back or try any more...
Posted on Jun 23, 2009
How to Open Windows Explorer?
Steps
  1. Use the Start menu. Click Start ? Computer (Windows 7 and Vista) or My Computer (Windows XP). ...
  2. Use the keyboard shortcut. Pressing the Windows key + E will open the Windows Explorer screen.
  3. Use the search bar. Click Start and then type explorer . ...
  4. Restart Windows Explorer. ...
  5. Start using Windows explorer.
Oct 20, 2016 | Computers & Internet
Tip
Protect the privacy of your Explorer searches Note: This tip relies on the...
Protect the privacy of your Explorer searches Note: This tip relies on the Group Policy Editor, which isn't available in some versions of Windows 7. Thus, this tip will not work if you have the Home Premium, Starter, or Home Basic editions of Windows 7.
When you search through your PC from Windows Explorer, you can see the most recent searches that have been performed. If you share a PC and don't want others to see what you've searched for, you can turn off the recent searches feature:
Select "Enabled" to protect search privacy.
1. In the Start menu's Search box, type GPEDIT.MSC and press Enter to launch the Group Policy Editor.
2. Go to User Configuration --> Administrative Templates --> Windows Components --> Windows Explorer.
3. Double-click "Turn off display of recent search entries in the Windows Explorer search box" and select Enabled from the screen that appears. Then click OK. The recent searches feature will now be turned off.
on Jan 12, 2010 | Computers & Internet
I am unable to do a google search?
Internet Explorer comes preinstalled on most Windows-based computer systems.
If you use Internet Explorer, you may run into the issue where the Internet browser does not open for some reason when you attempt to access it.
Usually that's caused by a minor flaw in your computer, one you can correct without too much effort or time.
Run the anti-virus software you have on your computer and perform a full system scan. Sometimes if a virus or malware infects your computer, it blocks Internet Explorer from launching.
Once the scan has finished, remove any bugs or infections your software found on your computer and attempt to relaunch Internet Explorer.
Shut down the computer and restart it.
Sometimes just restarting the computer can correct any error you are having.
Click the "Start" button, followed by "Control Panel."
The Control Panel window will load with a variety of system icons. Select "System."
Select "System Update" and allow your computer to connect to the Internet (no browser is required) and Windows tells you if any updates for your system are available.
Install these updates and your issues with Internet Explorer may disappear.
Launch a different web browser (such as Firefox or Safari). Using one of these browsers, you can usually access the Internet; you could try to download an updated version of Internet Explorer to correct the older version that's not loading.
http://www.enhanceie.com/ie/troubleshoot.asp
Turn Off Google's Safe Search
Google's preference page allows users to customize settings and options that help utilize searches to the viewer's needs.
One of those options is Google's filtering tool.
This tool contains three filtering options that will filter your results completely, with moderate safety, or it will not filter the search results at all.
Google's filtering preferences also filter and determine what kind of keywords and keyword phrases appear in the Google search bar.
Click on "Preferences" on the left side of the search bar of the Google Home Page.
You will be directed to Google's "Preferences" page.
Scroll down until you locate the "Safe Search Filtering" section of the page.
You will see three safe search options: "Use Strict Filtering," "Use Moderate Filtering," and "Do Not Filter My Search Results."
Click the "Do Not Filter My Search Results" option to check the option and click the "Save Preferences" button to save your changes.
Google guide making it easier
http://www.googleguide.com/preferences.html
Editing SafeSearch Filters
http://www.google.com.au/preferences?hl=en
Aug 15, 2013 | Computers & Internet
How can I reinstal Windows Search and Windows Security Centre
Install Windows Security Center
Open Internet Explorer and navigate to the Microsoft Windows Update website.
Click the "Express" button on the main page to have your computer checked for important updates to be installed.
Since Windows Security Center is not installed, it will be detected and installed within the update.
Search the list of updates that will be installed on your Computer and deselect any options besides Windows Security Center that you don't want installed at this time.
Click "Install Updates" to begin the installation process.
Set your computer up for Automatic Updates to keep your computer up to date.
You can do so by clicking "Start" followed by "Control Panel."
Click "Automatic Updates" and select the recommended option.
Click "Apply" followed by "OK" to save the changes and exit the window.
Install Windows Security Center in Windows Vista
Click the "Start" button followed by "All Programs." Scroll through the list and select "Windows Update" from the available options. You can also type "Windows Update" in the search field followed by pressing "Enter" to access it immediately.
Click the "Change Settings" button in the left window pane.
Select the radio button next to "Automatically download and install updates."
Click "OK" when you have finished. Windows will begin to scan your computer and download the necessary updates, one of which will be Windows Security Center if it isn't available on your computer already. When the updates have finished installing, a bubble will pop up in your system tray telling you new updates have installed and your computer needs to be restarted.
Restart your computer and once you log back on to Windows, Security Center will be available. You can access it by clicking the "Start" button and typing "Windows Security Center" in the search field. It will also be available in the "All Programs" software list.
Reinstall Windows Search
If for some reason you've lost Windows Search from your computer, it is possible to reinstall it.
Reinstalling Windows Search will improve the performance and stability of your computer system's indexer.
It will allow you to sort and group results in Windows Explorer more quickly, and will improve the indexing of your online email.
It expands your system's ability to do fast remote queries of file shares, including on Windows XP and Server 2003.
It automatically indexes shared folders and contains improvements in previews for earlier supported operating systems (Windows Server 2003 and Windows XP).
When you type a search term into Windows Search, the results appear quickly.
This is also true for information from emails and their attachments.
Download and install Windows Search on your computer.
http://www.microsoft.com/windows/products/winfamily/desktopsearch/choose/windowssearch4.mspx?tab=Install%20It
Click on the appropriate link for your version of Windows.
Click "Open" to download the file if you use Vista.
Click "Save" to download the file if you use Windows XP.
Click on "Run" to install Windows Search on your computer.
Follow the prompts to complete Windows Search installation.
Restart your computer.
Windows Search will be available in the Start menu if you use Vista.
If your operating system is Windows XP, use the Deskbar for quick and easy search access to indexed content on your PC or the network.
Personalize Windows Search for an optimal search experience .
Add-ins let you index Outlook saved email, Microsoft networks, Internet Explorer history and Lotus Notes.
Hope this helps
Nov 03, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
I got Linkury Smartbar stuck on my laptop
To perform a standard uninstall using the Windows XP operating system on your computer:
  1. Click Start.
  2. Click Control Panel.
  3. Double-click Add or Remove Programs.
In the Currently Installed Programs box:
  1. Click Linkury Smartbar
  2. Click Change or Change/Remove.
To uninstall the Linkury Smartbar using Windows Vista or Windows 7 (32 bit or 64 bit):
  1. Click Start.
  3. Double-click Programs and Features.
  2. Click Change/Remove.
If for some reason the above procedure does not properly uninstall the Linkury Smartbar, go to the Linkury Smartbar download page and perform a "reinstall". Then restart your computer and perform the "uninstall" procedure.
To remove the customized web search of the Linkury Smartbar:
  1. Click the arrow to open Internet Explorer's Search Menu.
  2. Choose Change Search Defaults.
  3. Select Linkury Smartbar Search Web Search.
  4. Click the Remove button.
  5. Click Ok.
Aug 02, 2012 | Acer Computers & Internet
I've had my pc rebooted,and when i want to go on a specific site,i can't open internet explorer.how do i reinstal internet explorer?
dear friend if you are using internet explorer just give a try to mozilla firefox once.
and if you still need internet explorer i think you might be using windows XP.
Click Start > Control Panel > Add Remove Programs > then click on Add remove windows components > search for "Internet Explorer" it will have a tick mark in front of it. now "Untick" (unselect) it and press Next this will uninstall your internet explorer from your windows. now reboot your Computer.
now you have to install the internet explorer for that you have to do the process again
Click Start > Control Panel > Add Remove Programs > then click on Add remove windows components > search for "Internet Explorer" it will have a no tick mark in front of it. now "Tick" (select) it and press Next this will install your internet explorer to your windows. now reboot your Computer.
now your internet explorer will work as a new one but with older bookmarks and settings.
try using Firefox once
and dont forget to rate my suggestion
Thanks
Gagan Gupta
Was that Useful?
Mar 23, 2011 | Computers & Internet
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found.
Which is your browser and operating system? Anyways i would suggest you to perform all this so try.
http://support.mozilla.com/en-US/kb/Support+Website+Forums
Firefox Support at above link.
See if the information below helps to resolve the issue/s you are having with Internet Explorer:
http://support.microsoft.com/default.aspx/kb/936213/?p=1
"How to optimize Internet Explorer"
Configuration settings in Windows Internet Explorer 7 and Windows Internet Explorer 8 may cause one or more of the following issues:
· You experience performance problems in Internet Explorer.
· You receive an error message in Internet Explorer. For example, you receive an "Internet Explorer cannot display the Web page" error message.
· Internet Explorer stops responding.
The above article describes how to optimize or reset Internet Explorer in Windows Vista to resolve these issues.
http://support.microsoft.com/kb/936215
"How to troubleshoot Internet Explorer issues in Windows Vista and in Windows XP"
This article discusses how to troubleshoot possible issues that you may experience when you use Windows Internet Explorer 7 or Windows Internet Explorer 8 on a computer that is running Windows Vista.
http://support.microsoft.com/kb/936214/
"How to troubleshoot compatibility problems that affect Internet Explorer 7 in Windows Vista"
This article describes how to troubleshoot software compatibility problems that affect Windows Internet Explorer 7. To help determine which program may be causing the problem, you can take the following steps:
1. Use safe mode with networking
2. Perform a clean boot
3. Use a different user account
4. Scan your computer for viruses and spyware
5. Run Internet Explorer 7 in "No Add-Ons" mode
Hope the above helps.
Cheers.
Dec 27, 2010 | Facebook Social Network
My face book is not working. the error message is saying bigpipe undefined
I would suggest you to use the Internet Explorer in No Add-on mode and check if the issue persists. To run in No Add-on mode follow the below steps - Click Start, and then type Internet Explorer in the Start Search box. Click Internet Explorer (No Add-On). Internet Explorer opens without add-ons, toolbars, or plug-ins. Test Internet Explorer to verify that it works correctly. If the issue gets resolved use the below mentioned links for further resolution - http://windows.microsoft.com/en-us/windows7/Internet-Explorer-add-ons-frequently-asked-questions
http://windows.microsoft.com/en-US/windows7/Using-the-Internet-Explorer-Add-on-Manager
Nov 05, 2010 | Computers & Internet
Laptop logs off when i log on. what can i do
Edit these values and type the correct path of shell :
Shell = explorer.exe
Userinit=X:\windows\system32\userinit.exe
NOTE: These files may also be deleted by spywares. You may need to extract them using Windows CD.
Steps for rectifying this problem:
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit these two values in right pane:
Shell
Userinit
Change these two values to
Shell=explorer.exe
Userinit = x:\windows\system32\userinit.exe
Exit from Registry
Restart Infected computer.
You should be able to log on to computer.
if it not work then go to back steps and just copy orwrite the file userinit.exe
Performing the above steps will resolve the issue.
Hope this helps.
Jul 07, 2010 | Dell Latitude D400 Notebook
None of the Microsoft suggestions correct error #0x80072F8F and allow me to get updates
search for updates manually. especially for installer 3.1 install it and restart your computer. Check Services and make sure windows automatic update service is set to automatic and started. Check time and Date and download the latest version of internet explorer from microsoft site. Install it and it will automatically update many root certificates for your windows. Set the security setting of internet explorer to default level and finally try to use update application of windows. It should work.
Sep 07, 2009 | HP Pavilion 510c PC Desktop
Microsoft Windows 7 Ultimate, Full Version (PC DVD) Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
