Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Not booting hp presario f700
When I'm editing my picture at MS word my latop was restart and they not open to its windows . Only blinking the lights when you try to power up the laptop. please help me to solve this kind of problem!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 2,226 Answers
Hit the f5 key then follow the screen from there that is in safe mode
Posted on Mar 24, 2014
Bios update for compaq presario f700 running linux mint
Nice OS. Dare I suggest boot into vista and install the firmware. Ensure there is no antivirus programme running as this may corrupt the BIOS!
Re boot into Mint.
Feb 17, 2013 | Compaq Presario F700 Series Laptop...
How do i reset my computer to factory settings. its a compaq presario f700
Hi!
To restore your Compaq Presario PC f700: Turn the computer on, then while restarting, Press and hold the F11 key. Under HP Recovery Manager, select the option to perform a system recovery. ***Note*** Doing this will delete everything that are save in your computer. Back up your files before doing this.
Hope this can help.
Jul 24, 2011 | Compaq Presario Notebook
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
My power light comes on then ngoes off immediately
1. Turn off the computer
2. Removed battery and disconnected power cord .
3. Wait, for 5-10 minutes
4. Plug the power cord back in but DO NOT reinsert the battery
5. Holding down both the Insert/Scroll button, hold the power button down for 20-30 seconds, release the power button. still hold the Insert/Scroll button press the power button normally should come up and Windows should boot.
6. Restart hit ESC it should open the BIOS and reset to default. restart computer should come back.
Feb 19, 2011 | HP Compaq Presario F500 F700 and G6000...
Pls help to me.my compaq F700 laptop cant on.when i press on switch hearing one beep sound only.not bootable. How i solve the problem.
Hearing exactly ONE beep is "good" -- it signifies that the hardware is working correctly.
So, either the disk-drive itself is the problem,
or the installed copy of Windows has been corrupted, such that Windows cannot start/complete the boot-process.
Jul 03, 2010 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F700 DVD problem. Today would not
Please perform the below steps to fix this issue.
1. Check in device manager for cd drive option. in case its visible, right click on it and uninstall it and reboot the system and the corect drivers should get loaded automatically.
(to go to device manager follow the below steps:
in XP---1.On the desktop right-click on My Computer and click Properties or open the Control Panel and double-click the System icon.
2.In the System Properties window click the Hardware tab.
3.In the Hardware tab click the Device Manager button.
in vista\windows 7---1.Click on the Start Orb.
2.In the Start Search box type: device manager and then press enter.)
2. Delete the upper and lower filters:
For XP
Start -> Run ->regedit - > Ok
It opens the registry editor window. navigate as per the below path
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the right side pane if you see upper or lower filter options...right click and delete them.Restart the system
For Vista
Start - > Search - > regedit - > OK
3. Check in Sysem setup/BIOS and see it the drive is getting detected. in case the drive is not getting detected over there it is a possibility that the data cable that connects the drive to the main board might be loose. if that is the case we need to go into more detailed troubleshooting. please let me know if above steps fix the issue else will provide further steps.
regards.
Jan 07, 2010 | HP Compaq Presario F500 F700 and G6000...
Hp presario f700 light on power jack lites lights on power buttion flash off 3 lites on front flash off cinter lite stays on.
Ok. I have this exact same laptop and the exact same issue. Go to hplies.com and you will see almost 2,000 users with the same issue. The problem lies with the nVIDIA GFX chip on the motherboard. THE ISSUE IS UNREPAIRABLE. Any repairs will force the laptop to fail again.
This issue has actually landed me in small claims court where I am suing for hte full cost of this laptop because not only is hte laptop defective, nVIDIA admitted it, and HP covered it up.
Join us at hplies.com and we will give you the know how to get this issue fixed/your $ back. We even have links to all of the information!
Do not give HP a DIME. The laptop will just fail AGAIN. Please add your information to the database as a new letter is being complied to be sent to HP to make them either fix our computer or do something real about it.
Jan 02, 2010 | HP Compaq Presario F500 F700 and G6000...
No touch pad response, no pointer
Boot in safe mode (hit F8 on system start-up). Then once in windows, use the system restore feature found in acessories>system tools once you click the start button.
Sep 21, 2009 | HP Compaq Presario F500 F700 and G6000...
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
