Question about Bose Televison & Video
Bose speakers work great with radio in 04 maxima but when i play a cd the sound muffles and rotated between left and right speakers, it also changes from high to low depending on how i turn the steeri
All steering wheel controls work fine.radio works fine through speakers, its just when I use the cd changer or tape
Arpi
  • 326 Answers
SOURCE: I can't get the remote to work with my disc changer
Hello, please check the batteries by replacement (use fresh ones). Best regards, Arpi
Posted on Apr 06, 2007
  • 3 Answers
SOURCE: code to control my Viewsat9000HD on Bose remote not working at all
Have you tried changing the codes in the system setting?
Posted on Sep 11, 2008
SOURCE: No sound
I had the exact same problem. I disconnected the radio from the power cord in the back, waited several minutes, reconnected the power cord and my radio had sound!!
Posted on Nov 16, 2008
awcforever
  • 359 Answers
SOURCE: No sound comming from the left side speakers in my 04 Envoy XUV.
Did you try your balance control on the radio? You will find FADE, and BAL. The balance will move the sound from side to side. If thats not it, it sounds as thought one of the harnesses behind the radio came loose. Hope that helps
Posted on Feb 15, 2009
techprogrami
  • 57 Answers
first> road vibrations can cause cable connections to come loose so you can start by taking out your radio and making sure all of the questions in the back are connected as they should be.
Second> if this doesnt seem to work then the next step is to check the wires going to the speakers that arnt working (this will b quite a job, but if you can do it, it will save u quite a bit of money) .. checking the wires your checking for >bad connection to the speakers >cuts in the wire or if any part of the wire is touchin any other metal object
Was This Helpful ?
Posted on May 29, 2009
I have a 1996 Nissan Maxima with a factory Bose CD player / cassette and radio and it will not turn on what's the solution
Maxima Bose Radio ' eBay
www.ebay.com/bhp/maxima-bose-radio
eBay1995 1996 1999 Nissan Maxima Pathfinder Infiniti J30 Radio BOSE CD tape Player ...Will fit and work in these with BOSE audio package only:1995 - 1999 NISSAN .... 2006Nissan Maxima OEM Bose Cassette & 6 Disc CD Player Radio CR13B ...DESCRIPTION Unit is missing some bottons, 3 of them, this item has NOT ...
Nissan Maxima Bose Stereo ' eBay
www.ebay.com/bhp/nissan-maxima-bose-stereo
eBayWill fit and work in these with BOSE audio package only:1995 - 1999 ... 1996 - 2000 NISSAN Pathfinder. 2004 2005 2006 NISSAN MAXIMA FACTORY BOSE STEREO 6 DISC ... Factory NISSAN INFINITI BOSE Radio, Tape, and CD Player. ... 6 Disc AM FM Stereo Cassette Radio Bose OEM LKQ (Fits: Nissan Maxima).
Nissan Maxima Car Stereo Removal and Repair - YouTube
? 8:52
https://www.youtube.com/watch?v=RT-SZEfeA4Q
Sep 16, 2012 - Uploaded by Factory Car Stereo Repair
Factory Car Stereo Repair .... I have nissan maximal 05..the CD part turns on but the cd won't eject...should ... I have a 2005maxima non-bose radio system. ... my speakers is super in my 05 maxima but my cd player keeps on ...
Nissan - Factory Car Stereo Repair
Feb 03, 2016 | Nissan Cars & Trucks
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sep 07, 2012 | Sony 2003 2004 03 04 Infiniti G35 Bose Am...
Nissan Maxima 1997 Stereo not turning on at all!!
Here is a list of radio wiring harness wire color codes and what they do. I have given both with and W/O Bose.
Nissan Maxima Car Stereo Radio Wiring Diagram Radio Constant 12V+ Wire: Pink/Blue
Radio Ignition Switched 12V+ Wire: Blue/Black
Radio Ground Wire: Vehicle Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: Red/Orange
Radio Antenna Trigger Wire: Black/Red
Front Speakers Location: Doors
Left Front Speaker Wire (+): Blue/White
Left Front Speaker Wire (-): Blue/Yellow
Right Front Speaker Wire (+): Brown
Right Front Speaker Wire (-): Brown/White
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Red
Left Rear Speaker Wire (-): Green
Right Rear Speaker Wire (+): Blue
Right Rear Speaker Wire (-): Pink
1997 Nissan Maxima with Bose Stereo Wiring Diagram W/Bose
Car Radio Battery Constant 12v+ Wire: Pink/Blue
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: Black/Red
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Each speaker has its own amplifier located at each speaker.
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Brown
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Light Green
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Pink
Right Rear Speaker Negative Wire (-): Blue
Mar 27, 2017 | 1997 Nissan Maxima
CAN THE BOSE CD PLAYER BE FIXED IF SOMETHING IS
Yes, many aftermarket radio/CD players are made that will fit. Look on WWW.Crutchfield.com
Feb 07, 2010 | 2000 Nissan Maxima
Front Speaker not working
Yes, ur setting needs to be changed. On fliping the settings u will realise in one of the modes mostly the surround mode the speakers will work.
Thankyou
Appreciate a good rating from you..
Jul 31, 2009 | Bose?® Acoustimass?® 10 Series IV home...
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Speakers only play cd's
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Feb 24, 2009 | Bose Companion 2 Computer Speakers
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
Bose Wave Radio/CD - Sound from only one speaker
Sounds like the audio transformer, but it's difficult to tell because Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 06, 2007 | Bose 683-0332FB CD Shelf System
Televison & Video Logo
13 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Jerry Greenberg
Jerry Greenberg
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
