Question about Vehicle Parts & Accessories
How do I fix my back door it no longer opens? 2005 Yukon Denali XL
My back door no longer opens how can that be fixed?
  • 35 Answers
First be sure that children safety is off then try from inside if no so the hand is broken then you will find small screw behind the hand remove it then you will find steel wire try to catch it and pull it out door is open
Posted on Mar 23, 2014
LIFTGATE MOTOR WENT OUT. HOW CAN I OPEN THE DOOR MANUALLY?
chevy tahoe lift gate not opening - YouTube
? 2:12
www.youtube.com/watch?v=xU6ybiY3F4I
Sep 1, 2010 - Uploaded by 76bluemoon Back lift gate/glass would not open or release. ... Wow, are you sure? .... known issue with tahoe, suburbans, hummers and othergmc vehicles. ... 2007-2012 Yukon Denali Rear Door Lock Actuator Replacement ... 2004 GMC Yukon XL rear liftgateremoval - Duration: 50:17. by Velvethamma 5,814 views.
Aug 08, 2015 | 2007 GMC Yukon XL Denali
2005 gmc yukon denali xl engine fans dont come on
under the hood I would check the thermostat to make sure it open so that the hot antifreeze reaches the sensor to make the fan start
May 03, 2014 | 2005 GMC Yukon Xl Denali
2005 gmc yukon xl blower moter stuck on even with ignition off
UNPLUG THE FUSE AND JUST USE THE BACK HEAT UNTIL YOU COULD GET IT FIXED! SHIRLEY COULD PROBABLY FIX IT!
Oct 20, 2011 | 2005 GMC Yukon Xl Denali
Rear lift door on my 2004 Denali Yukon (SWB)will not stay up. Both lift rods seemed to have failed simultaneously. Can they be fixed or must they be replaced?
They need to be changed. Buy 2 new gas springs, support the gate, and pop off clips holding them on. Install new ones with clips provided and remove support. I just did this on my Focus a couple of months ago. Easy fix.
Aug 09, 2011 | 2005 GMC Yukon Xl Denali
Rear access will not unlock 2005 Yukon Denali
I found this URL on the internet http://www.chefseattle.com/blog/site-news/suburban-rear-liftgate-wont-unlock-how-to-fix/ that might fix your problem. Also consider doing my fix rear wiper how to tip for 2005 Tahoe before that fails, while panels are removed.
Apr 19, 2010 | 2005 GMC Yukon Xl Denali
2004 GMC Yukon XL Denali
if the hinges are loose making the door difficult to close the brass bushings in the hinge pins are worn
replace the parts to regain a perfect closure to your door
if not replaced the latch will go bad very soon
Mar 07, 2010 | 2005 GMC Yukon Xl Denali
Rear doors and tailgate will not lock with remote or with buttons , unlocks ok 2005 GMC YUKON
Harris, did you find a solution to your problem? I am having the same issue on my 04 denali. Rear doors and tailgate wont lock but the unlock fine. Front door function normally? let me know.
Jul 09, 2009 | 2005 GMC Yukon Xl Denali
Gas tank wont' fill to specs
Based upon my experience, I would say it's a manufacturing defect. Something in the filler or the tank itself. I've seen cases where the dealer replaced the tank and related parts when this is happening.
Nov 17, 2008 | 2005 GMC Yukon Xl Denali
Rear brake line/ rubber bushing leaking
if you say oil that oil seel dameg bat you saygrease ned to cleen up and boot new grease heet brpof dont replased whit reglar grease .abujabal yousef
Jul 29, 2008 | 2005 GMC Yukon Xl Denali
Vehicle Parts & Accessories Logo
52 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
