Question about Toshiba Satellite M35X-S114 Notebook
Celeron M processor 1.3 Mhz
Can it be upgraded and if so, what is compatible / recommended?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Hello Rafael, Based on the stats this looks like a pretty old notebook. Depending on what you want to use it for it may be a better option to buy a new one. Let me know what you use the notebook for primarily and I'll try to guide you through your options.
Posted on Mar 21, 2014
3 Suggested Answers
thehumble1
  • 137 Answers
SOURCE: Dual Processors for Toshiba Satellite A205-S5000 533Mhz FSB
you got a cheap laptop. maybe from walmart or some other store that was selling it for about $400. It doesn't have a processor that you can switch out. I'm sure it's horribly slow for Visa, so my advise would be to sell it and get something with a dual core.
Posted on Feb 26, 2009
joecoolvette
  • 5660 Answers
SOURCE: upgrade this cpu
Hold onto your hat tamiagrad09, it may be a 'bumpy ride'.
1) Processor:
Intel Core 2 Duo, Model T5200, 1.6GigaHertz maximum frequency rate. ('Speed'. 1.6GHz)
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Core_2_Duo_2
Read across from the blue - Core 2 Duo T5200 - in the left column.
A) Core Technology used:
Merom; Merom 2M, and is based on the 65nm architecture.
(nm stands for NanoMeter.
One Billionth of a Meter )
B) FSB = 533MegaHertz
Front Side Bus is 533MHz.
C) Voltage = 1.0375 volts to 1.3 (1.3000)
[ DC Voltage ]
That is the voltage range of the processor you are using now.
2) Processor socket:
http://en.wikipedia.org/wiki/Socket_M
3) Intel 945GM motherboard chipset,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Core.2FCore_2_mobile_chipsets
945GM/E
FSB (Front Side Bus) support is for processors, that have either a 533MegaHertz Front Side Bus, or a 667MHz FSB.
Now your chipset;
Intel Core 2 Duo, model T7250, mobile processor;
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Merom.22.2C_.22Merom-2M.22_.28standard-voltage.2C_65_nm.29
Scroll down to Core 2 Duo T7250
A) Core Technology used is also Merom; Merom 2M, and the 65nm architecture.
B) FSB:
800MHz. <- This = NO
C) Voltage:
1.075 to 1.175
This would work.
Processor socket:
Socket M just like the T5200 you have now.
No tamiagrad09, the Intel Core 2 Duo, Model T7250, will Not work.
The highest FSB supported by the motherboard is 667MHz.
The T7250 must have 800MHz.
http://www.cnet.com/laptops/toshiba-satellite-a135-s4467/4505-3121_7-32327256.html#!
Hmmm, did you see the Intel Core 2 Duo, Model T7200, will work?
Same Core Technology, and architecture.
Also uses the same Voltage range.
-> Also only needs a FSB support of 667MHz.
Maximum frequency rate ('Speed') is 2.0GHz
http://ark.intel.com/products/27255/Intel-Core2-Duo-Processor-T7200-%284M-Cache-2_00-GHz-667-MHz-FSB%29
http://www.amazon.com/dp/B000I7977C/ref=asc_df_B000I7977C2231384?smid=AVJVFPJRIWFG5&tag=nextagusmp0359530-20&linkCode=asn&creative=395105&creativeASIN=B000I7977C
Just from a quick search, not advertising.
Besides, we computer geeks have gotta stick together.
Now,.................................
Procedure.
Ignore all of the following if you are aware;
1) Tools;
A) Spudger Tool.
You be able to use a thick guitar pick, or kitchen tool, as a substitute, but nothing beats a Spudger Tool,
http://www.amazon.com/Techni-Tool-Spudger-Alignment-Tool-Black/dp/B000PDNPYK/ref=sr_1_7?ie=UTF8&qid=1350896291&sr=8-7&keywords=spudger+tool
Used for gently prying the Palm Rest Cover from the Base Enclosure, among many other uses.
B) Jewelers screwdriver set.
(A lot of times the checkout aisle racks, at major discount stores have them )
C) Isopropyl Alcohol.
91 percent is best, 70 percent will do. (Rubbing alcohol)
IMHO 50 percent = No.
50 percent water, and 50 percent alcohol.
D) Q-tips
E) Thermal Paste
F) Multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
G) Plastic scraping device.
Old credit card is what I use
H) ESD wrist strap.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
A Processor is the MOST susceptible hardware component to Static shock.
Do not use an ESD wrist strap, and have it's alligator clip attached to a good ground source, and you can use the motherboard/processor/ram memory, for a Frisbee.
Average cost is $3 to $6.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
(Feel an Anti-Static Mat is unwarranted. 10+ years at this says I'm right)
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
In Step 23 per the Irisvista link, the four Philips head screws, securing the Cooling Tube processor plate to the Processor; SHOULD be loosened with a sequential pattern.
Same thing when tightening. A sequential pattern should be used.
Tighten one screw until it just touches, then go in a spiral pattern with the rest of the screws.
After all 4 screws are lightly snugged down, then tighten the first screw to the desired torque, and spiral pattern again.
That is sort of backwards information, but I wanted to bring up about the proper procedure, when loosening.
I would scrape off the old Thermal Paste, and use alcohol dipped Q-tips to clean it further. (Takes a LOT of them babies)
Put it in the case, or carton the new one comes in.
Perhaps you, or someone else might need it in the future.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a WELL ventilated area with NO sparks or flames present.
The screw in the Socket M processor socket, ONLY turns 180 degrees to loosen. (Half circle. Don't e-slap me )
L = Lock
Make SURE the Dot/s or Triangle/s in the corners of the Processor, match up with the corresponding marks on the processor socket.
Most of the time they line up with missing socket holes, in the Processor socket.
Hold the Processor down with your thumb, turn the screw 180 degrees towards L.
Apply a small pea sized drop of Thermal Paste, to the center of the Processor. That small blackish rectangle in the center.
Holding the Thermal Module flat, line it up, gently set it down.
Tighten the mounting screws as outlined above.
DO NOT forget to plug the Fan Assemblies power cable, into the motherboard.
(Good time to break those Q-tips out again, along with a small fine soft brush, { makeup brush? }, and a can of compressed air for computers.
Clean the fins of the Heatsink out, and the fan blades, center hub, and surrounding cage, { Shroud } of the Fan Assembly
Also the rest of the laptop, and motherboard.
That thin 'aluminum plate' that is above the Processor, and to the side of the Fan Assembly, has the graphics chipset underneath it.
(I believe)
I would remove the aluminum plate Heatsink screws, clean the top of the graphics chipset, (Credit card/ alcohol dipped Q-tips), and the bottom of the 'aluminum plate Heatsink'.
Then properly apply fresh, new Thermal Paste.
(If there is a Thermal Pad, carefully peel it off, then scrape, and alcohol dipped Q-tips.
You CANNOT reuse a Thermal Pad, and you SHOULD not try reusing the old Thermal Paste.
Even if it is still gooey, Thermal Paste looses it's thermal conductivity over time. (And repeated heating)
The Keyboard Cable is a FFC. Flat Flex Cable.
A FFC has NO connector on the end. The Keyboard Cable STAYS attached to the Keyboard, and removes from the motherboard connector.
The flat contact strip 'pins' need to go back the same way, as they were positioned originally in the motherboard connector.
I suggest make a mark on one side of the cable, and a matching mark on the same side of the motherboard connector.
Same for all components that use a Flat Flex Cable.
(Touchpad, etc)
The motherboard connector is a ZIF connector.
Zero Insertion Force.
Is a rectangular shaped connector, and composed of two parts, or pieces.
HOWEVER it does -> NOT come completely apart.
The bottom part is larger, and stays stationary. It is the BODY.
The top part is smaller, and moves. It is the Locking Bar.
Two styles being presently used to my knowledge;
Style 1: The Locking Bar slides. Slides towards the LCD screen.
ONLY moves about 2mm. That is a little larger than 1/16th of an Inch, or about the width of this capital -> O
Use your thumbnails, be gentle.
Style 2: The Locking Bar flips straight up to a 90 degree angle.
If the Flat Flex Cable of the component you are trying to remove seems stuck, gently move it side to side, then ease it out.
Still no? Check to make sure the Locking Bar is in the fully unlocked position.
IF, the Locking Bar comes off of the Body, you are looking at MOTHERBOARD REPLACEMENT.
Hence why I am being so detailed.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Oct 22, 2012
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000341
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
What type of dual core processor can I use for my dc7600?
The motherboard for the dc7600 has an Intel LGA775 processor socket. However, not all LGA775 processors are compatible with the motherboard. For the small form factor, the following CPUs are supported: Intel Celeron D Processors:
Intel Celeron D 331 Processor (2.66-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 336 Processor (2.80-GHz, 256K L2 cache, 533-MHz FSB) , Intel Celeron D 346 Processor (3.06-GHz, 256K L2 cache, 533-MHz FSB)
Intel Pentium 4 Processors with HT Technology:
Intel Pentium 4 521 Processor (2.8-GHz, 1-MB L2 cache, 800-MHz FSB) , Intel Pentium 4 524 Processor (3.06-GHz, 1-MB L2 cache, 533-MHz FSB) , Intel Pentium 4 541 Processor (3.2-GHz, 1-MB L2 cache, 800-MHz FSB), Intel Pentium 4 620 Processor (2.8-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 630 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 631 Processor (3.0-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 640 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 641 Processor (3.2-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 650 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 651 Processor (3.4-GHz, 2-MB L2 cache, 800-MHz FSB), Intel Pentium 4 661 Processor (3.6-GHz, 2-MB L2 cache, 800-MHz FSB) or
Intel Pentium D Dual Core Processors:
Intel Pentium D 805 Dual Core Processor (2.66-GHz, 2x1MB L2 cache, 533-MHz FSB), Intel Pentium D 820 Dual Core Processor (2.8-GHz, 2x1MB L2 cache, 800-MHz FSB), Intel Pentium D 915 Dual Core Processor (2.8-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 925 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 930 Dual Core Processor (3.0-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 940 Dual Core Processor (3.2-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 945 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800-MHz FSB), Intel Pentium D 950 Dual Core Processor (3.4-GHz, 2x2MB L2 cache, 800 MHz FSB)
Unfortunately, these are old processors and I don't see any available new. Newegg.com lists a couple available as refurbished. You may be better off getting a new computer with either a Intel I3 or current AMD processor.
I wish that I had better news for you.
(do not attempt to use a CPU that your motherboard doesn't support. It probably won't boot.)
Mar 30, 2012 | HP Compaq dc7600 Small Form Factor PC...
I have a mainboard of model D845GVAD2------------------------AAC18931-104. It has already intall the Intel celeron processor of 1.8GHz. Now I want to upgrade my processor. So what high frequency processor...
The Intel® Desktop Board D845GVAD2 supports a single Pentium® 4 processor with a system bus frequency of 400 MHz or 533 MHz, or a single Celeron® processor with a system bus frequency of 400 MHz.
So you can install upto 3.06 GHz 533 MHz(cache memory) processor and also update the ram 2 GB 400 mhz.
Dont install Prescott processor.
Hope it will help you.
Dec 31, 2010 | Intel Desktop Board D845GVAD2 Motherboard
Upgrade from celeron to pentium 4 processor???
It is probable that you will be able to upgrade the CPU, but you may have to upgrade the BIOS. Check this links I've included with this post.
Jul 12, 2010 | Dell Dimension 2400 PC Desktop
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
Mar 15, 2010 | HP Pavilion dv1000 Notebook
I have an ECS P4M800-M7 motherboard using Celeron D 2.66Ghz processor.What compatible processor can i use for upgrading.
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:- http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=548&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
Jun 13, 2009 | EliteGroup Intel Pentium 4 Processor...
Celeron 540 upgrade
Aspire 4315 Specifications Specifications
Part Number
Varies by specifications
Processor / Speed
Intel Celeron mobile processor 530/540/550 (1 MB L2 cache, 1.73/1.86/2 GHz, 533 MHz FSB), supporting Intel 64 architecture
if you have a 2 Ghz processor installed, you will have to replace the motherboard to go with a faster CPU.. which will be spendy..
Hope this helps
May 06, 2009 | Acer Aspire 4315 Notebook
Can we install windows xp on compaq v3424 au laptop
If your laptop meets the following requirements then there shouldn't be a problem:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
I would take a system restore point BEFORE you upgrade and make sure you back up everything BEFORE you attempt an install/upgrade.
Hope this helps.
Feb 20, 2009 | Microsoft Windows XP Professional With...
Upgrade intel celeron processor 798 MHz
it is better to use intel core2 dueo or intel quad core processor
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Will the 5020 psu run a pentium celeron 2.5 ghz motherboard
The motherboard socket is not compatible, nor will the FSB be able to handle that. It probably has a 300 MHz Celeron right now, that's about all you are going to get out of it. I have heard it can be Overclocked to run at 450 MHz (by increasing the FSB from 66 to 100) I wouldn't recommend OCing though. Sorry.
Dec 08, 2008 | Compaq Presario 5020 (320830-003) PC...
Open Questions:
Toshiba Satellite M35X-S114 Notebook Logo
21 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
