Question about JVC HD-61Z575 61" Rear Projection HDTV-Ready Television
I have big screen JVC floor model tv and it turns black when i put it back on tv from the video input
Its skips tv from the video input list
SOURCE: Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Posted on Jun 09, 2007
  • 375 Answers
SOURCE: JVC AV-27D304 display
hit the display button on your remote should turn it off
Posted on Apr 08, 2008
SOURCE: jvc big screen tv
Good day.
Please check for loose contacts along the cicuitry of your unit. Particularly on the system section.
Regards,
chris
Posted on Aug 18, 2008
  • 9 Answers
SOURCE: JVC GM-P420E Plasma no video green screen
the problem is with the micro processor on the back of the fx-1169a board (gm-p420ug) this is the board the inputs connect to . yours may be a diffrent p/n due to yours bein a "e" extention model. to repair this problem you need to remove the processor from the socket, remove the socket from the board and solder the processor onto the board. the processor is ic002 on the back side the problem is thermal in nature due to cold solder joints on the socket. i have fixed this problem many times by using this method.
Posted on Jan 28, 2009
  • 280 Answers
SOURCE: black screen on EVERY input/channel
Turn off the closed capition
Posted on Jun 19, 2009
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
How do I reset TV?
reset jvc tv Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... reset jvc tv question. Get free help, tips & support from top experts on reset jvc tvrelated issues. ... one on the Right 2. HDMI input not working ... ...reset television. I have a jvc 42inch that was just going to main logo screen and not beyond it.
[PDF]LCD Television Users Guide - JVC
resources.jvc.com/Resources/00/01/14/YA654ien.pdf
Audio Reset . .... See the included manual on mounting procedures. - JVC is not responsible for ... 2) Remove the screws from the back of the TV. 3) Pull out the ...
HOW TO FIX A JVC HD BIG SCREEN TV - YouTube
? 6:38
https://www.youtube.com/watch?v=r4v-xzUpQDM
Apr 11, 2012 - Uploaded by kyle dubb
Did your HD D.L.P. t.v. stop working? This movie clip will show you step by step how to easily fix your big ...
Dec 19, 2015 | JVC Audio Players & Recorders
Blank screen
Any error message about inputs? Maybe that clicking sound happens when iit connects to the selected input, but nothing is connected. Can you scroll thru all the inputs? If so, turn on any devices connected to the JVC and scroll thru each input to find the one you're looking for.
Jul 11, 2013 | JVC Audio Players & Recorders
Which button on the remote control is for switching from TV to AV (VCR)?
The TV/Video button on the original remote for the KDL-26S2000 should let you cycle through the inputs on the TV. This button is at the upper left of the remote. (However, if you have set the system to Skip inputs, you may need to remove the skip option.)
There is also a TV/Video button on the front of the TV. It's the second button from the left on the panel (it's just to the right of the menu button).
To reset the input list, press Menu and navigate to Settings. Select the Setup sub-menu and then select the Label Video Inputs. Give the input any label other than skip.
Some TVs work best if the TV is turned on and set to that input source before you turn on the source device.
For additional information and pictures of the menus, see the manual. It is available from Sony support: http://esupport.sony.com/US/perl/model-home.pl?mdl=KDL26S2000&template_id=1&region_id=1&tab=manuals#/manualsTab (see the Manuals, Specs and Warranty tab). The direct link to the manual is http://www.docs.sony.com/release/KDL40S2000.pdf .
I hope this helps.
Dec 31, 2011 | Sony BRAVIA KDL-26S2000 26 in. LCD HDTV
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
No Video Signal - Black screen with Blue Bar that reads "No Video Signal". Eversince we got a new HD reciver to view our new Toshiba 40" tv in HD, we have been having this issue! Lately it...
One of the things an HDMI connection does is allow the TV and equipment to talk back and forth to each other. When you turn the TV off it ends this connection but when you turn it back on, it doesn't communicate correctly. The analog inputs don't do this that's why when you change inputs and go back to HDMI it works, because the TV reestablishes that connection. You didn't list the model of the TV but go to "http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp" and click download. Enter the TV you have and click "GO". A list of downloads comes up and your TV may have a firmware update for it. There is instructions on how to do it. Even if this doesn't fix this problem, it is still good to do to avoid other problems. Another solution is to use component (Red/Blue/Green) cables. The highest resolution they support is 1080i, HDMI is 1080p. Depending on the model of your TV and what your watching though, you might not see a difference. TV2 will never have this problem because it is not connected through HDMI.
Apr 19, 2011 | Televison & Video
Cannot get lower channels
this is a chennel SKIP fuction . set any ch. to out of the tv memry .so you are reset this ch. pls open tv menu sysem and select edit ch. function .
if your tv ch.no.4 is blocked [skip]. set edit ch no:4 see this ch. is SKIP ON if yes then reset to v- or v+ [or arow key] to set SKIP OFF see this ch. no:4 is view perfactly
if your problum is not solve. pls infom me with your tv brand name and Model no.
Oct 07, 2009 | JVC AV-27230 27" TV
Need Help with tv problem
tiene que revisar la tarjeta de comvergencia
Aug 26, 2009 | JVC AV-48P575 48" Rear Projection...
Black screen on EVERY input/channel
Jun 19, 2009 | JVC AV-27530 27" TV
HDMI input failure
Hey guys, had the same problem. Found this solution on the web. Worked for me.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is reenabled.
Here’s how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
This should work.
Oct 06, 2007 | JVC HD-52Z575 52" Rear Projection...
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
