Question about SanDisk 2GB Memory Stick PRO Duo Memory Card
Memory stick too small for my printer
I wanted to view the picture on my memory stick Pro Duo and it's too small to insert into my printer ESPON CX6000. Is there anything that I use so that I can view what on my memory stick.
  • 256 Answers
Sound like your printer is not designed to read memory sticks. You will need a card reader that reads memory sticks. An inexpensive multi card reader for about $10. should do the trick. They only work on a computer though. So you can see/read the files on the memory stick, download them to your computer, edit and/or print them. To me, this is the logical way to do it. The screen on the printer is too small to make good judgement calls on cropping and you can't edit them either.
Posted on Jun 14, 2009
  • 34 Answers
The printer manual says you need an adaptor for that type of memory stick. Radio Shack, Walmart, should have them.
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
I want to download photos from memory stick pro duo of sony company
Use card reader and insert your cams stick pro duo memory card/chip into it. Then insert card reader into Pc usb and copy your photos from memory stick pro to your pc.
Aug 19, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
1GB Memory Stick PRO Duo Memory Card: i have a memory stick pro duo card .... but now we...
Hi sir
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 17, 2010 | SanDisk 1GB Memory Stick PRO Duo Memory...
    I have a sandisc memory stick pro duo 4gb and it is too small to fit in the memory card slot of my laptop which is an acer aspire 7220 series. please help x
    Hi there!
    Simply insert the card in it's adapter, then insert it into the memory slot.
    However you can buy yourself an external USB card Reader supporting your pro duo card.
    Please rate this advice as it's very important for us.
    Good luck friend!
    Mar 13, 2010 | SanDisk 2GB Memory Stick PRO Duo Memory...
    My computer can't read pictures from memory stick pro duo
    there or to picture folders on the psp one is in the root of the memory stick and the other you have to open the memory stick then open the folder called PSP
    Aug 04, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
    My memory stick pro duo won't fit into either of the two computers I have available to me, because it's too small. When I try to put it in, it just seems to be way too small.
    I advise buying an inexpensive card reader, that accepts different forms of USB flash drives, including yours.
    You just plug the USB cable of this card reader into your computer, and insert your Sony memory stick.
    How about this one for an example?
    http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1187796&CatId=942
    (Scroll down the page a little, and view the animation)
    Jul 14, 2009 | Sony Memory Stick PRO Duo (2GB) for PSP
    Error Viewing pix
    Do not use a Memory Stick Pro Duo - High Speed , use a Memory Stick Pro Duo below 2 GB
    Apr 16, 2009 | Sony Cyber-shot DSC-W90 Digital Camera
    Sony Memory Stick PRO Duo Not reading
    Get a USB card reader, insert the memory card into the card reader and then connect the card reader into the USB port of your computer.
    The computer will see the memory as an external memory device, now you can view the data/images and copy them to your computer.
    Feb 13, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
    I have a memory Stick PRO Duo 4GB
    YEAH, YOU MAY NEED A MEMORY CARD READER to read your memory stick. because some compters have not all type of card slots. the card reader will solve your problem.
    Feb 10, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
    Memory card.
    Supported Flash Memory Cards: CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, Microdrive, MultiMediaCard, SD Memory Card, Memory Stick Duo, xD-Picture Card, Memory Stick PRO Duo
    Your phones card is a RS-MMC type not combatable, wont fit, no eject on printer, card too small for slot, wrong type
    Power off carefull tweezer hunt or bluetac on a match, happy hunting
    Oct 19, 2007 | Office Equipment & Supplies
    SanDisk 2GB Memory Stick PRO Duo Memory Card Logo
    106 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Carlos Calvo
    Level 1 Expert
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
