Question about Hitachi P50H401 50 in. Plasma HDTV
No power. plugged in and load pop at back of tv plug. changed 10amp 125 volt fuse.nothing..no lights or power still.
    Top Expert:
  • Hitachi Master
  • 74,666 Answers
Check and replace the main power supply regulator board as card basis. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 21, 2014
Hello, I have a Samsung LN52B630 TV that quit working...noticeably after a confirmed lightning strike nearby.
Screen coming on when the main plug is removed is normal, that happens on most TV's...Are the spots that have no volts supposed to have voltage? there is a legend on the board to tell what voltages belong no what pin, check that
Oct 28, 2017 | Samsung Televison & Video
Just stopped and nothing since
If you can't hear anything when you try to switch it back on then the problem resides in power http://www.pcworld.com/article/2025425/how-to-pick-the-best-pc-power-supply.html
Mar 03, 2014 | Acer Aspire Z5801 All-In-One Desktop PC...
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
Tv will not power on!!!
most likely will need a new power supply, google it
Jan 01, 2010 | LG 32LG30 32 in. LCD HDTV
I am stationed in Iraq; I have a Onkyo TX-SR606 7.1 Channels Receiver that was plugged into a 220VAC outlet; it blew the 10amp 125 Volt fuse on the board; no fuses available here; is it safe to say the...
I would say : NO !
The fact tha the fuse blew wasn't because the voltage was too high, but because a component (after the fuse) became defective because of the high voltage. So there will be something defective....
Jul 09, 2009 | Onkyo TX-SR606 Receiver
125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
Mar 14, 2009 | Televison & Video
NO POWER
Viewsonic's are typically well built. Are there any lights on? If you've already sit for a while and then plugged it back in and still nothing, pop the back off again and see if there are any blown (popped up) capacitors on the power supply. Maybe it took a light surge. If there are any bad caps, they usually only cost around a dollar a piece to replace.
We had 2 42" Viewsonic's that get used every day go through a building surge while one was on and it still works great a year later.
Apr 26, 2008 | Panasonic CT-32SL14 32" TV
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Feb 12, 2008 | Pioneer PRO-200 60" Rear Projection...
Power Source
Are you certain the polarity of the connections to the TV are correct? If you connected them in reverse you may have damaged the TV. If there's a fuse in line check that too. BMW
Jun 01, 2006 | Ktv 9BNC 9 in. Television
Hitachi P50H401 50 in. Plasma HDTV Logo
35 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
