Hitachi P50H401 50 in. Plasma HDTV Logo
cody white Posted on Mar 21, 2014
I plugged in my hitahi HD 1080 model #P50H401.52 inch, it made a loud pop at back of plug in on tv.. replaced the 10amp125 volt fuse as it was bad. still no power..what next. also hit reset button. an
Can not see anything obivious
4 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Aug 20, 2009
SOURCE: I have the same problem blue power light blinks 3 times
Ur power board inverter is dead.
U need a new board.
Anonymous
  • Posted on Feb 24, 2008
SOURCE: Hitachi HD 1080 has blue power light on but no picture
Press the reset button...it's on the bottom to the right (underneath the TV). Same thing happened to me.
Anonymous
  • 1284 Answers
  • Posted on Jul 29, 2011
SOURCE: our hitachi tv- hd 1080
The only reset is to unplug the power to the TV for a minimum of 2 minutes then plug it back in and retry
caroldon
  • 17130 Answers
  • Posted on Oct 27, 2011
SOURCE: I have a 42edt41a. The other day I turned the TV
You can use a brush to clean the inside and look for any bits or pieces of component in the board. if so this will indicate the component and the relativity to the POP noise. It can be a capcitor shorting and bursting or even a transistor that has popped. The fuse being blown is due to a failure and it can be SHORT in the board. You need to use a multimeter to probe the +B and trace the short, Isolate the sections and it will lead to the shorted ccomponent.
How do you replace a fuse on the 2011 Panasonic TC-P55VT30 plasma TV?
gently lie it facedown and unscrew the back to reveal the boards and fuses
I need a replacement motor on a KitchenAid Professional HD Stand Mixer (Model KG25H7XSL).
The loud pop was probably the soft start circuit board on the motor. You can buy this board at repair sites or Ebay. And yes, they make 220V versions of this mixer.
http://www.samstores.com/product-kitchenaid-5ksm5ebu-heavy-duty-mixer-for-220-volts-%28cobalt-blue%29-16220.html
Loud pop and then buzzing noice mitchubishi 1080 p
Unplug the set and do not plug back into power until see is opened and examined. It says Mitsubishi here but what is the model number as it is not indicated here.
I have sony full hd 1080 model xbr. Will it work in Israel?
If it is a USA model then you may have problems. First you have a problem with AC power as the US uses 110-120 volts AC while 220-240V is present at the wall outlet there. Next you have incompatible TV signals. Now if all you want to do is view your DVDs then you might be OK IF you convert the power (with a step-down transformer) and the physical plug on the cord with an adapter plug as countries use different cord plugs. So as you can see there are some issues to address. Generally I'd say use a TV from over there.
Mitsubishi VS-50805 HD 1080 Series
check the convergence ic's unplug the main convergence board plug then try the set again if the set comes on get a convergence kit here
http://www.tvrepairkits.com/xcart/home.php?partner=larry
1helpful
2answers
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Pioneer Pro-118 won't turn on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine. Check all three fuses while you're in there.
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
