Question about Kenmore Heating & Cooling
Ac rattles after a few minutes of operation then shuts down for several minutes. then restarts and does the same thing over and over again. wat should i do?
  • scoffin Jun 18, 2009
    thank you for your help. after i posted the problem i took the ac unit out of the window and took the cover off. noticed the condenser was clogged. i cleaned it with a wire brush and now it works perfectly. :)
  • 585 Answers
Believe it or not, it's probably just dirty! With the unit off, apply a spray cleaner or a detergent solution, which can consist of water and a little dish or liquid laundry detergent, to wet the condenser coils, and spray clean with your garden hose. If it;s a window unit, it's probably best to take it out of the window for cleaning.
Posted on Jun 14, 2009
At night its shuts down when the therm is satisfied,but trys to restart right away and when it does start it shuts down right away and just keeps doing this
The thermostat has a differential built into the temperature sensing operation. The differential is normally a degree or more. If the stat shuts down at 72 degrees it should not start the unit again until the temperature in the room reaches 73. If the AC runs and cools properly until it shuts down, I would check the thermostat. The AC can not restart immediately after it shuts off because the pressures in the system are too high at the compressor. It takes a few minutes for the pressures equalize allowing the compressor to start. If the stat tells the unit to start under high pressure, the compressor will shut down on overload. It will start and run after the pressure falls enough for the compressor motor to run.
Jun 04, 2015 | Dometic Rooftop RV Air Conditioner
Chokes down after running about 30 minutes. Will sometimes restart after several attempts and minutes but usually chokes down again within few minutes. I have changed the air and fuel filter, spark blug,...
There are few things that will make the engine run rich, one is the fuel inlet needle in the carb leaking, and the other is a blockage in the exhaust or spark arrestor.
May 14, 2011 | Garden
The unit runs Ok for a few minutes and then shuts down.
Does it do this on just battery power or with an external power source? If on battery poer, then the battery if defective.
- Jim
Jul 20, 2010 | Garmin Nuvi 660 GPS Receiver
Car shuts off at red lights
sounds like a lose ground wire
Dec 15, 2008 | 2002 Oldsmobile Alero
Heating & Cooling Logo
113 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
