Question about Dryers
Maytag Dryer Parts Manual/page-2
Dryer hums when switch is pushed nothing happens
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Sounds like your motor is stoped for sme reason something in blower wheel, or locked rotor
Posted on Mar 24, 2014
catriver
  • 878 Answers
SOURCE: Maytag Atlantis Electric Dryer
Fly, sounds like you blew the thermal fuse. This is located on the front blower. You will need to remove door by removing the two screws and lifting up on the hinge. Remove the 2 spacers on the other side of the door. Now the panel will pull out and the blower will be exposed. The fuse will look like the one on the right of the attached picture....Catriver..post back.
Posted on Jan 27, 2007
ginko
  • 19396 Answers
SOURCE: Maytag Dryer #MDE4000AYW
Try first unplugging power cord from the appliance, this will drain power from circuits and reset it.
Check the door latch sensor, if that is stuck the door sensor will not let the machine start.
Keep pressed start button for 10 seconds or so, on some dryer this reset the machine.
If it still does not work then there is an internal fault , probably the timer assembly must be replaced.
If you need to call a technician you can use the number listed on the owner manual.
If you want to do it yourself, test the timer control, then if it is faulty replace it.
You find replacement here.
Posted on Sep 18, 2008
  • 66 Answers
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Posted on Dec 27, 2009
cool78259
  • 228 Answers
SOURCE: Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Posted on Jul 25, 2010
  • 3074 Answers
SOURCE: Dryer is plugged in and the power seems to be
this may help;
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Posted on Oct 24, 2010
Testimonial: "Thanks a million. Yup, that was indeed very helpful, and exactly what I needed. You directed me to the perfect solution. Thank you, thank you."
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Maytag Gas Dryer model DG882, dryer won't start, motor hums when start button is pushed & drum is hard to turn, but spins free with belt off, as well as motor starts right up. Removed drum, Teflon...
no you would just end up buying a new motor they don't sell the bearing for the motor the motor comes as one complete piece so the motor is running then have you check the door switch if the door switch is broken it will not run sorry a lil confused on your situation the beginning of your post says the dryer wont start and the motor hums if the motor is not moving then replace the motor whereas the end of your post says the motor runs and if the motor is running and when you push the start button nothing happens one of the first things you should check is the door switch message me back with any further questions and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Feb 13, 2011 | Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Dryer does not start. if you push on the start button you can hear a small hum from the area of the timer, otherwise nothing. door switch seems to be working
one  make sure you advance the timer into the heating area of the cycle if you did that and turned it on and still humming you  have a bad motor
Jun 07, 2009 | Maytag SDE3606A Electric Dryer
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
When start button is pushed, hums but does not run. Drum does not turn. Belt is okay
It sounds like it is the motor or a stuck/obstructed blower wheel. You can start by opening the door, push the door switch in, hit the start button & see if you can turn the drum clockwise by hand. This might get it going. if the drum does not move by hand then the problem is probably within the blower. post your findings for a follow up
May 01, 2009 | Dryers
Dryer won't start all the time. can hand start unit.
hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Feb 17, 2009 | GE DBXR463EBWW Electric Dryer
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
Dryers Logo
32 people viewed this question
Top Dryers Experts
