Question about Samsung Televison & Video
Too much glare from screen. hurts my eyes.
Samsung 46 inch flat screen tv.
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Set the back light to minimum. Refer its user manual for details. Gopakumar Gopalan Google
Posted on Mar 21, 2014
SOURCE: lamp going out on jvc flat screen tv 52 inch,how do you change
Versed, you have to open the back panel (cover) to access the lamp. replacing is easy as soon as you can see it. loosen the mounting bolt and pull to unplug the lamp from the SMPS Lamp power supply. Thats it.
Posted on Dec 29, 2007
  • 84 Answers
SOURCE: hdtv lcd 40 in. broken screen face
You can have them repaired using a TV Repair guy but often it costs as much as a brand new tv. My daughter broke my $1,600 LCD. It would have cost $1,200 to fix.. so I just bought a new one.After that I picked up a TV screen protector called TV Armor http://www.tv-armor.com Its designed to protect the TV from damage. Now I dont have to worry anymore when she is playing near it. It works really well.
Eric
Posted on May 04, 2008
  • 11 Answers
SOURCE: How to clean a Samsung flat panel TV screen?
Only with the cleaning cloth provided....
Posted on Jul 31, 2008
  • 4 Answers
SOURCE: LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Posted on Apr 16, 2009
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
Main Board for a UN55b7000wf samsung LED TV
The BN97-03189B board is formatted for the screen size of your tv. You would be trying to install a board meant for a 46 inch tv into a 55 inch tv. It just wont work.
Aug 19, 2016 | Samsung Televison & Video
Model Le46M51B samsung flat screen TV clouding
sounds like your screen is separating. If you tv is less than $1,000 prob not worth fixing
Nov 15, 2013 | Samsung LE46M51B 46 in. LCD Television
My 46 inch samsung has a picture distortion, it's like it has a mirror image , how can i fix this?
Anthony, you did not list a model #. If you would it makes it eassier to determine what may have happened with your Samsung TV. An LCD would start with LN46----.
I have had screen issues with some samsung product. As well as other makes of televisions that use Samsung 46 inch dislay lcd.
Mar 02, 2013 | Samsung LN-T4661F 46 in. LCD HDTV
Samsung 46 inch lcd no picture only sound
Could be backlight or the Invertor. While the sound is operating shine a flashlight into the screen and see if you can see the picture or not then let me know and I will assist you. But I will also need the model number of the set.
Feb 08, 2012 | Samsung Televison & Video
How to fix real bad glare on new toshiba led/lcd tv 46sv670u
I would not recommend to remove it, if you are removing what I think you are removing then this will void your warranty.
but if it is just plain plastic like on this picture
Then you are supposed to remove it.
if the so called "protector" is not like on the above picture, then you are not supposed to remove it.
Apr 13, 2010 | Toshiba REGZA 46SV685D 46 in. LCD TV
Cracked 46 inch screen on my Samsung tv. Where can I get a good deal on replacement? Or can it be repaired? Please help Model number is LS46BHPNB/XAA
You can go to Encompass or J&J electronics for the Panel. But If you have never replaced a Panel before, it is best left up to a trained Samsung tech.
Jul 08, 2009 | Samsung LN46A650 46 in. LCD HDTV
Glare is too much for my eyes, need a glare guard.
You can purchase a glare guard from 3m, available from cdw, tigerdirect, dell, 3m etc.
The price ranges from around $53 to $90 but you might find cheaper.
This is one model but there are several
3M™ EF200LB Anti-Glare/Radiation Computer Filter, Black Frame
May 18, 2009 | Gateway FPD1975W 19" LCD Monitor
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
