Clunking sound on spindown
Sears model 417.94712400 washer/dryer making a clunking sound on spindown only, otherwise it is fine. transmission going?
  • 1314 Answers
SOURCE: loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Posted on Jan 11, 2008
wehrhard
  • 3 Answers
SOURCE: Washer makes clunking noises.......
You didn't give to much detail about the noise, other then clunking. Does it sound like it's metal against metal? Does it sound hollow? When does the noise take place before, during or after the spin cycle.
The easiest thing to do is check to see if the motor is loose, or if you might have too much slop or slake in the belt, if you do then replace and readjust the belt.
Posted on Nov 16, 2008
huuum
  • 750 Answers
SOURCE: Washer makes noises
You said, when the washer is going into spin cycle it makes a loud clunking noise. You are wondering if this could be the brakes or possibly the pump?
Sounds like this!
Faulty direct drive Coupling (Whirlpool / Kenmore / Roper / Estate)
The direct drive (motor) Coupling may be broken. Many Whirlpool/Kenmore brands washing machines utilize a small, relatively inexpensive direct drive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other.
It can wear out over time or fail under overloading conditions. This protects your transmission from excessive loading.
it can also be a broken spring or strut dependping on your washes make and type
Please remember to leave a rating
Posted on Nov 21, 2008
michiganfan9
  • 179 Answers
SOURCE: Frigidare Washer Drum making noise when in spin
it is your bearings you need to replace both tubs and the basket but it will be cheaper and easier to buy a new machine to rebuild your washer it a pain in the **** because you need to take the whole machine apart. if you do decide to rebuild it make sure that you have someone else there to help the tub is bulky and has some weight to it
Posted on Dec 26, 2008
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Making loud knocking/clunking sound in the wash cycle.
i have the same problem. the transmission/brake assembly is worn out. the stopping and starting problem... I have that too, that was a dry solder joint on the circuit board. i found it because if I pressed on the area of the panel to the left of the cycle select knob, it would shut off immediately. I soldered it back up and it's fine. Still working on fixing the transmission problem, the parts store wants 300 bucks for the part but looking at the GE website, the tranny might be under extended warranty.
May 03, 2009 | Washing Machines
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
98 Jimmy 4WD clunk
It seems like no one else hear at FixYa is responding yet to both your requests about clunking in 4wd.
I see two requests....in the first a 2000 blazer from Gloeckz
there is a rapid clunking in 4wd!
In the second it clunks hard going in then won't drive!
This is rayenc11s' 98 Jimmy 4WD clunk I'm no trans specialist and not familiar with repairing or troubleshooting serious 4wd problems but it sounds like this may be a problem in the transfer case.
Since no one seems to be helping you but me I'd suggest you go to a transmission shop and ask them if this is a common problem that may lead to a bad transfer case if not corrected!
Make sure you have the proper fluid in your transmission case, transfer case and differential case first or have a quick oil change place check it for you!
Hope this is helpful.
Good Luck!
c04bf14.jpg jackiaria
Jan 05, 2009 | 2001 Chevrolet Blazer
Nov 16, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washer makes noises
Sounds like this!
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Makes clunking sounds & throws belt off pulley.
I think you have the answer. I suspect it will be the bearings that have seized up. Or possibly the spyder / drum axle broken
Oct 19, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
