Question about LG Goldstar SP520 Cellular Phone
Goldstar 932 Radar
Stays in stand-by. Keeps beeping, Antenna not rotating. Clic on "Menu", beeps faster, and "SB" flashes on the screen
When I access the menu by holding select to change to remote or SU-4 mode the flash crashes/freezes and I have to take the batteries out. Also when you go into SU-4 mode it lets out a beep sound and it...
Did you try to reset all settings as told in the manual on page 12?
Press the (mode) and (on/off) buttons simultaneously for
approx. 2 sec. to reset all settings, including the custom
settings (except the distance unit selected in m/ft) to
their default values.
If the problem stays, please check you finnished your repais correct. (nothing lose in the unit and no cables switched, no false connections)
Oct 30, 2013 | Nikon Speedlight SB-800 TTL Flash
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
Won't open the overlay screen
You must have a heading sensor input for radar/chart overlay. (i.e. PG500)
Jun 19, 2010 | Furuno NavNet vx2 1934CBB/NT GPS Receiver
Error SB SIG MISS on FURUNO CRT radar?
Either your reed switch is bad or your antenna is not rotating. You may hear the motor spinning but that does not mean the array is. If the array is not spinning make sure the belt did not come off the motor. Start there.
Jul 05, 2009 | Furuno 1715 LCD Radar System GPS Receiver
It sounds like voltage loss could be your issue. You need to find the "Y" cable under the dashboard and measure the voltage at the point where it connects to the main 12V supply. Keep the meter on and then spin up the radar. If there is a fuse (there should be) make sure you are measuring on the radar side of the fuse. If the voltage drops off as the radar slows, you have found your problem. If the voltage stays constant and the connections are sound at the terminations in the radar pedestal, I would recommend you send the pedestal in to Raymarine.
May 11, 2009 | Boating
Lexmark c530dn red light on
Operator panel display blank, five beeps, and LED off
Service tip: The printer has detected a problem with the system card, the operator panel assembly cable (part of
the top cover access assembly), or the operator panel assembly if POST does not complete. The printer emits
five beeps, and sticks in a continuous pattern until the printer is turned off.
Is this what you are getting?
Mar 12, 2009 | Lexmark C530dn Laser Printer
Beeps and says service required
This message occurs if your V995 can't properly calibrate its internal circuitry for the antenna. As the message implies, you need to send in your V995 for factory service.
Jan 02, 2009 | Vector 995 Radar Detector
I have a k 40 stealth mounted radar unit - it keeps faulting and giving me beeps like every 30 secs
if the beep is one beep every 30 secs then the front radar detector is defective. If it beeps 2x every 30 secs the rear radar detector is defective. If under warrantee you are good. If not, take to any dealer and cost $225 to get it replaced.
Dec 15, 2008 | 2000P Radar Detector
Sb-600 not beeping, images completely black (underexposed)
Series of images is the KEY. If the Power you set the SB-600 is HIGH it will take a LONGER time to recycle than the SB-800. If you try to take a photo before the SB-600 is ready you will get a dark image. The randomness you get is due to the time between shots. In general try to run remote flashes at a lower power so they recycle faster.
I like the SB-800 because it can take 5 cells. 5 cells can really make a difference in the recycle time (faster) The SB-600 only takes 4 cells so it is slower.
Apr 04, 2017 | Nikon Speedlight SB-600 TTL Flash
LG Goldstar SP520 Cellular Phone Logo
18 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
