Question about Panasonic Original Pansonic Tv Vcr Dvd Remote Control Ur76ec2803-2 Condition 7.8/10
Palsonic problems Keeps loosing all the channels goes great for 3 weeks then stops
  • Panasonic Master
  • 5,309 Answers
Most remote problems are caused by the batteries dying. I suspect that in your case the remote is fine and device you zap with it has the problem. Some VCRs use a chip that has memory circuit, which is powered by a small capacitor called a memory retention capacitor. When these fail, the power to store the details of the channels is lost. I can put a picture of one of these capacitors up, you then just have to try and find it in the device!
Posted on Mar 23, 2014
  • nargis751
    nargis751 May 24, 2015
    where can I buy one from in the UK? What is it called
I have a palsonic TFTV826HD tv and when i came home from a 2 week holiday , i am not able to receive the ABC and ch 10 stations , others i have , i reset and did the auto tuning
Do you use an digital antenna receiver which gives you a couple basic air channels for free Or is it through a cable company? It could be the weather conditions or the antenna could be unplugged or cable wire could be loose or cable company could have certain channels being fixed.
. We have a big Element HD tv flat screen and use an digital antenna receiver and when receiver is unplugged or if our outside/entry way doors are open (receiver antenna is outside) none or some of channels won't work..
Hope this kinda helps :/ :) let me know.at least I tried lol
Feb 01, 2017 | Televison & Video
I have a Palsonic tv and it keeps turning off ,what could be the problems
There might be some loose solder terminals at its main power regulator board.
Dec 01, 2012 | Televison & Video
Screen goes blank and standby light keeps flashing red
How to fix ps3 yellow light of death 3. tips first
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work, then there are 2 options left for you on how to fix your ps3 safe and fast!
Send your playstation 3 back to Sony
You might think that this is an great option, but take a look at some statistics. Most users had to wait at least 4-6 weeks before they had their Console back. And also, if your warranty is expired, you have to pay a big fat $150,- to get the job done! Does this still sound as a good option?
Jul 27, 2010 | Sony PlayStation 3 40GB System
Channles are going out one by one. Fixable?
Plug one of those speakers into a different channel. Like if you plugged the center or rear channel into one of the front channels and vice versa. This will narrow down if the actual speaker is bad or the channel on the amplifier inside of the sub is going bad. If the speaker is bad, you can see if AL sells replacements, if the amp is bad, a repair shop will probably charge more to fix it than what it's worth. I use a 5.1 Logitech that goes for $69 that's great. It might be time to check into another setup.
Nov 20, 2008 | Altec Lansing ADA995 Speaker
Code for Palsonic 6830TG TV
if the volume down ts working then that means the remote is working if the volume + does not work and the channel + then they need to be cleaned with isopropyl alcohol using a cotton swab, that means you will have to open up the remote control
May 27, 2008 | One For All URC 7740 Remote Control
Codes for palsonic televisions
Hi, that TV is not listed in the code list for your model.. You can try an automatic search by doing the following:
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
remote control is in programming mode
3. Press and release power. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
For future needs, here is the link to your manual:
Bookstone 538744 remote manual
Apr 12, 2008 | Brookstone 538744 Remote Control
Channel keeps changing
It sounds like a stuck button or switch. What happens when you hit the channel DOWN, does it still keep scrolling down?
Is this with or without the remote?
Have you tried it with the remote and or the TV?
Let me know whether you are changing the channels with the remote or the buttons on the tv and I can try to give you a couple more suggestions.
Mac =)
Feb 12, 2008 | Televison & Video
Resets
this always happens to me when my battery wiggles loose. the little sliding catch that holds the battery isn't such a great design, and it easily slides out of it's "locked" position (particularly when i use the heavier extended-charge battery). resultantly, the battery momentarily disconnects and freaks out the operating system. this will happen even when the phone's in a travel case which i thought would hold the battery in place. But the amount of battery movement required for a disconnect is extremely slight. my resolution has been twofold: 1) i diligently backup everything to a 1GB SDcard weekly (they're very inexpensive now) using a great program named SPB Backup (very reliable); 2) i adheared a few pieces of clear plastic to the phone where the battery installs--this causes the battery to wedge more tightly against the sliding lock, and thereby keeps the lock from sliding loose. this hasn't been fullproof, but has cut down from several reboots per week to maybe once every 3 months.
Jan 24, 2008 | Siemens SX66
Can't change channels!!!!
take the batteries out of the remote...now check if you can change channels manually on the big screen. if so the remote is stuck on one signal that channel u said. get a new remote. if still same trouble on big screen look hard at the buttons and make sure none are jammed. also try to get to your setup menu and auto-program the channels it should search everything and then try changing channels. new stuff alot times plugs come loose, goes back to the factory workers...not pushing them tight have a tech check that at your home.
Aug 18, 2007 | Samsung PCJ522R 52" Rear Projection...
Panasonic Original Pansonic Tv Vcr Dvd Remote Control Ur76ec2803-2 Condition 7.8/10 Logo
200 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
