Question about Brother MFC-7420 Printer
Black lines in copies and fax's Brother MFC 7420
Black lines when copying and faxing.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Posted on Jun 14, 2009
How to turn off the fax?
Use a cancel button. Press the button for another function (copy scan, print pictures from a flash card. Turn machine OFF and ON again. If the telephone line is not connected to the MFC, the fax will not work.
Oct 13, 2013 | Brother MFC 7420 All-In-One Laser Printer
How to disable the fax?
I am getting a light duplication on my copies half
The duplication problem can be either the drum or the fuser. Most likely your drum needs to be replaced. If you can measure the distance between the first print and its duplicate I might be able to help more.
thanks adi
Dec 15, 2009 | Brother MFC-7420 Printer
Getting a line on copies - not on faxes.
If the line is present on everything you print out it is most likely a scratch on the drum.
Aug 12, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 Fax/Copier-Black copies
Check your owner's manual, and there's one in the install disk. It will show you where there are electric contacts inside where the drum is. You may have to take the drum out to see them. You're supposed to clean them with isopropyl alcohol on a q-tip. Don't get alcohol on anything else.
Apr 15, 2009 | Brother MFC 7420 All-In-One Laser Printer
Won't fax
You have to get your answering machine and your fax to play nice. Read the instructions for both. I think I have my answering machine to pickup at three rings, and the fax to pick up at five. Don't have the fax answer first. Don't have both machines answering at the same number of rings.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
My brother mfc7420 won't send or receive faxes.
please give me more info! what is on the screen? i am a brother tech, i will try and help you but i need mmore info.
Dec 16, 2008 | Brother MFC 7420 All-In-One Laser Printer
Vertical lines on photocopies/faxes
The MFC-7420 Manual recommends cleaning the scanner glass and white plastic bar above it with isopropyl alcohol. Page 11-22 has a diagram.
I am having a similar problem but cleaning it did not work. But try that first.
Oct 15, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
Open Questions:
See all Brother MFC-7420 Printer Questions
Brother MFC-7420 Printer Logo
1,874 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
