Question about Maytag MER6775A Electric Kitchen Range
Lower oven gets really hot and then shuts down
Lower over overheats
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Temperature light won't shut off after oven top cools down?
the preheat light wont go off on my oven, and its not really hot. my oven light is on as well ,how do I turn off the preheat light
Nov 30, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
The oven is taking forever to heat to 250...The broil works and the stove works...The oven will not heat above 250 on regular bake mode
Sounds like the bottom element is not working, Check it. If it is, there is a high limit, that shuts the oven off it it overheats. When they go bad, they shut down at lower temps. Sounds like that might be your problem
Mar 31, 2010 | Maytag MER5755QAS CleanDesign Electric...
Too hot
I wish my m/wave was this powerful. try reduceing the time 1200 watts is a lot of power. may your used to a lower powered modal
Apr 13, 2009 | KitchenAid KCMS1555RSS Stainless Steel...
Samsung smh7150 shuts down after a few minutes.
If the mag overheats because its not being cooled it will shut down until its cool.
If the fan is turning slow you can try oiling it but it likely needs replacing.
Another thing that causes this is that the exaust port is blocked because its upagainst the wall and the hot air can not escape.
Jan 12, 2009 | Samsung SMH7178STD Microwave Oven
Error code F03
although i don tknow what model your talking about all the F3 codes in ovens is pointing toward bad oven sensor, replace oven sensor
Mar 16, 2008 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
Kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Sep 06, 2007 | KitchenAid Architect Series KEBC208KSS...
Maytag MER6775A Electric Kitchen Range Logo
59 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
