Question about Frigidaire Freezers
Not cold of on the door
  • Official Brand Answer
  • 2,267 Answers
Good Morning renee kelley, this is Z. I am happy to assist you!
Good Afternoon Jason, thank you for allowing me to assist you!
I understand your Frigidaire freezer is not cooling and displaying "OFF" on the door. It appears that the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
Posted on Apr 03, 2014
  • Frigidaire
    Frigidaire Apr 03, 2014
    Hi again Renee, my apologies - while my response is intended for you, I accidentally addressed Jason from another question on a separate page as well. Please forgive my error. Best - Z
I Have A Freezer Model Fuf17svrww.the Door Open Light Control Is On And Sounds and the door is completely close
Check the door switch is being closed when the door closes. The door may have dropped just enough to allow the switch not to be activated by the edge of the door.
Apr 18, 2014 | GE FUF17SVRWW Upright Freezer
Whirlpool fridge door "drops" into place when opening.
are both door leveled? if not the door cam worn out and need replacement
Nov 23, 2017 | Whirlpool GSS30C6EYW 30 cu. ft....
The door does not close on its own
You might want to check the bottom of the door and see if its dragging and make adjustments if it is. Also there are plastic cams at the door hinge pin area that are supposed to help the door close. They get worn and may need to be replaced. You can lift the door off of the hinge pins and inspect them. hope this helps and good luck.
Feb 10, 2014 | Kolpak Freezers
What is benefits of sliding doors?
There are several benefits of sliding doors. I have shared 3 main benefits of sliding below.
1. Size of the door- The large size of the door is one attraction of the sliding door.
2. Space- You don't need to spare huge space in your home to install these doors. On the other hand, as the doors do not swing open and close, you can confidently place the art crafts near the door.
3. Transparency- Sliding doors are always the best ones to be installed in your patio. For you to enjoy the beauty of the surrounding landscape, no other type of doors would be apt like glass sliding doors.
For more information about sliding doors. I would like to refer at http://www.lghausys.com/in/product/windows/124nd_sliding.jsp
Oct 26, 2013 | Caravell 5.5 cu. ft. / 156 liter Chest...
Freezer is level but door is not. matching frig. is level and door is level doors then do not match across both doors. is there an adjustment on freezer door that can be done?
Please check the doors hinges/supports. Loosen the bolts of abnormal level door, adjust the level and tighten the bolts. If it is not work put a metal sleeve on support shaft ( It may wear down already)
I think that all you can do to re-level the door.
Dec 06, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Freezers Logo
108 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
