Question about Sears Kenmore Elite Gas Dryer Front Load Steam 8.0 Cu. Ft
I have a Kenmore Elite Gas Dryer that will not heat. I replaced the coils and the flame will not stay on for long
The burner fires and the flame won't stya on long. I did replace the coils, but the same problem occurs
  • 44 Answers
You need to replace the flame sensor.
Posted on Mar 21, 2014
I have a Kenmore Elite Oasis gas dryer Model # 110.77052600. The gas and electrical supplies are ok. I have no flame or glow at the burner. What are possiable causes?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
I have a model 110.92832100 Kenmore Elite gas dryer that has stopped drying. i found a penny welded onto the Thermal fuse, so I replaced it and while I was in there I replaced the thermostat. When the...
Since you are already this far you have some knowledge of how you dryer works. What is wrong now is the heat sensor that picks up that the pilot is on. The pilot should burn at a steady flame when you turn the dryer on to heat this in turn heats a probe next to the piolit this is a type of heat sensor. When the probe or heat sensor senses heat it tells the gas valve that its okay to turn on. Have a great day and hope this helps.
Aug 19, 2010 | Kenmore Dryers
Gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
May 04, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
Kenmore gas dryer not heating up
ck/replace the 2 black coils on valve they will sometimes fail after 1st start up slight chance it may be flame sensor mounted on side of burner to ck remove the 2 wires and short together temporaily if flame stays on and reignites ckd vent system first bad flame may cause sensor to shut it off if flame/vent ok replace sensor
Nov 27, 2008 | Dryers
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer
Check to see if ignite is glowing and then goes back out. If it does, it probably needs a set of burner coils. If it glows but doesn't go out, it probably needs a flame sensor. This is box on side of burner tube.
Nov 14, 2007 | Kenmore 74602 Gas Dryer
Sears Kenmore Elite Gas Dryer Front Load Steam 8.0 Cu. Ft Logo
96 people viewed this question
Top Sears Dryers Experts
Dan Webster
Dan Webster
Andrew Taylor
Andrew Taylor
Are you a Sears Dryer Expert? Answer questions, earn points and help others
