Question about Weedeater 25cc Gas Blower ()
I put reg gas in it & it ran rthen quit now the cord will not pull
Gas did not have oil in it, just ran for a few mins then it quit. I poured the gas out & put the gas & oil mix in but the starter cord will not pull
  • 1,162 Answers
Could have scored the rings, broken ring, or just cooked the piston to the sleeve, maybe melted the connecting rod to crank, damaged needle bearings. Most likely needs to be taken apart.
Posted on Mar 24, 2014
2010 F 150 oil light warning and wont accelorate
get you a gallon of marval mystry oil drain your oil and filter put a little mystry oil in your old filter rinse it out put back on and oil plug too fill with mystry oil crank truck let it run for 3 min let cool of drain put in new filter and oil if problem still accelorate and oil light still stays on you might have problems with oil pump if oil light goes out and still problems accelorating try changing fuel filter if this doesn't do the job also crack you truck up (if it is carberated carb) take air fiter off carb intake pour a little mystry oil in carb very slowly while running this helps to clean deposites due this for about little at a time you will hear motor sound like choking stop let motor catch up do this for about 3-5 min then pour mysry oil in till motor dies let set for 3 min start motor them put gas treatment (STP) in gas tank this should do the job if you have furl injestion put one cup of mystry oil in gas tank and one bottle of (STP) and atleat 6-10 gal of gas. if this doesn't do the job you may need to tale the truck to a spec.
May 27, 2014 | 2001 Ford Focus
Need help starting a gx340 honda with new ring kit ,honed cylander,lapped valves,adjusted valves with new ex valve seal.started warmed up and changed throttle level from low for 10 min to med for 10 min...
If there is air in the tanks, it will be harder to crank, drain air out before starting, Also check spark plug. Sometimes i put gas where the plug goes, just a little pinch of gas though. put spark plug back and give it a few cranks.
Oct 02, 2013 | Honda Jenny GT8HGB-30P 8hp 30 Gallon GX...
Starts up fgor few minutes then shuts off
Clean or replace air filter. Ensure oil is full. 30w. Remove bowl from bottom of carb & clean. Clean carb.
Sep 07, 2013 | Cub Cadet Garden
Yardman blower jut quit running like it was out of gas, restarted then did the same thing, now its difficult to pull the cord to strt
I'll guess and say that the carb flooded the engine and you have hydro lock.Pull the sparkie and clear the extra fuel.
The carb is at fault,IMO.
if the needle get a little dirt in there it will hold the float open and flood the motor.
Dirt.
Nov 16, 2012 | Yard Man Mulchinator QuickShift BlowerVac...
We started the snowblower 2 weeks ago now it will not even turn over, the cord wont budge either
Have you tried pulling the spark plug out? If it still will not turn over, then quite possibly if it is a 2 cycle the gas mixture wqas not right & it got to hot. Try putting some Marvel Mystery oil in spark plug hole 7 let it set for a while then try pulling the cord. I have gotten them to loosen up with this process. Make sure gas mixture is correct before trying to restart.
Dec 27, 2010 | Garden
I put gas in the oil and oil in the gas can it be fixed
As far as gas in the oil I presume you are talking about bar oil. I wouldn't worry to much about that. Empty out all you can and refill with bar oil. With oil in the gas I would drain all I could out of fuel tank,then remove sparkplug and pull srarter rope several times. With plug still out i would pour 1-2 ounces of of gas into plug opening and let it set for a few mins.,then dump out remainging fuel. Once again I would pull starter rope several times. Reinstall plug and refill gas tank with proper fuel oil mix. Try to start. If you're lucky you can get it to fire and burn off excess oil in afew pulls. If you can get it started I would run for just a couple of mins,then shut off and drain gas again. Hope this helps. Thanks.
Nov 13, 2010 | Poulan Pro Chain Saw 46cc 20"
Long storeage of troybuilt gen
i have had my generator for 6 years. i use fuel stabilizer and do as you did in shutting it down. I do not drain my fuel but it doesnt hurt. I would question putting anything in the engine that could in time cause problems. I use synthetic oil, this should coat all internal parts well enough to not need extra oil. I do start the engine a few times a year and let it run 5 mins. or so. I live in SW La so having a generator that doesnt work during hurricane season is not a good idea. The steps you are taking should keep your engine fine. It is a good idea to run it and use the power every now and then. This keeps the magnets in the generator in good shape.
Oct 12, 2008 | Electrical Supplies
Weedeater 25cc Gas Blower () Logo
152 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
 steve
steve
Thomas Perkins
Thomas Perkins
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
