I bought air time on 3-17-2014 did not register
941-416-0990 I bought air time 3-17-2014 it did not register phone does not work 941- 416-0990
Phone won't register paid air time
Contact Tracfone for assistance.
Mark
Motorola Support
Aug 11, 2014 | Motorola Mobility TracFone C139-4 Cellular...
My vtech dect 6.0 phone says not registered how do i fix it
I came on here to look for the same solution but it didn't take my comment and so I am sharing what I did from my research, If it says Not registered, press and hold the page button on the base and in about 4 seconds the In Use button will be lit. Release the page button and press the # button. You may have to try this a few times. The first time I tried it, it said Failed. I took the battery out, unplugged the phone from the wall and started all over again. Good luck.
Jan 26, 2011 | Vtech DECT 6.0 Digital Cordless Phone
CIT310 - registration problems with the base
use the pager button, keep it pressed for about 15 seconds, and then use the register option from the phone, handset will pick up the signal. You may have to do this multiple times.
May 27, 2009 | Linksys CIT310 IP Wireless Phone
NEED TO DEREGISTER LOST HANDSET
The "END" and "#" key combination can be used for several purposes:
1) If wanting to use an ALREADY REGISTERED HANDSET on an alternate base, and if if the INITIAL BASE isn't available to deregister the handset:
1a) Press "END" + "#" until it for 5+ seconds (wait for it to beep)
1b) Choose the "Base Unavailable" option
1c) That'll deregister the CURRENT HANDSET so that it can be re-registered on ANY base.
2) If a BASE has a handset registered to it which you no longer want registered but the registered handset is missing or broken:
2a) Grab another WORKING handset which is properly REGISTERED to the BASE in question
2b) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
2c) Choose the "Deregister HS" menu option
2d) Pick the REGISTERED HANDSET # to de-register. (Every other registered handset EXCEPT THE ONE YOU'RE ON will appear in the list!)
May 08, 2009 | Uniden TRU8866 Cordless Phone
I bought a GE 24 GHz desk phone (27936GE-A) with a removable handset (27936GE3-M), serial #20056798. Speaker phone works fine, handset just beeps 3 times, but doesn't work. Any tips?
If the battery is fully charged, You probably just need to register the handset Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} to the base by following the instructions in the user's manual.
Sep 12, 2008 | Lands Phones
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
No signal
3100 Network Problem
Apr 16, 2008 | Nokia 3100
VT 2461 Won't let me register new handset
jimmackey
were you ever able to register the additional handset? I have the same problem with 4 handsets, one broke and I bought 2 new vt2420 handsets. The unit wont register handset #3 (the one that broke). Would love to know if you were able to resolve the issue?
Oct 11, 2007 | Vtech VT 2461 Cordless Phone
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
