Question about FreeMotion 310R Recumbent Exercise Bike
Resistance on peddle is inconsistant
As the peddle travels forward resistance sporadically halts causing a lurching forward motion.
Why can we only peddle backwards. When we peddle forward, there is too much resistance.
Your resistance motor can be bad, the magnets are full expanded and stopping the forward movement.. You need a crank remover to take the body covers off to inspect the resistance motor.
Mar 01, 2015 | Nordic Track NordicTrack - GX 2.5
Renault megane cc problems
possibly low on fluid.that would be first to check
Aug 25, 2014 | 2007 Renault Megane 1.4
2003 Jaguar s-type lurching problem
can you discribe the lurching in more detail ie is it when you come to a halt, pulling away or when it changes gear ?
Jan 18, 2012 | 2003 Jaguar S-Type
I want to know how to tell if i need a new clutch as compared to a slave cylinder, car has only 99k, and i bought it as is, owner said it needs slave cylinder, how can i be sure????
Put the car in first and start it up. If the car want's to lurch forward then the clutch is working but not disengaging. Look toward the slave/master cylinders or even the pedal itself. Pontiac used aluminum clutch pedals and they bend over time, hitting the floor before giving you the full length of travel. This causes the clutch to not disengage. 50 bucks at Fierostore.com.
If the car doesn't lurch or the RPM's go up while in gear and clutch out, but the car doesn't go any faster then the clutch is slipping and needs to be replaced.
Good luck,
Rebel Faggioli
Aug 05, 2011 | 1986 Pontiac Fiero
Bicycles....? How have bicycles in the years prior been improved in terms of motion?
The below are improvements over the years. One thing to remember that a HUGE % of the energy the rider puts into moving forward is used to overcome wind resistance.
In terms of motion....
Lighter overall. Lighter bikes overall, lighter wheels - easier to spin up and keep rolling.
More efficent bearings all around/ wheels cranks, etc.
Better design of frames/bars, etc. Positions the rider better on the bike to convert his energy into forward motion Also - better positions the rider on the bike to cut the wind better - lower rider resistance.
better tires, skinner tires - Less rolling restiance -
Dec 21, 2010 | Cycling
98 Chevey malibu 3.1 (lurching)
Sounds like your timing Belt has chipped a tooth... i would suggest getting it replaced ASAP
Jan 24, 2009 | 1998 Chevrolet Malibu
Jetta v6 lurching and almost stalling
When something in the car's faulty and a sensor picks it up and tells the computer, the computer will cause the car to do exactly that. Could be anything, from a damaged air intake sensor to the breaks.
Have your car connected to a computer and let the computer do the talking for you.
Jun 20, 2008 | 1997 Volkswagen Jetta
FreeMotion 310R Recumbent Exercise Bike Logo
128 people viewed this question
Top FreeMotion Exercise & Fitness Experts
Howard
Howard
ray gallant
Are you a FreeMotion Exercise and Fitnes Expert? Answer questions, earn points and help others
