Paperpro stapler Looking for a high-capacity stapler that can staples 20-50+ pages centered in 8 1/2 x 11" paper for making homemade booklets of 5 1/2 x 8 1/2" size.
brainyass
  • 242 Answers
SOURCE: Stanley TR70 Manual Stapler won't accept Arrow 1/4" staples
It sounds like you have a light duty stapler and are trying to use heavy duty staples. 1/4" refers to the length of the legs not the thickness of the actual staple. You probably just need light duty staples.
Posted on Oct 23, 2008
Kevin Hayes
  • 167 Answers
SOURCE: Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Posted on Feb 17, 2009
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
Posted on Mar 14, 2009
  • 384 Answers
SOURCE: what size staples do I need to use on the
The gun uses "T50" staples. Buy them at any hardware store.
Posted on Jun 17, 2009
SOURCE: Staples penetrate, but do not bend
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Posted on Jun 25, 2009
My brand new stapler suddenly stopped folding the staples. It just shoots out singles; good for bulletin board posting-not for stacks of papers. Can this be fixed?
The item on the bottom that folds the staples has two positions. Press it up from the bottom and swivel it 180 degrees to folded staple setting.
May 13, 2016 | PaperPro Compact Stapler, 15-Sheet...
My stapler won't wrap staples around the paper. What can I do?
Amazon.com : The Classics Staple-Free Stapler the "Paper ...
www.amazon.com/The...Staple-Free.../B000IGCUZE
Amazon.com, Inc.The Classics Staple-Free Stapler the "Paper Grip" with 5 Sheet Capacity, Kid Safe (TPG-133). by The ... Gift-wrap available. Enter your ..... It is hard to get the correct pressure on the paper--too much and it tears, not enough and won't fasten.
PaperPro Prodigy One-Finger Desktop Stapler, 25 Sheet ...
www.amazon.com/PaperPro...Stapler/.../B000GGY9L...
Amazon.com, Inc.
Rating: 4.4 - ‎399 reviews
Gift-wrap available. ... One-Finger Stapling Technology only needs one finger to stapleup to 25 sheets ... The Paper Pro Prodigy Stapler is the most distinctive, powerful non-elictric stapler available. .... This is such a great, easy to use, and quality stapler that once you use it, you won't want to use a ... A near-great stapler.
Swingline® Full-Strip Stapler, 15 Sheet Capacity ... - Staples
www.staples.com > Office Supplies > Office Basics > Staplers
Staples Inc.Stapler can easily handle up to 15 sheets of paper at a time and has ... refill this Swingline stapler with a full strip of standard office staples, so it won't run out of ...
Staples One-Touch™ Plus Desktop Flat Stack Full Strip ...
Jan 10, 2016 | Swingline 87845 Optima ® 40 Desk Stapler
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
Paperpro stapler fix
Use one single staple pin cartridge however small.the pushing spring should keep the staple aligned
Aug 03, 2013 | Office Equipment & Supplies
Is there a stapler that can staple over 100 papers, or do I need special eqipment?
Yes, there are some heavy duty staplers that can staple more than 100 sheets: http://www.amazon.com/PaperPro-1300-Stack-Master-Stapler/dp/B000MIJAKG
http://www.amazon.com/Economy-Heavy-Stapler-Sheet-SPR01315/dp/B001D1RO3G
Jan 24, 2013 | Office Equipment & Supplies
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
What kind staples p300 stapler brad nailer
Staple Size 3/8 in. Crown Width, 1/4, 5/16, 3/8, 1/2, 17/32, 9/16 in. length
Brad Size 18 gauge, 3/4, 1, 1-1/4 in. length
Magazine capacity 100 staple/brad
These are sold at Lowes and other lumber centers.
Oct 14, 2011 | Ryobi P300 One+ Stapler Brad Nailer
How do I replace staples in the Konica Minolta Bizhub 600?
The saddle stich or the booklet??? saddle stich is like church program with staples in the middle. Booklet is staples on the left side of the paper or the corner stapler to different staplers and depends on the finisher model?
Aug 08, 2011 | Minolta Office Equipment & Supplies
PaperPro 1110 Prodigy metal stapler Has ceased up. How do you open the top to access the mechanism? thanks Gerard
My PaperPro Prodigy stopped firing staples. Examination of the hammer mechanism was fine. (apparently sometimes an internal part can break) Check with stapler opened and no staples. Hold the safety lock pin down with a fingernail or sticky tape so you can check operation of the hammer mechanism. Should withdraw to clear staple compartment and then fire. If this looks good, examine the roof of the staple compartment. Mine had a little lump of brown grunge in the roof of the staple compartment next to the hammer - stopping the staples from sliding up into firing line. Scraped it out and works fine again.
Apr 02, 2008 | Cell Phones
54 people viewed this question
jasbo
jasbo
