Question about Toys
Missile schwinn Motor hums appears to be locked up need replacement motor
yalmer
  • 552 Answers
SOURCE: need replacement motor
Before trying top replace anything, make sure you have power at the motor from the cord.
If you have no way to check for power, unplug and change the cord to any other you have around.
That will assure that the cord is good or bad.
Posted on Feb 16, 2008
  • 249 Answers
SOURCE: Washer motor hums....
have you tried the timer switch?
Posted on Jun 19, 2009
c17hydro
  • 2984 Answers
SOURCE: Ford Taurus 1999SE-Windshield wiper motor just hums.How to fix ?
Removal & Installation To Remove:
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Disconnect the battery ground cable.
  3. Remove the wiper arms.
  4. Remove the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to remove.
  5. Remove the cowl vent screens.
  6. Disconnect the electrical connector from the wiper motor and remove the 4 bolts that mount the module assembly to the cowl.
  7. Remove the windshield wiper module from the vehicle.
  8. Rotate the wiper operating arm in a clockwise direction to gain access to the bolt retaining the arm to the motor. WARNING
    Always rotate the wiper operating arm in a clockwise motion or damage to the motor could occur.
  9. Remove the nut retaining the wiper operating arm to the wiper motor.
  10. Remove the three wiper motor-to-wiper module assembly retaining bolts and remove the motor from the vehicle.
To Install:
  1. Position the wiper motor on to the module assembly. Install the three wiper motor-to-wiper module assembly retaining bolts. Tighten the bolts to 115-151 in lbs (13-17 Nm).
  2. Position the wiper operating arm on the wiper motor output shaft. Install the mounting nut and tighten to 22-29 ft-lbs (30-40 Nm).
  3. Position the windshield wiper module onto the cowl. Install the mounting bolts and tighten to 106 in-lbs (12 Nm).
  4. Connect the wiper motor electrical connector.
  5. Position the cowl vent screens onto the inner panels. Install the 8 plastic retainers and the 6 clips holding the cowl vent screens to the inner panels. Turn the retainers 1⁄4 turn counterclockwise to install.
  6. Install the wiper arms.
  7. Connect the battery ground cable.
  8. Adjust wiper arms if necessary.
Here is the picture of the motor....it is the round object in the middle of the picture that looks like a can and has a square block on the end of it.
You have to remove the cowl vent panel....just under the windshield. $64.00 for a new motor.
Posted on Oct 01, 2009
Testimonial: "Fast and accurate response."
SOURCE: Power Fold Rear 3rd Row Seat on 2006 Ford Explorer
Power Fold Rear 3rd Row Seat on 2006 Ford Explorer will not raise. I can hear motor trying to raise seat. The gear does not appear to be turning. Motor hums like it is in a bind. What needs replacing?
Posted on Nov 14, 2009
  • 4 Answers
SOURCE: Hotpoint Aquarius 1000 WM62 motor problem?
the motor is shorting, it could be faulty brushes if you are lucky. Look at the wires in the plastic connector to make sure they are not sooty from burning. I had to rewire one on my machine.
Posted on Dec 17, 2009
My liftmaster formula I belt drive won't go up or down. The motor just hums . I can manually lift and lower door, nothing appears to be hung up. Is the motor shot? Can I replace it?
if the motor just hums , that indicates that the star/run capacitor for the motor needs replacing
call in an electrician to check it pout
May 07, 2016 | Building Materials
Question about Samsung WF338AAB 4.0 cu. ft. Front Load Steam Washer will not spin or remove water Drum will not turn
Motor coupling is byby. Needs replacing $25 to buy or so remove 2 motor brackets drop motor replace coupling place back. Done unplug electric unit first off course
Feb 15, 2015 | Samsung Washing Machines
I have a 33 gal craftsman compressor when I turn on the relay switch hums but the motor doesn't spin?
I would check the capacitor since it appears that the motor is not locked up. Here is a how to on testing capacitors;
how-to-check-capacitor
May 16, 2012 | Craftsman 33 gal Air Compressor 6 hp...
Washing machine stopped spinning & tumbling at any cycle. Have limited knowledge on multimeter use, but door lock/switch appears to be in working order. Belt around motor in excellent condition. ...
Check the condition of brushes. Replace if necessary. Check motor rotation. Not rotating, check if it has a soft starter for motor. If there is soft starter, bypass it. Check the motor rotation. If it does not rotate, then it is quite likely that the motor is burnt.
- sonsunny
Jul 09, 2011 | Washing Machines
Cannot adjust the tension on Schwinn 202. Computer is on but tension will not move up or down
I have the same problem with a schwinn 202 that someone gave to me because the resistance adjustment no longer worked. They were advised by Schwinn that the motor needed replacement, but after testing mine, the problem seems to be a lack of power from the computer to the motor. Schwinn tech support will get a call from me tomorrow.
Nov 21, 2010 | Schwinn Cycling
GE electric dryer not working
It sounds like your motor is failing.You went to turn it on and it hummed... The motor got hot and triggered the safety shut off. When it cools you may be able to get it to hum again. But you will need to replace the motor.
Let me know if I can help you further.
Apr 15, 2010 | GE DWSR405EBWW Electric Dryer
Oct 19, 2009 | 2006 Ford Explorer
Dryer hums but won't tumble. I can manually turn
most likely motor will need to be replaced if you do repair try to remove blower wheel first you will need a 1/2" rachet and a 7/8 for the motor to hold motor in place you may need to replace also they will lock together some times
Sep 26, 2009 | Kenmore Dryers
Filter hums when turned on will not kick on
Your motor is what is termed as "locked up" This is a term to describe either a motor armature which will not spin because of a mechanical or electrical problem. Electrical issues can sometimes be easy to fix.
If the start capacitor is bad, it simply needs replaced in order to fix your problem. Most all pool pumps have a Start capacitor located in a small metal *** attached to the motor. You will either need to have a capcitance tester to see if the capacitor is bad, or buy one and replace it if you have money to burn.
I say that because the problem causing the hum could also be due to a mechancical failure, and not so easy to fix. If the bearings in the motor are run down, seazed or damaged, the motor will just hum and not pump. same result ( humming motor)... different reason. Most electricians or air conditioning or mechanical service companies could test the motor and suggest which repair is needed.
Jul 31, 2009 | Hayward Pool & Spa
Toys Logo
107 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
