Question about Motorola Radio Communications
I have a cm200 base station and need to sync it with my cp 200 radios
I had a set of cp 200 radios and a cm200 base station, I now bought another set of cp200 radios. The new set of radios is receiving from the old set of radio and base station but not transmitting them
    Problem Solver:
  • 12 Answers
Hi Raymond, we're a Motorola /Vertex Dealer and have the software and cables to program everything to match. as long as they are all on the same frequency range (meaning the new Portables are not VHF and the base is UHF, if both are the same, we can take care of programming for you, $35 each unit programmed. shoot an email over to us metrocom2 @ yahoo (dot) com - jenny
www.metrocomdc.com
Posted on Mar 21, 2014
dobhan
  • 105 Answers
SOURCE: Motorola GM300 Base Station
Pls check your power supply it can cause a garbled audio once the power supply is not regulated or constant voltage so your transmission also is defective,check also the connector it should be tighten,if not do change your microphone for temporary......
Posted on May 23, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola talkabout 200
Here is a link to the TA280 manual, which is similar to the TA200, http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T280_User_Manual.pdf
Funny thing, I haven't found the TA200 manual in English. Here it is in Czech: http://www.cbradio.cz/doc/Motorola/PMR%20TA200/manual.pdf If you do a google search, you can find the page and have it translated. I'll keep looking, and if I find it in English, I'll repost.
Posted on Nov 10, 2008
eradiostore
  • 1654 Answers
SOURCE: Lost manual - can only get one T3 radio to transmit
http://www.motorola.com/mdirect/manuals/fv200_userguide.pdf
Check your Interference Eliminator Code.
Posted on Dec 10, 2008
eradiostore
  • 1654 Answers
SOURCE: Motorola Talkabout FV700 not transmitting nor receiving
To troubleshoot: Unlock your keypad lock, then reprogram your radios to the following settings. (Check function after each change)
1) Shut off the Interference Eliminator (set to zero).
2) Turn off the Qt filter.
3) Vox setting to off.
By shutting off all the "bells and whistles" of the radio, you will take it back to being just simply on a frequency. If your radios do not communicate with one another then, or with your friend's radios, you have radio which is failing to operate.
If the radios do work in this simple mode. One by one add the special features back until you discover the culprit.
Posted on Dec 26, 2008
  • 104 Answers
SOURCE: I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Posted on Sep 14, 2012
How do i connect my fitbit device to my verizon tablet.
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
Sep 17, 2014 | Fitbit Ultra Tracker
Why My trittOn warhead 7.1 headset port keeps blinking
There are a couple things that could blink on a Tritton Warhead 7.1 headset:
1. The round quadrant on the base station
2. The sync button on the headset piece itself
On 1. That means you have to sync it with your Xbox. Press the button on the Xbox that you would usually pres to sync a controller (it kind of has 3))) on it) and then press the sync button on the base station. they should sync up, then you have to press the ( 3 ))) ) ones on the inside of the headset until the quadrant on the Base Station is the same as on your controller.
2. that means that the headset is not connected to the base station. Try to unplug it form the power socket but if you get no lights on the base station at all it might be faulty or the power adapter might be faulty
You get 2 yars of warranty from the purchase date so submit a ticket on support.madcatz.com
May 14, 2014 | PANDIGITAL Photography
What is the point gap setting for 1980 honda Twinstar 200 cc?@
Hi, Marvin for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda TWINSTAR 250 Service Repair Maintenance
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Honda CM200
https://en.wikipedia.org/wiki/Honda_CM_series
Mar 28, 2013 | Honda Motorcycles
We are unable to receive radio stations on our recently purchase lcd26advd, is this tv set up or how it should be. The instruction manual makes no mention of radio stations.
Digital TVs or set-top boxes only receive the digital TV signals not the digital radio signals. To receive digital radio, you need a digital radio (DAB+) receiver. The ABC does broadcast two of its digital radio music stations-ABC Dig Music and ABC Jazz-on digital TV and they are available on channels 200 and 201.
If this is helpful a vote of the thumbs up would be appreciated
May 02, 2011 | Televison & Video
Are these Avaya phones incompatible with blue tooth headsets such as a Voyager Blue Tooth headset? I bought two new Voyager headsets that won't sync, but they each sync on another type of phone.
Yes, those are analog phones.
Do you have the Voyager base station? That should be able to plug into the phone via the curly cords.
The headset then syncs up with the Voyager base station.
Mar 24, 2011 | Avaya 8101 1-Line Corded Phone
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
CP 200 LED shows it is in scan mode, but does not ...
On the CP200 radio the scan feature must be programmed into one of the side buttons of the radio, plus the channels must be select to be in the scan list. Your radio would need to be reprogrammed to scan the channels you want to scan.
Programming requires a RIB (radio interface box), cable, and Motorola proprietary software. Your local Motorola dealer should have a subscription to this software and be able to program the radio to scan.
Best regards.
May 19, 2010 | Motorola Walkie Talkie 2-Way Radio
CWD4900SE - We have just bought a refurbished extra handset but it has OUT OF AREA on the screen. We have lost our manual - is there something we need to do to get the new handset to be recognised by our...
You shouldn't have to do anything special, just place the new handset into the main base station so it can sync to your frequency.
If that's not working, then the refurbished unit is defective and you should exchange it.
Jan 14, 2010 | Cable_and_wireless CWD4901 Cordless...
Motorola phone MD7081 has eight phones with one base. All phones say "Out of reach" - new batteries installed, etc.
When you install a new battery, you need to place the phone (each one) in the base so it can sync up to the base stations radio signal.
Have you tried placing a phone in the base so it can sync up?
Jan 12, 2010 | Motorola Mobility MD7081 Cordless Phone
Uniden washington base station
I need the wireing information for uniden washington CB radio,thank you.
Oct 28, 2008 | Uniden PC78ELITE 40-Channels Base CB Radio
Radio Communications Logo
71 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
