Blue tint on prints
I have all correct color cartridges on my Mg5250 printer. All my photo prints are getting blue tint. The nozzle check chart looks perfect including the black grid. Whatever I set it to grey-scale or play with settings it gets blue. Tried different computer, tried printing from usb. In addition, I can see purple color everywhere inside my printer but its not leaking- looks like it was sprayed around. thanks Kris
nitinbabbar
  • 55 Answers
SOURCE: HP psc1210 not printing in Black
u better try this ,remove color catridge from the printer,switchoff n switch it again with black catridge only,the printer will give catridge error dont worry ,n try to print any black font document from the printer n see does it print black,n reply
thnx
Posted on Jan 28, 2008
  • 2072 Answers
SOURCE: Xerox 8200 Phaser color problems
Have you gone to Xerox.com and clicked Support and Drivers.
In the box that appears type Phaser 8200. The click the red drivers and downloads. Then scroll down and download the jet snipit files.
Then run it as the directions tell. It does a specific jet cleaning that may restore the blue.
Also have you tried to subsitute any jets? The jet substitution comes up in the remove light stripes area. There is a test pattern that prints out with the colors and jet numbers. You then substitute the jet number with the blank square.
You can try those, but with an 8200, I strongly suspect the only thing that is going to correct the problem you have it to replace the print head itself.
I will say also, that is a very expensive part.
The Phaser printers that are toner based now. They produce the best quality color print available. The toner particles on those now align, and are not just placed on the paper "close" to correct. They do it perfectly.
If exact and outstanding color is what your looking for I would look in that direction to be honest. A new print head for a 8200, is over $700.
Try the snippet cleaning, jet substitution and if those dont help, more than likely , I would say 98 percent chance your print head is needing repalced.
You indicated you used the different color settings. Does that include tek color correction?
At the Xerox.com site look into that under support. In the support area type in blue then follow the incorrect color items.
Wish I had an exact answer. In a way there is, but you have to try the snippit and substitution modes to verify the print head will not clean itself properly.
Posted on May 17, 2008
SOURCE: Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Posted on Oct 20, 2008
eagle338
  • 4889 Answers
SOURCE: R200 will not print black color
Sounds like maybe the chips on the cartridges aren't making proper contact. Have you tried removing the black cartridge and reinserting?
How long did it take you to replace all the color cartridges? If it sat uncapped for very long, the black may simply be clogged. Often a few drops of Windex with Ammonia D (not the lemony stuff!) on the purge/park pad will do it.
With the lid up turn it on, and as soon as the heads are unparked pull the plug. Very gently, slide the print head out of the way. With an eyedropper, put a few drops of Windex with Ammonia D on the park pad, enough to make it obviously damp but not overflowing. If it is all gummed up, you'll need to clean it. In that case look here for more detailed instructions:
http://www.polyphoto.com/tutorials/PrintHeadCleaning/
My printer cleaning site is kind of rough, I wrote answers to others and got tired of retyping and just saved a few.
If the park pad is not all gummed up, then gently slide the print head all the way back over the park pad. As you do, the park pad automatically comes up under the print head so don't worry about it drying out. Leave it for a few hours or overnight before plugging it in and turning it on again, then run a cleaning cycle and try a nozzle check.
Never run more than 3 cleaning cycles in a row without printing -something-, even if it is just a nozzle check. And never -ever- move the print head manually while the printer is plugged in.
Posted on Nov 06, 2008
SOURCE: my hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
Posted on Jan 04, 2010
Why are my prints only printing the reds and blues in photos?
Please next time put the question in the correct category. I still will try to help you.
If your printer does not tell you any cartridge is empty, and it still does not use that colour it could be the nozzles of one cartridge are blocked. Check this by printing a test page, as told in the user manual. Sometimes called an alignment print.
Then check if all colours appear correct. Looks like yellow is not working correct.
May 08, 2014 | HP Photosmart 7520
Red and blue tint
Often "grayscale" is achieved by mixing some of your colors (CYM) to form composite black and gray - not necessarily just black from your black cartridge. Often there is some yellow used beneath the black -- so if you are getting a red or blue tint, it could mean something as simple as being low on yellow ink.
Jan 26, 2014 | Office Equipment & Supplies
Wrong colors printing
Perform a nozzle check and make sure all colors are printing properly.if not perform a head clean
Oct 24, 2012 | Canon MG5250 Printer
All color images are printing pink/orange. all inks are only 1% used. the very first photo i printed was beautiful. every photo since has been the pink orange color. even the black is not printing well
This sounds like a blue ink cartridge failure or a clogged blue ink nozzle. If you have cleaned the nozzles, I would try another blue cartridge. if this does not solve the problem more aggressive cleaning may be required. Let me know and we can go throught the process. Thanks.
Apr 21, 2011 | Lexmark Prospect Pro205 Wireless...
R1900 adds blue-green tint to my photo prints
Epson doesn't like Generic Cartridges.
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 22, 2010 | Epson R1900 Printer
I have all the correct color cartridges on my MP530 color printer. All of the sudden it coated a blue tint to my color printings. My print out look blue. Any suggestions I can correct the printer to print...
Just make sure the right colors are in the right place, photo magenta is not interchangeable regular magenta. Also run the nozzle check to make sure all colors print, if after 2 deep clean cycles you don't have all colors you may need a new printhead.
Jan 10, 2010 | Canon PIXMA® MP530 All-In-One Printer
Canon i860 won't print deep colors
I had similar problem: everything muted and with brownish tint. Tried everything, finally discovered that I installed wrong cartridge: 6PC instead of 6C. The "photo" cartridges are pretty much the same, make sure you have the right ones: 6C, 6M, and 6Y.
Nov 17, 2008 | Canon i860 InkJet Photo Printer
Blue tint suddenly appearing on all my photos
you may need to run a clean on ur nozzles and check if you are low on ink.
Jun 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Multiple Problems Printing
Replace the print head, and all should be just fine.
Jan 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
k24674
jasbo
jasbo
